VRAY DR Rendering Background Problem
General discussion on V-Ray for SketchUp
Postby rherman » Thu May 07, 2009 3:39 pm
I am using the latest Sketchup and VRAY 1.5.30
I seem to have artifact problems (black squares) when I have any type of background selected (M), this includes SKY w/ default settings and w/ Sketchup settings; also background images, etc.
VRay forums are down but I was wondering if anyone has found a solution? The one solution I found was... if I select just a color and having the m on None, the problem is fixed.
Thank You!
rherman
Re: VRAY DR Rendering Background Problem
Postby dalomar » Thu May 07, 2009 6:29 pm
Two questions...first, are the spawners from the same version as VfSU that you're using, or were they installed from a previous version? Unless the spawners are from the same version as VfSU there's a strong chance that this is at the heart of the issue. There isn't a way to check the version of the spawners at the moment, so you'll have to reinstall them from the 1.05.30 installer.
Second, have you set up asset collection correctly? The spawners need access to all the images that you're using in your scene, so they need to get distributed one way or another. By default its setup to send everything to a node, but there's also the option to read from shared folder. If you've changed that or disabled asset collection altogether, that may be at the heart of the issue.
Damien Alomar
Product Manager | V-Ray for SketchUp/Rhino
ASGvis
dalomar
Postby rherman » Thu May 07, 2009 6:39 pm
I have done both, I have a shared folder which all the materials are placed by V-Ray. But even so, Sky material is not a material, it is a setting, I had previously installed an older version but reinstalled with the same version I'm running. I will try try try again!
rherman
Return to V-Ray
