Whats wrong with this DC?
Postby Pixero » Mon Jun 11, 2018 12:52 pm
I've been trying to make a simple DC that copies a 2d rectangle along one axis.
Something isn't working and when changing a value or dragging the scale handles the DC disappears.
Also, the scale handles in the Z direction isn't visible.
Could someone take a look what I have messed up, please?
DC_Raster_2D.skp
Pixero
Re: Whats wrong with this DC?
Postby pcmoor » Tue Jun 12, 2018 4:12 am
a bit of a challenge, then discovered thickness of the DC is zero (2D?) whereas lenY for the picket was given a value of 1cm, decided to push pull some volume and it fixed it. Set it to 0, but option to change. Had to add the Y scale as well as at thickness=0, the z scale was hidden (another DC bug)
Cheers
pcmoor
Postby Pixero » Tue Jun 12, 2018 7:00 am
Thanks.
So do I understand you correct that 2d components won't work in a DC?
The whole Idea was to quickly create an array of 2d rectangles that I can cut with the 2D boolean script to match the shape of, for example, a facade.
So having it 2D is a must.
Pixero
Postby pcmoor » Tue Jun 12, 2018 9:51 am
2D will work, but an error on the original seems unfixable, other than making it 3D
So redoing with just 2D elements with no use of lenY works okay
pcmoor
Postby Pixero » Tue Jun 12, 2018 10:15 am
Thanks!
Pixero
Return to Dynamic Components
