Vray rectangle light does not match in model and in render
General discussion on V-Ray for SketchUp
Postby Flion » Sun Dec 09, 2018 5:55 pm
I'm doing some vray lights analysis to clarify some things for myself. I placed a Vray plane light to a window (on the inside) however in render the position of the plane does not match the placement. Seems that the plane has gone to the left and I can see the black outside (turned off the Sun Light and Environment). What am I doing wrong?
SU 2017 pro
Vray 3.4
Flion
Re: Vray rectangle light does not match in model and in rend
Postby ecati » Mon Dec 10, 2018 9:18 am
The rectangular light and the wall are not in the same plane. With the drawing again, the problem improved.
ecati
Postby Flion » Mon Dec 10, 2018 1:01 pm
Thanks for the reply ecati however I think in my drawing both are on the same plane and positioned exactly the same like in yours. When I redraw it the problem is gone, however I'd like to know the cause of the problem in order not to happen in the future. I scaled the plane using scale tool. Could that be the reason?
Flion
Postby ecati » Mon Dec 10, 2018 2:58 pm
There are differences in the coordinates of rectangular light corners.
ecati
Postby Flion » Tue Dec 11, 2018 10:24 pm
Thanks for pointing that out! However Differences appear to be much smaller, almost negligible than what it appears when rendered. I fixed it but the result seems the same. I wonder if something can be wrong with Vray light plane geometry. Did I do something wrong scaling it? I'd like not to repeat the same thing in complex scenes.
Flion
Postby ecati » Wed Dec 12, 2018 2:21 pm
You need to be careful when drawing. I don't know another solution.
ecati
Return to V-Ray
Users browsing this forum: No registered users and 5 guests
