Proxy issue with Vray 3.4
General discussion on V-Ray for SketchUp
Postby jdmd90 » Mon Mar 20, 2017 5:32 pm
Hi everyone!
I've got a big issue with proxy object with vray 3.4
if i import a vrmesh file (for example a tree) i can see in the material editor the different color apparently assigned to the proxy object, but if i try to start a preview render, this one appears completely white, without material or color assigned. even if i add the texture to each color the tree appears always white, without any color o material assigned. if i turn on the material Id channel, the object doesn't appear. so, i think the material are not actually assigned :|
i tried with downloaded proxy and new proxy created by myself. i have always the same problem.
i use SU 2017 and vray 3.4
what can i do??
Thanks!
jdmd90
Re: Proxy issue with Vray 3.4
Postby erik.nord » Thu Mar 23, 2017 9:03 am
This is a huge issue with the new vray 3 for sketchup. Proxies are buggy! Chaosgroup is working on a hotfix, that they promise will be released "shortly".
Chaosgroup send my colleague this temp. workaround:
"In the meantime, as a temporary workaround, simply open the proxy component in edit mode, then select the object and apply the Multi material to it."
I hope Chaosgroup will do an update that will allow you to import proxies made in 3ds directly into SU, and the materials will apply automaticaly as they were in 3ds. But that might be wishfull thinking...
Best regards.
erik.nord
Postby valerostudio » Thu Mar 23, 2017 2:22 pm
I had a similar issue was able to resolve by placing the MultID material directly to the proxy faces of the component.
valerostudio
Postby jdmd90 » Fri Mar 24, 2017 3:33 pm
mmm glad to hear that i'm not the only one. i'll try this temporary method for now, hoping they fix this issue very soon!
thanks!
jdmd90
Postby hazzrael » Mon Mar 27, 2017 7:17 pm
So VRAY WTF with this bug the workflow is totaly compromise and can we speak about linear workflow dont random material ID and wtf with the 2 points perspective in old model from vray 2.0 a lot of bug guys . is not serious .we have to make pics day by day here ... plz fix this
hazzrael
Postby troyhome » Wed Jun 07, 2017 3:12 am
Same issue. Hoping for a fix soon.
IOviz.com
SU Pro 2017 PC
Thea: latest
vray4SU latest
troyhome
Postby jcesarbio » Sun Jun 11, 2017 7:04 pm
Same problem here, didn´t work applying the material to the component. Does anyone knows any other fix?
jcesarbio
Postby dan16198899 » Tue Jul 25, 2017 7:02 pm
This is how I was able to make it work, hope it helps.
Just copy the imported .vrmat settings to the proxy material.
5
dan16198899
Postby gudio83 » Fri May 03, 2019 1:51 pm
Solution:
1. Select laubwerk three proxy in your model.
2. Click on Laubwerk editor
3. Remove materials
4. Import V-ray materials
5. Repeat all steps for all laubwerk proxies.
6. Save SU model
7. Render your scenes.
This work with SU2019, V-ray 4.0.2, Laubwerk player 1.0.29
gudio83
Return to V-Ray
