Vray alpha channel problem
General discussion on V-Ray for SketchUp
Postby Thomeeno » Sat Nov 23, 2019 6:47 pm
Hi, i recently noticed a problem in SU Vray - one of my textures is affecting alpha channel in Vray render - everything in alpha is white besides objects textured with this texture. These object are grayed as if texture would appear some shadow to the alpha. At the end it makes material darker (as alpha and RGB mix together) if exported to final image. I have no layers, bump and displacement maps turned off and everything switched to affect RGB only and if i delete texture everything is OK. Someone know what is it?
edit: Vray 3.4
SU 2017
Thomeeno
Re: Vray alpha channel problem
Postby Robby_GF » Sat Nov 30, 2019 8:25 am
A quick fix would be to convert the texture to JPG. It doesn't have an Alpha channel.
Robby
GarageFarm.NET The Cheapest Render Farm - 20,000 cores and growing!
Robby_GF
Return to V-Ray
