How to let the light come throught??? Help [V-ray]
General discussion on V-Ray for SketchUp
Postby jcarchitecture » Thu May 14, 2009 6:12 pm
I've got this model with opening. In sketchup, the light comes right throught no problems, and no there isn't any glass in the openings. When I render, none of the shadows on the ground appear. I need help fast because I need to hand this in soon.
Thanks in advance for the help.
jcarchitecture
Re: How to let the light come throught??? Help
Postby solo » Thu May 14, 2009 6:15 pm
In your shadows window select on ground for the shadows.
http://www.solos-art.com
I'm better with polys than words
solo
Global Moderator
Postby thomthom » Thu May 14, 2009 6:31 pm
jcarchitecture wrote:I've got this model with opening. In sketchup, the light comes right throught no problems, and no there isn't any glass in the openings. When I render, none of the shadows on the ground appear. I need help fast because I need to hand this in soon.
In V-Ray you need to place a ground plane first. What you see in SU isn't what V-Ray will render. If you want V-Ray to render the "Ground" shadows you can place an V-Ray Infinite plane.
btw, what VfSU version do you use?
PluginStore Author
PluginStore Author
Postby solo » Thu May 14, 2009 6:35 pm
Never noticed the 'render' reference, TT is quite right as far as vray goes.
solo
Global Moderator
Postby jcarchitecture » Thu May 14, 2009 7:32 pm
I'm using sketchup 7 with V-ray for sketchup 7. I still can't seem to be able to make the light come through and hit the floor.
jcarchitecture
Postby thomthom » Thu May 14, 2009 7:34 pm
Can you post screenshot of your SU scene and your render?
PluginStore Author
PluginStore Author
Postby thomthom » Thu May 14, 2009 7:35 pm
Do you have the Sky map assigned to the GI and Background slots in the Environment section?
As of SR1.5 the V-Ray Sun/Sky is not on by default.
PluginStore Author
PluginStore Author
Postby jcarchitecture » Fri May 15, 2009 12:28 am
I putt a light in the sky which gives shadow in the building, so that is solved. Now i need to knwo how to soften the shadow thats hitting the floor.
jcarchitecture
Postby thomthom » Fri May 15, 2009 7:23 am
Did you use an Omni light? If so; then you can set the Radius in the light's properties.
Though, a Sky map is easier to control IMO.
PluginStore Author
PluginStore Author
Re: How to let the light come throught??? Help [V-ray]
Postby ScottPara » Fri May 15, 2009 6:48 pm
Like Tom said a screenshot or a posting of the model will help alot when people commenting on your problems.
Scott
Love the fact that some HATE my avatar.....
ScottPara
Postby dalomar » Tue May 19, 2009 6:44 pm
Controlling the softness of the shadows of the sun can be done through the Sun Size parameter. You'd get to that through your sky settings in the Environment rollout
Damien Alomar
Product Manager | V-Ray for SketchUp/Rhino
ASGvis
dalomar
Return to V-Ray
Users browsing this forum: No registered users and 4 guests
