Vray3.6 displacement problem ... help!
General discussion on V-Ray for SketchUp
Postby cuttingedge » Wed Jan 10, 2018 7:26 am
I have a strange behavior of displacement map in vray 3.6.
I cant make it to work. The material preview shows a good displacement but it doesnt appear in the render.Tried and tried but cant make it work.
Even I tried models done in vray 2.0 which worked but wont work in 3.6.
Anyone having the same issue? below is the displacement map
cuttingedge
Re: Vray3.6 displacement problem ... help!
Postby EpsiOne » Thu Jan 18, 2018 3:14 pm
Same problem for me. Anyone?
EpsiOne
Postby syege » Wed Mar 21, 2018 1:53 am
just found the solution, u gotta apply the material from within the vray material list... u know select your geometry, go to vray asset editor material list select your material, right click apply to selection and BUMP! i mean displacement eheh
6
syege
Postby muthenna75 » Tue Aug 21, 2018 9:56 pm
Hello
I have the same problem with V ray 3.6
muthenna75
Postby valerostudio » Fri Aug 24, 2018 3:45 pm
Use fur for carpets man! - displacement is not worth it. Fur is 1000X faster and better for this application. I try to stay away from displacement altogether honestly.
If you must - like you said above, the material needs to applied directly to the faces (not to the group).
Displacement on the left, fur on the right
valerostudio
Return to V-Ray
Users browsing this forum: No registered users and 5 guests
