3D Truss Models  Topic is solved
Re: 3D Truss Models
Postby medeek » Mon Nov 06, 2017 1:22 am
Version 2.0.5 - 11.05.2017
- Added gutters and downspouts for rafter and truss hip roofs.
- Gutter menu added to the global settings.
- Custom roof layer added for gutters in the layer menu within the global settings.
I still need to add gutters and downspouts to the gable roofs (truss and rafter).
Four gutter types with two different downspout types.
This is a new feature so please send me your feedback and I will try to address all of the issues.
The gutter shown is a 6" half round with a 2.75" round downspout. The gutter and downspouts are separate solids so that one can easily adjust the placement of the downspouts after the fact.
The downspout angle is 15 degrees, with a 3" drop out of the gutter and a downspout center line radius of 3".
View model here:
https://3dwarehouse.sketchup.com/model/ ... Downspouts
Nathaniel P. Wilkerson PE
Medeek Engineering Inc
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Mon Nov 06, 2017 8:21 am
K-Style gutter with "2x3" downspouts.
I may need to add a few more user configurable variables:
- offset from bldg. corner (currently I have it offset 0" from the framing)
- offset from framed wall (currently I have it offset 1" from the framing)
- downspout radius (currently set at 3" @ CL)
- downspout drop (currently set at 3" before the first bend)
Right now these values are all hard coded into the plugin.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Mon Nov 06, 2017 5:15 pm
Version 2.0.5b - 11.06.2017
- Fixed a minor bug with the downspout module, downspout solid is now a uniform extrusion with no unnecessary seams or edges.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Tue Nov 07, 2017 3:31 pm
Version 2.0.5c - 11.07.2017
- Fixed a minor bug with the gutter layer for installation upgrades of the plugin.
If you have version 2.0.5b please upgrade to this version or be sure to open up the global settings and click on the layers tab, this will create the default gutter layer setting.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Sat Nov 11, 2017 5:36 am
Version 2.0.6 - 11.10.2017
- Added gutters and downspouts for rafter and truss gable roofs.
- Added gutters and downspouts for dutch gable rafter roofs.
I still need to add gutters to monoslope truss roofs, shed roofs and some other specialized truss roofs. Adding the gutters to the common truss roof became slightly more complicated when I realized I also had to deal with roof returns and their various configurations.
This gable roof has a hip return with fully wrapped gutter, you can also choose to half wrap or no wrap (linear gutter only at eaves, does not wrap around corner).
The dutch gable is really no different than the regular hip roof, when it comes to the gutter and its configuration, but internally it is a completely different set of advanced options.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby pbacot » Sat Nov 11, 2017 6:55 am
Very nice looking models!
MacOSX (El Capitan) ShetchUp Pro v16 Layout Twilight Pro v2 M2 Kerkythea PowerCADD
User avatar
Top SketchUcator
Re: 3D Truss Models
Postby medeek » Sat Nov 11, 2017 4:21 pm
Half wrap of a hip roof return:
All of the gutters and downspouts are constructed as solids so that it is easy to manipulate them with Pro's boolean tools or other third party solid tools.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Sun Nov 12, 2017 8:08 am
Version 2.0.6b - 2017.11.11
I've added a text file in the materials sub-folder that allows one to modify the available materials (colors) for the gutters within the global settings menu.
The default values are:
8B4513:BROWN
B87333:COPPER
C0C0C0:SILVER
FFD700:GOLD
8B0000:DARK RED
0000CD:MEDIUM BLUE
006400:DARK GREEN
556B2F:DARK OLIVE GREEN
FFFFF0:IVORY
If all of these custom materials are deleted then only "white" will be available "FFFFFF" in the global settings.
The first six letters is the RGB value for the color, the description after the colon is the color name.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Mon Nov 13, 2017 3:57 am
The Medeek Seal of Authenticity:
This will be shown in the new license tab of the plugin global settings when the copy is fully registered.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Tue Nov 14, 2017 5:16 pm
Had a little fun with AutoCAD and SketchUp yesterday. I created the arc aligned text in AutoCAD first and then imported the DXF, then completed the solid model in SketchUp:
I can't believe I used to solid model in AutoCAD, what a clunky interface for that sort of thing. I will say though that AutoCAD is still king when it comes to 2D drawings though, SketchUp has a ways to go in that regard.
Even solid modeling in SolidWorks seems really slow and awkward now, and that used to be my goto for anything 3D.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Thu Nov 16, 2017 5:29 pm
Version 2.0.7 - 11.16.2017
- Added license tab to the global settings.
- Minor updates to the licensing system.
I've spent a couple days on adding language support but was unable to roll it out with this latest release. I will keep working on this in the next few days and hopefully have something to show for my efforts with the next major release.
