TexFresnel Explanation?
General discussion on V-Ray for SketchUp [LOCKED]
Postby peter_shaw » Tue Dec 13, 2011 2:13 pm
Hello everyone!
Can someone explain how TexFresnel works? I googled and found this http://www.vray.com/vray_for_sketchup/m ... ayer.shtml but it seems outdated.
I use TexFresnel as reflection map and i know what the IOR does, i even found a list of IOR values for different materials, but what about Refract IOR and the other variables?
peter_shaw
Re: TexFresnel Explanation?
Postby majid » Wed Dec 14, 2011 12:40 pm
please see the attached file
My perspective shortcuts book: https://bit.ly/30Tdbce
majid
Top SketchUcator
Postby peter_shaw » Thu Dec 15, 2011 10:20 am
thanks a lot for the explanation majid! but i can't render your skp file :( the materials list in vray is empty. maybe because we use different vray versions? i have 1.48.89.
but your idea is really good: im just gonna run some tests myself with 20 different cylinders and see how different values behave.
edit: ok, here's the results if anyone is interested. wanted to test more (multiplier by exponent?, texFresnel on refraction map slot?) but got lazy...
fresnel.pdf
peter_shaw
Postby thomthom » Thu Dec 15, 2011 1:20 pm
peter_shaw wrote:i have 1.48.89.
Update to the latest version, currently 1.49.01. Many bugs are fixed since your version. Always check if your software is up to date.
PluginStore Author
PluginStore Author
Postby majid » Thu Dec 15, 2011 2:06 pm
no need to change the IOR for refraction, as there is no refraction in your scene. BTW seems you are now ok by experiencing ;)
my KT tutorial also contains the fresnel explanation...(http://www.sketchupartists.org/tutorial ... materials/)
majid
Top SketchUcator
Postby peter_shaw » Thu Dec 15, 2011 4:51 pm
majid wrote:no need to change the IOR for refraction, as there is no refraction in your scene. BTW seems you are now ok by experiencing ;)
yes thanks again i think experimenting is the best anyways - learning by doing.
peter_shaw
Postby peter_shaw » Thu Dec 15, 2011 4:53 pm
thanks for the heads up. just updated to 1.49.01. wow, didnt think they updated that much in a 0.0012 version jump :D
even the UI is all cleaned up and nice :)
peter_shaw
Return to V-Ray
