Paint Creating New Duplicate Material
General discussion on V-Ray for SketchUp
Postby IndexAD » Sat Nov 24, 2018 2:05 am
When I try to apply an existing custom material (already in the model) to an object, it often creates a new unwanted copy of that material.
I have tried multiple approaches (applying to a material-less object, applying to a group or single object, etc.) to no avail. The error also occurs in various models, but always an existing file and not a new model.
The only thing I have found that works is to rename the existing material, then paint the object - which is obviously not an optimum way to work.
Thanks!
MacOS 10.14
SU 2018 Pro (this error has happened in multiple versions)
IndexAD
Re: Paint Creating New Duplicate Material
Postby Dave R » Sat Nov 24, 2018 3:09 am
This is a known bug and the development team has been working on a solution.
I'm not sure if it was addressed in the new release of SU2018 for Mac but if you haven't updated, yet, you should anyhow. The update was released to make changes for Mojave.
Global Moderator
Postby IndexAD » Sun Nov 25, 2018 3:45 am
I've found that it's an issue with V-Ray - most likely in how it manages materials (vs. SU).
I've disabled V-Ray for the time being and things are working fine.
IndexAD
Postby Dave R » Sun Nov 25, 2018 4:01 am
Very good. I would suggest reporting it to the Vray folks. Maybe they should fix it.
Global Moderator
Return to V-Ray
Users browsing this forum: No registered users and 5 guests