As far as languages go I am planning on producing language files for each of the SU supported languages.
Any help with translating some of these very construction specific terms and phrases would be greatly appreciated. Google translate seems to work quite well but I don't completely trust some of its translations.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Fri Nov 17, 2017 8:00 am
Starting to make some head way on the translation / language support:
I've decided to devise my own language handler since I could not get the built in one to work.
The upside is that this allows me so support any language I choose, not just the languages supported by SketchUp. I will be adding in an option in the general settings where the user can select their language of choice.
I will also be storing the language data in a new sub-folder "lang". My intent is to be able to make it possible for the user to add their own language file and translations if they need to.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Fri Nov 17, 2017 5:02 pm
I've identified a couple of major bugs with the gutter module when using metric templates. I will address those later today and roll out a sub-release. I apologize for not catching those earlier.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Sat Nov 18, 2017 8:21 am
My first menu in Japanese:
Fortunately, I know a little Japanese so I think I've got these more or less correct. I will probably need to have a native Japanese speaker who is familiar with the construction industry check these over for me.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Sat Nov 18, 2017 7:57 pm
I've added in a language option into the General tab of the Global Settings:
I currently have nine languages that I will support however if there are any others that you would like to see added please feel free to suggest one.
I think this method is preferable over using the locale of the installed plugin since someone that is running a french version of SketchUp may want to run the plugin in English or some other combination. This allows the user to customize their user experience exactly.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Sun Nov 19, 2017 8:29 am
Version 2.0.8 - 11.18.2017
- Added language support for the following languages: French, Spanish, German, Russian, Swedish, Japanese, Korean, Chinese.
- Added a language option in to the "General Tab" of the Global Settings.
- Fixed a bug in the gutter module for metric templates.
There is still a huge amount of work to get all of the menus translated into the eight languages given above.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Sun Nov 19, 2017 6:48 pm
I apologize Version 2.0.8 had a fatal flaw in it that thankfully someone pointed out to me this morning. Please re-download sub-rev. 2.0.8b which addresses this issue immdediately.
The problem is that I am encrypting the .rb files into .rbs when I sign the plugin. I don't want to encrypt the language files in the "lang" folder however the signing page did not know to discriminate so it encrypted those files as well and hence broke my links to them from the plugin load module.
Once I sign the extension and encrypted it I had to re-open the .rbz and put back in the unencrypted language files, problem solved.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Sun Nov 19, 2017 7:24 pm
Found this image on Mitek's South African Website, its insane how big that truss assembly is:
This one is enlightening in that is shows the system of battens being used on the roof:
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Sun Nov 19, 2017 7:45 pm
Based on Mitek's worldwide coverage alone I should probably also support the following additional languages:
Czech
Polish
Portugese (Brazil)
Finish
Romanian
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Mon Nov 20, 2017 7:46 am
Web based (HTML) user inputs will also require translation. These are a little more challenging than the regular (non-graphical) UI but nothing a little javascript could not overcome.
Here is the gutter tab of the global settings translated into Japanese:
The translation (creation of language files) for each menu and alert will take some time and effort.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Mon Nov 20, 2017 9:05 pm
I'm not really happy about SketchUp's move to discontinue its Make version. I've already posted my thoughts on the SU forum about it in another thread but to reiterate my points I will post it here as well:
I’ve invested a lot of my time (the last two years of every free moment I’ve had) and effort into developing a couple of plugins for SketchUp. Granted my intended audience is the PRO user by in large but I think SketchUp is really shooting itself in the foot and also negatively impacting its many plugin developers like myself by pushing a web based platform that does not allow for the installation of extensions and is completely missing the Ruby engine.
As far as doing anything productive I have never used a web based app except for the simplest operations. Even email, I still check with Mozilla Thunderbird or Outlook, I can’t stand web mail. Web based apps and the web in general is great for online maps, simple games, news sites, Wikipedia and disseminating information. Name one other major CAD platform that has a significant amount of its users using some sort of web based CAD utility, they don’t exist, and probably for a good reason.
I really think SketchUp and Trimble should reconsider this move. If you push people like myself away, that help make SketchUp more useful, you will lose it all. Yes, your established user base will stay, but its your new incoming user base that will fall off. Without a solid full feature free version the new kids coming up through high school and college will find something else. No one is going to seriously use the web based version, it’s too slow and limited. Other software will spring up to fill the void, and you will slowly loose whatever market share you might already have.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Mon Nov 20, 2017 9:58 pm
and...
I think I can read between the lines. Trimble is wanting to squeeze more of the casual-pro users into upgrading to a Pro license by eliminating the gravy train known as Make. The vast majority of the customer base is probably Make users with a small percentage of Pro (paying) customers. To make SketchUp viable they need a larger volume of paying customers, I get it, I have the same problem with my own plugin income, the volume is too low.
