[Plugin] Select_Only
Postby TIG » Tue Dec 15, 2009 5:13 pm
In response to a request here's a quick and simple context_menu tool to limit a selection to only Edges or Faces.
For example, you select some things and then right-click, and in the context_menu choose <<< Select ONLY Edges - this will remove everything else from the selection, except the Edges... similarly use the other option for Faces etc... The options only appear if there is at least one of that type of entity [Edge or Face] in the original selection set...
#select_only_tools.rb
User avatar
Global Moderator
Re: Select_Only
Postby thomthom » Tue Dec 15, 2009 5:23 pm
My Selection Toys also does that.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin] Select_Only
Postby Didier Bur » Wed Dec 16, 2009 10:14 pm
And my "quick selection" tool as well :P
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
User avatar
Didier Bur
Postby plot-paris » Fri Dec 18, 2009 9:30 am
:D we are not short of choices then...
User avatar
plot-paris
Postby 18870314 » Wed Feb 24, 2016 2:12 am
why I can't download
Postby TIG » Wed Feb 24, 2016 12:47 pm
This thread is SIX years old. :o
The RB file which is linked in the first post would probably work if it were downloaded then manually installed into your SketchUp Plugins folder.
If you have an Ad-Blocker set for SCF's pages, it is against the ToS you agreed to, and downloading/images etc may then get blocked - disable it foe SCF - the revenue from its discreet relevant banner-ads helps to pay for this site's very existence !
However, there are now many superior tools available - e.g. thomthom's Selection-Toys [his tools need his Lib too].
I suggest you search in the SketchUcation PluginStore...
Or the EW for suitable extensions...
The newer tools' RBZs are readily installed using the native-installer, so no need to even mess on finding your Plugins folder!
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: abcab, Céline YEUNG, Diego11, mattazpi10, Raimondo_Vincenti, yldrmmr and 16 guests
Visit our sponsors:
