creating relistic grass using vray fur
General discussion on V-Ray for SketchUp
Postby Dprince » Fri Mar 15, 2019 6:15 pm
Im unable to render large portions of grass when i use vray 3.4 with fur tool it comes with. Every time i try it freezes. any suggestion on how to remedy this?
Dprince
Re: creating relistic grass using vray fur
Postby valerostudio » Tue Mar 19, 2019 6:31 pm
Turn on Level of Detail in the fur options. You might be asking a lot of your machine with such a large area.
valerostudio
Postby Dprince » Tue Mar 19, 2019 6:59 pm
that is already turned on. is it a case where i need to make adjustments to the default settings?
Dprince
Postby Dprince » Tue Mar 19, 2019 7:19 pm
this is the area i need realistic grass and the other pic is the vray setting. which is default? im not sure what to adjust it to
Dprince
Postby majid » Tue Mar 19, 2019 9:11 pm
Reduce the knots to a lower value, maybe 3-1 then you might tweak the too close grass using Photoshop , etc. if needed.
My V-Ray book for architects: https://goo.gl/cz1oRc
majid
Top SketchUcator
Postby Dprince » Wed Mar 20, 2019 4:27 am
Dprince
Postby majid » Sat Mar 30, 2019 10:34 pm
Would be nice if please share the result.
majid
Top SketchUcator
Postby Dprince » Tue Apr 02, 2019 8:07 am
Everything worked find thanks a lot again.
Dprince
Return to V-Ray