The problem is that in order to charge a Pro price you really need to offer a full fledged “Pro” product. This is where I feel that SketchUp has let itself and its user base down. Only recently has layout become a more serious tool. Without the ability to seamlessly produce production drawings (the real world product of designers and engineers) SketchUp is merely a conceptual tool that no one takes too seriously.
The reason the Pro user base is too small is because it is not full featured enough. The solution is to beef up Pro even more so it can really compete in the marketplace against the big boys. A better product will draw more customers, build it and they will come, as they say. Trying to squeeze your customer base is never a great idea, its only a road to a slow demise.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby faust07 » Mon Nov 20, 2017 10:42 pm
Thank you for your incredible efforts to develop plug-ins for building construction solutions. Even the renderings are getting better and better. I'm thinking about whether the techniques are also suitable for the requirements of building constructions in Germany... Keep up the good work! :thumb:
faust07
Re: 3D Truss Models
Postby pbacot » Mon Nov 20, 2017 11:11 pm
Good points. Thanks for your work on these applications!
User avatar
Top SketchUcator
Re: 3D Truss Models
Postby medeek » Tue Nov 21, 2017 6:54 am
faust07 wrote:Thank you for your incredible efforts to develop plug-ins for building construction solutions. Even the renderings are getting better and better. I'm thinking about whether the techniques are also suitable for the requirements of building constructions in Germany... Keep up the good work! :thumb:
I'm not familiar with the building industry or codes in Germany but I would interested in learning more. I've also been working on translating the plugin into various languages this last couple of weeks and German is high on my list to get incorporated into the new language files. Please feel free to message me or send email if you have any specific questions, requests or resources on building in Germany.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby glro » Tue Nov 21, 2017 9:40 am
My experience is that translating a software is not only about words. Wooden houses are built in each country using technics that are not exactly the same. So translating words from one language to another is not sufficient.
Maybe the first step would be to check if technics are similar or not in the country you plan and if yes, then look for a a bi lingual technician
just an idea and with respect... personnaly, it would take me many lives to do the work you have done in just 2 years ...
glro
Re: 3D Truss Models
Postby glro » Tue Nov 21, 2017 9:51 am
medeek wrote:and...
my understanding is that a customer is somebody who pays for something; people using Make are not customers, thay are users, because they don't pay
you cannot expect a company to give for free and for ever its product, so i am not surprised by Trimble's decision not to update the Make version
I even find it a fair decision to keep the 2017 Make version online in the next years, so that people can adjust
Sketchup.free cannot be used by professionals, but it is a good way to learn about 3D, and hopefully, it will be able to manage extensions some day in the future
it is just my point of view...
glro
Re: 3D Truss Models
Postby medeek » Tue Nov 21, 2017 3:38 pm
@giro
I agree that offering Make for free indefinitely is not a viable business decision either. Rather than drop Make entirely they should offer it in a $50 - $150 price range for the casual user. At that price most users would be willing to bite and even the most modest income of your average middle class (non-professional) user should be able to justify and afford it. By eliminating the mid-range flagship product they are essentially eliminating a whole swath of the user base and more importantly the new up and coming user base.
Whomever is making this business decision at the top needs to reconsider and come up with a better solution.
I have been a big advocate for SketchUp and not just because I've created some plugins for it. I still firmly believe it is the most intuitive and easy to use 3D design software out there. I've used Solidworks, Catia, ProE, AutoCAD (3D work), Revit and Chief Architect. All of these other softwares have their strong points and hence are used in their respective industries but they all feel clunky and dated when compared with SketchUp.
I'm not religious about SketchUp, if something drastically better comes along then I will make the switch but I haven't found anything better yet.
I just would really hate to see Trimble take SketchUp down the wrong path.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby medeek » Tue Nov 21, 2017 4:15 pm
I agree, my translation word for word is merely a start. Ultimately, I will need a native speaker in each language that is familiar with the lingo of the construction industry in their native tongue. To properly translate the plugin will involve others and I am currently seeking out those individuals.
In fact, in that vein, I am offering a free license to any user who would be willing to help with the translation into their native tongue. I am still compiling a list of words and phrases but it should only number about 100 to 150 at best.
design.medeek.com
User avatar
medeek
PluginStore Author
PluginStore Author
Re: 3D Truss Models
Postby pilou » Tue Nov 21, 2017 8:20 pm
I can make the French part for the fun like an objective tour de force! ;)
But don't ask that for the BlackFriday! :)
Several specialized dictionaries are required! :ugeek:
Speedy Galerie
User avatar
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: asdar and 9 guests
Visit our sponsors:
