Rendered Walkthrough
General discussion on V-Ray for SketchUp
Postby Dprince » Mon Mar 04, 2019 8:23 pm
Hey guys quick can anyone recommend a plugin of software i can use to do render walkthroughs. im currently using sketchup pro and vray 3.4
Dprince
Re: Rendered Walkthrough
Postby solo » Mon Mar 04, 2019 9:06 pm
http://www.solos-art.com
solo
Global Moderator
Postby ntxdave » Tue Mar 05, 2019 12:32 am
You can also look at Shapespark
ntxdave
Postby Dprince » Sat Mar 09, 2019 5:54 am
does enscape adapt the material settings from vray when doing the walkthrough rendering?
Dprince
Postby solo » Sat Mar 09, 2019 3:30 pm
Dprince wrote:does enscape adapt the material settings from vray when doing the walkthrough rendering?
No, Enscape has it's own material system, does not adapt Vray materials, very simple and fast software to achieve animation and VR work
solo
Global Moderator
Postby andybot » Sat Mar 09, 2019 7:52 pm
I've moved from V-Ray to Enscape recently for walk-throughs, and can highly recommend it!
my blog featuring recent projects
andybot
Premium Member
Premium Member
Postby Dprince » Sun Mar 10, 2019 9:40 pm
I keep getting this error when i try to run enscape
Dprince
Postby solo » Sun Mar 10, 2019 9:52 pm
The warning has to do with your GPU, I assume you are on a laptop with an Intel integrated GPU which is not good enough to work with Enscape.
solo
Global Moderator
Postby Dprince » Sun Mar 10, 2019 9:56 pm
oh ok. i guess i can only use this when i upgrade. any idea how i can do the walkthrough with Vray?
Dprince
Postby solo » Sun Mar 10, 2019 10:04 pm
Dprince wrote:oh ok. i guess i can only use this when i upgrade. any idea how i can do the walkthrough with Vray?
On your system I doubt it, you would need a week to render it if indeed it was even possible, sorry mate but your machine is just not suited for such things.
solo
Global Moderator
Postby ntxdave » Sun Mar 10, 2019 10:07 pm
Once again, I would suggest you take a look at Shapespark I think it might do what you are looking for. Yes, they have their own material handling as well.
ntxdave
Postby Dprince » Sun Mar 10, 2019 10:20 pm
for shapespaek can i save the online walkthrough as a video?
Dprince
Postby pbacot » Mon Mar 11, 2019 12:02 am
Dprince wrote:I keep getting this error when i try to run enscape
Dprince,
Are you running Enscape on a Mac with BootCamp? Anyway if on a Mac see if you can select the GPU by turning off Automatic graphics switching in the Energy Saver settings. It will make the computer use a higher-performing card if you have one. Of course the card might still not be up to Enscape standards.
Top SketchUcator
Postby Dprince » Mon Mar 11, 2019 12:06 am
Dprince,
im using a windows computer
Dprince
Postby ntxdave » Mon Mar 11, 2019 3:29 am
Dprince wrote:for shapespaek can i save the online walkthrough as a video?
I do not think so. The output is for viewing in HTML/WebGL and VR.
ntxdave
Postby Dprince » Mon Mar 11, 2019 3:57 am
OK THANKS. thats not exactly what i want to do it has to be in video format and not available to just online viewing
Dprince
Postby pbacot » Mon Mar 11, 2019 4:23 am
Sorry, I read your profile and thought it was the Mac.
Top SketchUcator
Postby Dprince » Fri Mar 15, 2019 5:55 pm
I would still like to know how to do the walk through using vray. no matter how long it takes to render
Dprince
Postby valerostudio » Tue Mar 19, 2019 6:34 pm
This was an issue in the past with laptops. You still may have a graphics card Enscape can use. Try this https://enscape3d.com/knowledgebase/multi-gpu-issues/
valerostudio
Postby valerostudio » Tue Mar 19, 2019 6:39 pm
Dprince wrote:I would still like to know how to do the walk through using vray. no matter how long it takes to render
VRay will render animation based on SketchUp scene tabs. For example I would make a scene tab for point A of my walkthrough, then one for point B, point C, etc.
Setup your animation settings in model info with Scene delay off and a reasonable amount of time for the transitions, so the speed is the way you like it.
Render using VRay with animation enabled and saving to a folder. VRay will save each frame out. Then use an application to combine the frames into a video file. I bet there are a bunch of free ones. Photoshop will also do this now.
There are plugins that can make the walkthrough smoother and with animation (doors open for example) but that becomes more complex, and you have to make sure its VRay compatible, but the procedure above is the fastest way to get up and running (pun intended).
Smustard had some nice path animation plugins a long time ago. I am not sure if they still work. Worth a shot.
valerostudio
Postby Dprince » Tue Mar 19, 2019 7:10 pm
What settings should i have for Vray animation or better yet are should the settings be? im using vray 3.4
Dprince
Postby andybot » Wed Mar 20, 2019 2:24 pm
The settings I would recommend are having a powerful CPU or using a render-farm.
andybot
Premium Member
Premium Member
Postby Pixero » Wed Mar 20, 2019 3:53 pm
Several years ago I rendered a animation with Vray 1.5 on one PC.
I believe rendering took 4-5 weeks 24/7.
I would NOT do it like that again. :lol:
With Enscape I rendered a 4 minutes animation in less than an hour.
Pixero
Postby Dprince » Thu Mar 21, 2019 6:22 am
Pixero wrote:Several years ago I rendered a animation with Vray 1.5 on one PC.
my machine cant run enscape . each time i try it crashes
Dprince
Postby andybot » Thu Mar 21, 2019 2:45 pm
If you're serious about rendering an animation with V-Ray, I would highly recommend looking at render farms, there are quite a few options out there.
andybot
Premium Member
Premium Member
Postby solo » Thu Mar 21, 2019 3:35 pm
You said in a PM you had $1600 to spend on a new laptop, this will get it done:
https://www.amazon.com/Alienware-AW17R5 ... 68-20&th=1
solo
Global Moderator
Postby Dprince » Thu Mar 21, 2019 3:37 pm
andybot wrote:If you're serious about rendering an animation with V-Ray, I would highly recommend looking at render farms, there are quite a few options out there.
Can you send me some examples please? Thanks
Dprince
Postby Dprince » Thu Mar 21, 2019 3:46 pm
I was looking at this also ASUS ROG STRIX Hero Edition Gaming Laptop, https://www.amazon.com/dp/B076D95JW7/re ... KCb2GCA8BM
Dprince
Postby solo » Thu Mar 21, 2019 4:31 pm
Considering you are usimg Vray 3.4 I assume you are not using GPU rendering, so the alienware will have more cores than the ASUS, both will work great for Enscape however
solo
Global Moderator
Postby andybot » Fri Mar 22, 2019 2:43 pm
Dprince wrote:Can you send me some examples please? Thanks
Here's a list from Chaos Group: https://www.chaosgroup.com/render-farms (not all of these have SU+V-Ray support, but if you narrow the list to just SU, it misses farms like Rebus)
And they have their own cloud: https://www.chaosgroup.com/cloud (I haven't used it so I couldn't speak to how it compares.)
andybot
Premium Member
Premium Member
Next
Return to V-Ray
Users browsing this forum: No registered users and 6 guests
