V-Ray SketchUp texture question
General discussion on V-Ray for SketchUp
Postby arail1 » Mon May 25, 2009 3:15 pm
A question - can the SketchUp / V-Ray combo handle texture layers? In other words more than one layer like in PhotoShop. I've been operating on the assumption that this isn't something you can do in SK/Vray, that you'd need to have Modo or another program to do this. But maybe I'm wrong?
arail1
Re: V-Ray SketchUp texture question
Postby broomstick » Mon May 25, 2009 3:20 pm
put a blend map in the diffuse slot of the material. Now you have two new maps to put in, but I don't know what happens if you put two different bitmaps..
broomstick
Postby arail1 » Mon May 25, 2009 4:15 pm
I guess that's what I'm asking - can I use two different bitmaps. I'm away for the holiday weekend and I don't have V-Ray on my laptop so I can't do it here to see what happens. If I wanted to add nicks and scratches to a wood surface in a 2D image editing program, I might choose to do it as a separate layer. I'm curious if there's any way to do that in SK/Vray.
TIA
arail1
Postby kwistenbiebel » Mon May 25, 2009 4:55 pm
Yes, using a blend map should work.
In the blend map, you can stack two different bitmaps. Changing the 'ratio' value will give more/less priority to each bitmap.
It should even be possible to put a blend map within a blend map etc...
kwistenbiebel
Postby solo » Mon May 25, 2009 5:01 pm
As true as that may be, it's also limited to ratio blending. In other words what one really needs is to be able to blend accuratly like say you want an aged and distressed wood texture for a table, you could find a texture and map it in SU but that does not look realistic as the wear and tear should be in areas where the table gets used most, it's never even accross the table. So having a way of painting on a second blended texture to certain areas of a model surface would be the best solution.
But this is not the question, I'm off topic.
http://www.solos-art.com
solo
Global Moderator
Postby kwistenbiebel » Mon May 25, 2009 5:14 pm
You're right. Therefore a 'weightmap' could be used.
One could for instance use a 'wear and tear' bitmap and put a black & white 'clipping' image in the transparency slot, so the texture would only be visible in the parts you want.
But indeed, you can't really map that clipping image well with the current SU paint tools, as SU only allows one uv-set per object...
kwistenbiebel
Postby broomstick » Tue May 26, 2009 11:27 am
exactly. This is one thing Artlantis does really well, more so because every change is visual and in real time. I really like Artlantis, when I get to texturing ;)
broomstick
Postby thomthom » Tue May 26, 2009 3:04 pm
You can also add multiple diffuse layers. But you can not put any new diffuse layers over the default one, as that will cause a crash.
PluginStore Author
PluginStore Author
Postby lvl1201 » Mon Jun 08, 2009 7:54 pm
This thing is driving me insane...
I know that in artlantis u can change the material size and angle in a very user friendly way....
What i want to know is HOW do i do that in vray, ive been reading about the inches and the mm in other posts and ive been changing the UVW transform with no good results.... my material gets render in a tiny little size...
the material im using is a .vismat thingie... but ita happens the same even when i do the mat from scratch with bitmaps for diffuse bump etc...
so basically my question is HOW can i resize the material im aplying?
Yes i want to become an Architect.
Yes im pretty close to that.
lvl1201
Postby thomthom » Mon Jun 08, 2009 8:14 pm
Use Sketchup to position and scale your textures. Then what you see is what you get.
PluginStore Author
PluginStore Author
Postby lvl1201 » Mon Jun 08, 2009 9:15 pm
thomthom wrote:Use Sketchup to position and scale your textures. Then what you see is what you get.
Thank you for answearing so fast!!!
but maybe im missing something, it appears to work with a material with only the diffuse bitmap... bump and something else and they stop reacting to the texture position in SU
lvl1201
Postby thomthom » Mon Jun 08, 2009 9:25 pm
All other maps are relative to the diffuse map.
If your diffuse map is mapped to 2000x2000mm in SU, ALL other maps will be this big.
That assumes you have not touched the UV Repeat values in the V-Ray material editor. If you set the bump map UV values to 0.5, 0.5 then the bump map will be 4000x4000mm.
If you do not have any diffuse map in your material, a UV value of 1.0, 1.0 will be 1"x1". You'll have to calculate in relationship to inches to get the size correct then.
But an easer method would be to add a texture in your diffuse map with the colour of what you want the diffuse to be. Then it's easier to set the size and scale.
PluginStore Author
PluginStore Author
Postby arail1 » Mon Jun 08, 2009 10:58 pm
Since beginning this thread I've purchased a license for modo. I never got to try out the Vray suggestions that were so helpfully offered because my trial period came to an end and I had to choose between modo or Vray. Not enough $$$ for both.
I chose modo. modo has what it calls a Shader Tree which is essentially a layering system. You can stack multiple layers on top of one another - displacement maps, bumps, diffuse maps, image maps, noise maps, process maps, etc. to get what you want. I'm just scratching the surface but it's very exciting what it can do in this particular area.
This link is to a thread on the modo gallery forum of someone who modeled some industrial nuts and posted at the bottom a screen grab of his Shader Tree showing the layers.
http://forums.luxology.com/discussion/t ... x?id=35065
arail1
Postby Gaieus » Tue Jun 09, 2009 1:02 am
JimBerton wrote:thanks for showing us your nuts.
:roflmao:
This tree-like solution (and layered materials) is similar to that of Kerkythea however.
Postby arail1 » Tue Jun 09, 2009 2:55 am
My knowledge is limited to AutoCADLT, SketchUp and modo so I'm not at all surprised that some of the features I find unique to modo are not unique at all. I'm a furniture maker and a stair builder. I recently purchased, from a junkyard, a pile of old wood painted signs that were destined to be burned. I'm going to cut them up and make cabinets out of them. I was faced with the question of how to render wildly irregular surfaces - some shiny, some dull, many different colors, different degrees of surface distress, etc. I think modo, especially considering it's Painting feature, might be able to do that for me.
Of course I've spent so much time working my way through modo tutorials I haven't been in the shop in three weeks!
arail1
Return to V-Ray
Users browsing this forum: No registered users and 4 guests
