problem with V-ray
General discussion on V-Ray for SketchUp
problem with V-ray
Postby port » Mon May 20, 2019 11:14 pm
Every time I try to render I get this error in this model, I tried it with other models and it render fine.
plz help me here! :cry: :cry:
port
Re: problem with V-ray
Postby Dave R » Mon May 20, 2019 11:26 pm
Did you try contacting the folks at Chaos Group?
Global Moderator
Postby port » Mon May 20, 2019 11:29 pm
Dave R wrote:Did you try contacting the folks at Chaos Group?
I'm waiting for the answer
port
Postby Dave R » Mon May 20, 2019 11:34 pm
The fact that this only occurs with this model suggests there's something wrong with the model. Perhaps some issue with textures.
Global Moderator
Postby port » Mon May 20, 2019 11:35 pm
Dave R wrote:The fact that this only occurs with this model suggests there's something wrong with the model. Perhaps some issue with textures.
I'm waiting for your answer
port
Postby port » Mon May 20, 2019 11:37 pm
What do you think I can do to repair it?
port
Postby Dave R » Mon May 20, 2019 11:42 pm
port wrote:I'm waiting for your answer
Why are you waiting for my answer. You should be waiting for an answer from Chaos Group's technical support. You said you are waiting for an answer from them, right?
port wrote:What do you think I can do to repair it?
Short of getting a response from the Vray people, if I were you, I'd start investigating the the problem model. Remove custom textures and see if you can get the render to complete. Look at what works in your other models. Compare them to this one and see what is different.
Global Moderator
Postby port » Mon May 20, 2019 11:47 pm
sorry, the message was repeated without the previous correction
thank you so much! I'm trying to clean the model as much as I can to see what happens
port
Return to V-Ray
Users browsing this forum: No registered users and 7 guests
