Medeek Wall Plugin
Re: Medeek Wall Plugin
Postby medeek » Sun Sep 27, 2020 2:29 am
Version 1.6.7 - 09.26.2020
- Added additional tool tips to the Wall Corners tab of the Global Settings.
I've been fielding a lot of questions recently about the corner offset parameter and related wall end/corner conditions. I may need to still provide additional documentation and diagrams to further clarify these parameters.
3
Nathaniel P. Wilkerson PE
Medeek Engineering Inc
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Sep 29, 2020 2:53 am
Version 1.6.8 - 09.28.2020
- Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
Previously when you renewed your license you would need to go through some convoluted steps to refresh you license data within the plugin. This new feature reduces this process to a single mouse click.
Previously the required steps were:
1.) Remove the existing serial number.
2.) Click the Save Settings button.
3.) Re-enter your serial number.
4.) Click the Save Settings button again.
5.) Restart SketchUp.
3
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Oct 17, 2020 6:23 am
First look at a 3D batten cladding on rectangular walls:
View model here:
https://3dwarehouse.sketchup.com/model/ ... ten-Test-1
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Oct 17, 2020 7:18 pm
Some more screenshots of battens:
*Notice the format of the batten material and its three numeric values within the name of the material.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Oct 17, 2020 7:42 pm
Texture vs. 3D Battens:
Personally I prefer the texture myself, lower poly and it looks just as good or better than the real deal.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Oct 17, 2020 11:22 pm
Version 1.6.9 - 10.17.2020
- Added the ability to create custom "Board and Batten" wall cladding materials within the Material Library.
- Enabled "3D" Board and Batten wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
For the plugin to recognize the wall cladding material as a "board and batten" material is must be in this format:
battens_{decimal value}_{decimal value}_{decimal_value}
The three values are: batten spacing, batten width, batten depth respectively.
There should be no white spaces inserted into the name, only the underscore character in three places as shown.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Oct 18, 2020 11:02 pm
Another view of board and battens:
Just over five years into programming these plugins, I released the first version of the Truss plugin Oct. 7, 2015.
The further I go it seems like I just keep coming up with more things "todo". I really need to take myself and clone me about five times and then set each clone at developing the various plugins, maybe then I might get somewhere with all of this.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sat Oct 24, 2020 2:13 am
Version 1.7.0 - 10.23.2020
- Fixed a bug in the Walls tab of the Global Settings.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Oct 29, 2020 6:30 pm
The Medeek Wall plugin (and mdkBIM) was featured in this 3D Basecamp Fireside Chat:
https://www.crowdcast.io/e/fireside-chat-series-ep7
3
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Nov 16, 2020 8:30 am
Version 1.7.1 - 11.15.2020
- Added additional HSS and Wide Flange Beam options to the free standing column (post) tool.
3
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Nov 17, 2020 4:15 am
Version 1.7.2 - 11.16.2020
- Added the ability to create custom "Shiplap" wall cladding materials within the Material Library.
- Enabled "3D" Shiplap wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Wed Nov 18, 2020 9:03 am
View example model of 3D shiplap here:
https://3dwarehouse.sketchup.com/model/ ... iplap-Test
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Thu Nov 19, 2020 4:29 am
Medeek Wall Plugin Tutorial 17 - Tag/Layer Folders:
View model here:
https://3dwarehouse.sketchup.com/model/ ... er-Folders
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Fri Nov 20, 2020 8:31 am
Version 1.7.3 - 11.20.2020
- Fixed a bug with zero height gable, shed and hip walls when using the "No Framing" or "CMU" mode.
- Fixed a minor bug with man door and garage door jambs with walls panels that are isolated in groups.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Nov 22, 2020 1:54 am
Version 1.7.4 - 11.21.2020
- Completed the "Garage Doors" tab within the Global Settings.
Some more slightly tedious code, but necessary.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Sun Nov 22, 2020 11:28 am
Version 1.7.4b - 11.22.2020
- Completed the "SSW" tab within the Global Settings.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Nov 23, 2020 6:08 am
Version 1.7.4c - 11.22.2020
- Completed the "Beams" tab within the Global Settings.
- Fixed a critical bug with the default settings for the following two window parameters: Jamb Ext. Reveal, Shim Gap.
*** CRITICAL BUG FIX ***
When you first load the plugin it sets default parameters for walls, door, windows etc...
A previous update introduced a typo into the code which incorrectly set the two window parameters listed above. This update corrects those two typos. It is highly recommended to update to the latest version of the plugin.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Mon Nov 23, 2020 1:00 pm
Version 1.7.4d - 11.23.2020
- Completed the "Columns" tab within the Global Settings.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Postby medeek » Tue Nov 24, 2020 12:15 am
We’ve all had a trying year these last few months but somehow, thanks to our customers, we’ve managed to keep up the good fight and are still actively developing our extensions here at Medeek Design.
In recognition of the overwhelming support I have received from the SketchUp community these last few months I will be immediately offering 40% off of the mdkBIM bundle price using the coupon code GIVETHANKS20. (ends Dec. 1, 2020).
This will reduce the bundle price from $170.00 USD to $102.00 USD. This promo code does not apply to any of the extensions purchased separately or to the electrical plugin. The offer also ends on Dec. 1 and no rain checks will issued thereafter.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: anchu_shah, Cha4s and 13 guests
Visit our sponsors:
