[Plugin] Grow
Re: [Plugin] Grow v2.1
Postby brookefox » Thu May 17, 2012 6:06 pm
I'm a new 'grow' user and am confronted with immediate splats after after processing. Knowing how diligent TIG is about resolving issues, I don't doubt the problem is a conflict with one of the plugs I've recently installed. Prior to uninstalling them in batches to try to isolate the culprit, I thought I'd ask if there anyone had problems but did not mention them. I get no results searching splats here.
Thanks.
EDIT: Whatever the problem was, it has gone away.
~ Brooke
User avatar
brookefox
Re: [Plugin] Grow v2.2 20120519
Postby TIG » Sat May 19, 2012 5:08 pm
Here's a minor update viewtopic.php?p=324331#p324331
v2.2 avoids a clash with some rogue scripts' messing with base classes/methods for selection/group and/or miscast observers, that a very few users had reported recently.
Now fixed for all [I hope!]...
User avatar
Global Moderator
Postby brookefox » Sat May 19, 2012 6:57 pm
Thank you, TIG. Your attentive diligence is inspiring.
~ Brooke
User avatar
brookefox
Postby nektares » Sat May 19, 2012 7:37 pm
Hi TIG :) this looks like a very interesting plugin but when i try to use it i get this on the ruby console:
for nil:NilClass>
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Grow.rb:339:in `move'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Grow.rb:336:in `each'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Grow.rb:336:in `move'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Grow.rb:554:in `run'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Grow.rb:86:in `onLButtonDown'
¿Am i missing something?
nektares
Postby TIG » Sat May 19, 2012 8:25 pm
nektares wrote:Hi TIG :) this looks like a very interesting plugin but when i try to use it i get this on the ruby console:
for nil:NilClass>
I suspect that you have some rogue script installed that is beyond this last fix... I'll look at an update... :roll:
User avatar
Global Moderator
Re: [Plugin] Grow v2.3 20120519
Postby TIG » Sat May 19, 2012 8:43 pm
Here's v2.3 viewtopic.php?p=324331#p324331
I hope that it finally addresses all of the issues cause by 3rd party rogue scripts that ill-advisedly overwrite base class/methods and/or with miscast observers for groups/selections...
Sorry for today's confusion...
The tool only failed for a few users who had this 3rd party script combo... BUT now ALL should work OK... :?
User avatar
Global Moderator
Postby nektares » Tue May 22, 2012 3:06 pm
Thanks a lot TIG :)!!
I found the guilty plugin, The problem was caused by SketchyPhysics3 i removed it and now my mirror plugin, my mshstick plugin and the grow plugin now work fine!
I´m having a blast with your script, thank you!
nektares
Postby 258093521 » Mon Aug 06, 2012 4:43 am
good job
Postby ivreich » Tue Aug 07, 2012 5:05 am
Instant Bugsplat
HI TIG
I downloaded the latest version of grow but I'm still having instant bugsplats. No error messages.
I used a simple box, and don't have SketchyPhysics installed...
Joel
ivreich
Postby TIG » Tue Aug 07, 2012 9:37 am
Joel
If you have the Ruby Console open before you use it are there any messages ?
Do you have DrivingDimensions, SunStudy, Matchbox, Podium installed - these can have similar issues as SketchyPhysica and break standard methods...
Can you post the simple SKP that fails for you, with instructions on what you do to get a 'fail'...
User avatar
Global Moderator
Postby joeyme » Sat Oct 20, 2012 12:50 pm
very nice
joeyme
Re: [Plugin] Grow
Postby TIG » Thu Dec 12, 2013 10:43 pm
Here's a new future-proofed update.
User avatar
Global Moderator
Re: [Plugin] Grow
Postby huckrorick » Thu Feb 11, 2016 5:33 pm
Hi Tig,
I just tried your plugin. very cool. However, it seems like I can't get it to do what I want. I want to offset a component by a fixed amount (this works fine) and have each element be a fixed amount taller (e.g. 6"). I only seem to get a fixed increment with a scaling factor of 1.0 and then the increment in height is equal to the height of the component.
Can I accomplish what I want with your plugin?
huckrorick
Re: [Plugin] Grow
Postby pilou » Thu Feb 11, 2016 6:42 pm
Normally you can take any value on each axis, by move, by size, by rotation!
Speedy Galerie
User avatar
Top SketchUcator
Re: [Plugin] Grow
Postby YDAVIDI » Wed Mar 14, 2018 8:52 am
HELLO
IT SEEM LIKE A GREAT PLUGIN BUT THE AXIS I CHOSE DOESNT WORK.. IT ALWAYS ROTATE IT AROUND SOME OTHER POINT..
CAN YOU PLEASE HELP
THANKS!
YDAVIDI
Re: [Plugin] Grow
Postby TIG » Wed Mar 14, 2018 11:33 am
Make sure that your axes are reset to the default model-axes [right-click on an axis and choose reset if available].
It'd be sensible to locate the objects you want to 'grow' around the model's origin, then when prompted just snap to the origin [where the axes meet].
The XYZ [RGB] axes are what's used by the tool.
Also ensure that unit-snapping is OFF in Model Info > Units.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: Arx, Google Bot, junji kina, yvs21 and 7 guests
Visit our sponsors:
