Componentes dinsmicos para carpinteros
• Page 1 of 1
Componentes dinsmicos para carpinterosNo se si alguien pueda darme una idea de como hacer lo que esta en el video mil gracias Re: Componentes dinsmicos para carpinteroscan not see anything on the video, can you upload link to you tube?
Re: Componentes dinsmicos para carpinterosThere are two ways to create this, one is to use parts and hide the common edges and faces, the other is to use cutting components
In this case its parts and hidden faces/edges as shown @ 2.04 on video you can see the outline of the end face/component when the offset is matched to the thickness with a given back thickness, When you create such. I recommend you use solids then can outer-shell the subs to create a whole (retaining the parent for data and ability to reinstate with swap with its definition) cutting components work if the edges are hidden (outlines can be added as dynamic groups or components) Either way, it involves making sub components or (I prefer) groups to suit your purpose Re: Componentes dinsmicos para carpinterosOk, muchas gracias por la informacion, voy a intertar hacer lo que me dices y estare informando los resultados
• Page 1 of 1
