[Plugin] Extended Views v1.2 UPDATE May 23, 2013
Re: [Plugin] Extended Views v1.2 UPDATE May 23, 2013
Postby leedeetee » Thu Mar 03, 2016 2:11 pm
Thank you John.
User avatar
leedeetee
Premium Member
Premium Member
Postby ronhiatt » Wed Aug 24, 2016 4:53 am
What a great plugin! Once installed, I mapped my arrow keys to it, and now I can see the basic mechanical views of my cabinets. Obviously this should have been the default in SU originally. THANKS!!
How do I send a donation? Really.
Ron
ronhiatt
Premium Member
Premium Member
Postby AirWindSolar » Fri Dec 09, 2016 8:22 pm
Any word on an update for SU2017? This was probably the extension that I most often forgot wasn't just an integral part of SketchUp, and I'm missing the functionality a lot.
4
AirWindSolar
Postby drw12333 » Tue Feb 21, 2017 8:54 pm
any chance for update to 2017?
4
drw12333
Postby tuoni » Wed Sep 13, 2017 11:14 am
One of the best plugins and simplest, I use nowadays in SketchUp. In particularly with Vray. Keep up the good work Chris Fullmer! But any words about the upcoming update for 2017 version?
tuoni
Postby wrc86 » Thu Apr 12, 2018 8:22 pm
Are you OK Chris Fullmer? Is there anyone that can fix extender views for SU2018 or a code to copy and paste to make ir work?
wrc86
Re: [Plugin] Extended Views 2017 and possibly more
Postby tomaszdrgas » Thu Oct 11, 2018 11:42 am
Hy .. Dzieńdobry
I'm just starting with sketchup API and I have choosen CLF Extended Views as a sample lo see how extention should be made..
Soon enough I realised that it doesn't work in sketchup 2017..
I found out it was due to change made in sketchup 2017 when exploding groups..
I started to learn ruby last month but with lots of digging in sketchup's API documentation I managed to fix it.. (So proud :-D)
Here is the .rbz file (just zipped it and changed the extention to .rbz)
CLF Extended Views.rbz
I wanted to send that file directly to Chris so he could maintain it in extention warehouse but couldn't find his email.. Hope You don't mind.. It was a greate excercise to me..
Tomasz
tomaszdrgas
Postby JClements » Sun Oct 14, 2018 6:08 pm
In ChrisF's original post he wrote wrote: . . . But it works with user defined axes. Currently if you change the axis of your model, and then change to one of the standard views, it will not align to your set axis. This plugin fixes that and it aligns the camera to the user defined axis.
Although it includes a Bottom View icon and performs a "Zoom Extents", it doesn't pivot the view according to the CURRENT axis, however.
I tested this new version using SU2018.
John
Illustrator
Beaverton, Oregon
User avatar
JClements
Premium Member
Premium Member
Postby tomaszdrgas » Mon Oct 22, 2018 11:16 am
I use 2016 and 2017.. I don't have possibility to check how it works in 2018..
tomaszdrgas
Postby juju » Mon Oct 22, 2018 6:26 pm
tomaszdrgas wrote:I use 2016 and 2017.. I don't have possibility to check how it works in 2018..
Kindly update your profile, which reads that you're still on v8.
User avatar
juju
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: dasck91, Jorgeazbu, rhamah10 and 13 guests
Visit our sponsors:
