Hi all.
I know this might be asking a bit much, but I was wondering if you could use OnClick animateslow or animatecustom to make a plumb-bob swing like a plumb-bob (on all 3 axis) until it stops swinging like it would in reality.
I've attached a basic test plumb-bob model, if anyone wants to download & play with it. I know I can make it swing back & forth on different axis at different times & can get it to position itself on different axis but not sure how to make it swing through multiple axis at the same time, say in a spiral back to plumb like it would in reality. I had a few goes but it ended up kind of doing my head in a bit. I think I need a fresh outlook on it. So I thought I'd share to see if anyone else has some spare time & save me from going crazy like a coconut...that boy needs help.
https://youtu.be/pajL2jFFX2Q
I've included a plate at the top of the plumb-bob string to help in orientating it at a few angles etc. I also saved as a SU2018 version & can save as earlier if needed.
Cheers.
OnClick swinging Plumb-bob
• Page 1 of 1
Re: OnClick swinging Plumb-bobThis is probably something more suited to Physics extensions?
Re: OnClick swinging Plumb-bobUnfortunately non of the physics extensions are compatible with SU 2019.
Sounds like another good reason to switch to Blender;-)https://sketchucation.com/forums/viewtopic.php?f=179&t=69981
• Page 1 of 1
