Load Error, repeated crash after Vray upgrade
General discussion on V-Ray for SketchUp
Postby brooklynia373 » Wed Dec 27, 2017 7:28 pm
Hi, I upgraded to Vray 3 (and reprogrammed my dongle).
I am using Windows 8.1 and Sketchup Pro 2018.
I repeatedly get the message below and then SU crashes. It is unusable.
This problem is not happening in 2016 and Vray 3 works fine there.
Error Loading File C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb
Error: #<StandardError: Failed to initialize V-Ray>
C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:inrequire’
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/init.rb:1:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:inrequire’
C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:inregister_extension’
C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:26:in <module:VRay>' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/vfs.rb:4:in<top (required)>’
brooklynia373
Re: Load Error, repeated crash after Vray upgrade
Postby 3dstart » Wed Jan 03, 2018 12:01 pm
Just in the plugin folder find su_dynamiccomponents.rb (open it with some ruby editor in the plugin store) and add to the beginning of the code: "UI.start_timer (5, false) {"
and at the end of the code: “}”. It will load DC plugins after all other (5 = seconds, false) plugins, as well as Vray. So the Vray load will be normal and you will be able to use all the benefits of sketchup and vray.
Plugin folder on win: C:\Users\User name\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp\Plugins
3dstart
Postby ark » Fri Jan 05, 2018 12:43 pm
Had the same problem, and tried the above solution.
It works partly - at least Sketchup isn't crashing anymore, but i still get an error message:
Error Loading File su_dynamiccomponents.rb
Error: #<SyntaxError: C:/Users/dbk/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/su_dynamiccomponents.rb:28: syntax error, unexpected ',', expecting ')'
UI.start_timer (5, false){
Any ideas what's wrong? :)
David
ark
Premium Member
Premium Member
Postby brooklynia373 » Fri Jan 05, 2018 2:57 pm
Update: Chaos group sent a custom build for me to try and it worked with all plugins enabled. I assume this will be an updated release soon.
brooklynia373
Postby ark » Fri Jan 12, 2018 11:33 am
Regarding problems with sketchup crashing after installing Vray 3,6 I just received this workaround from Chaos group support:
This error seems to be caused by an incompatibility between V-Ray 3.6.1 and Dynamic Components plugin in SketchUp.
Please try the following:
1. Uninstall V-Ray
2. Open Sketchup and from the drop down menu Window --> Extension manager disable Dynamic Components extension. Then create a scene and save it, it doesn`t matter what it will be, the important part is to make a save.
3. After that close Sketchup, start it again, check in the Extension manager if Dynamic Components is still disabled and close Sketchup again.
4. Install V-Ray and start Sketchup and try to render with V-Ray.
And there will be a sub-release fixing this problem!
David :)
ark
Premium Member
Premium Member
Postby DOg1988 » Thu Nov 21, 2019 1:04 pm
C:/Program Files/Chaos Group/V-Ray/V-Ray for SketchUp/extension/ruby/base_serializer:100:in `update_plugin_from_json' подскажите пожалуйста в чем проблема как исправит ь
DOg1988
Return to V-Ray
