Material ID Shows Up All Black
General discussion on V-Ray for SketchUp
Postby igendreau » Mon Aug 06, 2018 4:43 pm
I'm trying to use Material ID so that I can easily select portions of my rendering for cropping/photoshopping purposes. I'm using VRay 3.6 with Sketchup 18.
Under each material, in Material Options > ID Color, I have a different bright color (blues, purples, yellows, etc...). Under Render Elements, I have Material ID included, along with Denoiser.
But when my render finishes and I select MaterialID from the dropdown menu, that version is just straight black. Am I doing something incorrect? Selecting Denoiser from the dropdown shows the attached just fine, but only black for Material ID.
Any help is much appreciated. Thanks!
igendreau
Re: Material ID Shows Up All Black
Postby valerostudio » Tue Aug 07, 2018 1:23 pm
Are you using GPU rendering? If so, you cant get a MatID with GPU - yet.
If you arent using GPU - try to regenerate the IDS - Extensions-VRay-Tools-RandomizeProjectMaterialIds
valerostudio
Postby TeKnoel » Tue Aug 07, 2018 6:10 pm
You can also set the Material ID color in the material options. Sometimes this field is set to black.
TeKnoel
Return to V-Ray
Users browsing this forum: No registered users and 5 guests
