New to DC: topic for my simple questions to the pros
Re: New to DC: topic for my simple questions to the pros
Postby pcmoor » Sat Mar 27, 2021 5:03 am
you could use the summary to display the data as the "component info" section is not affected.
I suggest you consider using some ruby scripts with your DCs to help with placement, multiple changes....
pcmoor
Postby pibuz » Wed May 19, 2021 9:01 am
Hi all!
Sorry to ask for help again: I'm trying to figure out the simplest way to round a result of a formula to the closest upper value of a list with non constant intervals (e.g. 20,70,180,500)
Do you have any hints for me?
Thanks in advance as usual!
pibuz
Postby pcmoor » Thu May 20, 2021 12:44 am
nearest
then test if input > nearest
if so find the next value
example 1: use a string of values and string functions to get the next
pcmoor
Postby pibuz » Fri May 21, 2021 7:30 am
I was almost there :lol: thanks a lot Phil!
pibuz
Postby pibuz » Fri Jun 25, 2021 8:52 am
Hi! is there a way to select all locked components? a plugin or a one-line snippet maybe?
Thanks in advance!
pibuz
Postby pibuz » Thu Oct 14, 2021 9:35 am
Hi again! I have a new question for Phil :roflmao:
I have a formula which returns a text string which may contain LUCIDO, SEMILUCIDO or OPACO.
I want another attribute to substitute in that exact string the words LUCIDO, SEMILUCIDO or OPACO with GL100, GL60 or GL25 respectively. Is there a way to do that?
Thanks in advance!
pibuz
Postby pcmoor » Sat Oct 16, 2021 10:02 am
Hi Filippo
can use nested SUBSTITUTE
order is important
example attached
pcmoor
Postby pibuz » Mon Oct 18, 2021 8:14 am
So cool! Thanks a lot, I couldn't have made it by myself. :mrgreen:
pibuz
Postby pibuz » Thu Nov 11, 2021 11:58 am
Hi again! This is slightly OffTopic but it seems I can't find out a plugin I once saw.
Say we have a DC ("wall") in a model, then we copy it 2 more times and make 3 variations in total, which will be called "wall", "wall#1" and "wall#2". Say we later delete the wall#1 instance, so we have "wall" and "wall#2".
This plugin checks the numbered instances of "wall", and renames the "wall#2" instance to "wall#1" (since "wall#1" is available again after the deletion).
Con any of you guys recall what was the name of this plugin?
Thanks in advance!
pibuz
Postby pcmoor » Sat Nov 13, 2021 12:47 pm
Eneroth Decrease Component Number on extension warehouse
pcmoor
Postby pibuz » Sat Nov 13, 2021 3:25 pm
Wonderful!!! THANKS Phil!
pibuz
Postby pibuz » Wed Jan 12, 2022 3:41 pm
Hi again! Happy new year!
I have the need to bulk export the thumbnails of the selected components, I fiddled around in the forums and I discovered this small but effective Ruby code:
mod = Sketchup.active_model # Open model
sel = mod.selection # Current selection
path = mod.path #current path
mypath= File.join(File.dirname(path),'/') #not the model name
sel.each do |sel| # you would have to select all components in the model
compname = sel.name # each component's definition name
thumbnailname = File.join(mypath, compname + '.jpg') # as jpg
sel.definition.save_thumbnail thumbnailname
The only issue is that this plugin doesn't work if i have the character "|" in the component instance name. Is there a way to allow the character in the "allowed" characters? Thanks in advance!
pibuz
Postby pibuz » Thu Feb 17, 2022 7:41 am
Hi again! Is there a way, even a small oneliner ruby code, to get a dimension in SKP (Not layout) with NO leaders at all? No lines, only the number.
Thanks in advance!
pibuz
Previous
Return to Dynamic Components
Users browsing this forum: No registered users and 6 guests
