How To Interpret a Text as a DC Formula  Topic is solved
Postby SketchUcationKid » Mon Feb 06, 2017 1:15 am
hi everybody!
the X axis value of my DC normally comes from a function because of the auto resize. the problem happens when I change the X axis value through the ANIMATE function on the INTERACT mode. it toggles between 0.3cm and 0.85cm values. when I click on the DC, SketchUp overwrites the value passed by the ANIMATE function on the function previously saved on the X axis field.
from that time on, the DC doesn't resize properly because there's no more formula in the field but a value instead.
in order to avoid this, I created a custom variable called pos_X in order to receive the formula that should be saved in the X axis field. pos_X is in a text format but X axis field only accepts number format.
I need to know how to interpret this formula in text format and send the value in number format to the X axis field.
many thanks.
SketchUcationKid
Re: How To Interpret a Text as a DC Formula
Postby Jim » Mon Feb 06, 2017 10:10 am
Hard to say without seeing the model, or the formulas. Here's a suggestion:
Use onClick to animate some attribute, in this case "movement":
onCLick: animate("movement", 0, 5)
The quotes are important.
It prevents a bug if your animation values are negative,
so just get in the habit of using them with the animate function.
Then base the X formula on the attribute:
X: =movement
The equals sign is important. It gets you the value of the attribute.
Jim
Global Moderator
Postby SketchUcationKid » Mon Feb 06, 2017 3:43 pm
@Jim. first of all, thanks for the reply.
I will try to be straight in my explanation:
When opening SketchUp:
  • DC parent name: Cabinet
  • DC child name: Door
  • custom variable name: door_gap
  • door_gap value: =0.3
  • custom variable name: door_thickness
  • door_thickness value: =1.5
  • X axis value: =Cabinet!X+Door!door_gap
  • RotZ value: 0
OnClick Event:
  • ANIMATE("RotZ",0,-90);
  • ANIMATE("X",Cabinet!X+Door!door_gap,Cabinet!X+Door!door_gap+door_thickness)
PS: the first animation works fine, as the second one. the problem happens when the second animation runs and change the X axis value, which was previously set to "=Cabinet!X+Door!door_gap". now it toggles between two numeric values (as result the two formulas).
when I finish the INTERACT mode and resize the cabinet, now, it doesn't resize properly because X axis value is not a formula anymore but a numeric value.
as a try to overcome this situation, I created another custom variable called "pos_X" (text type) and changed OnClick code, as follows:
  • SET("pos_X",IF("RotZ=0","=Cabinet!X+Door!door_gap","=Cabinet!X+Door!door_gap+door_thickness"))
PS: pos_X receives the right formula in text format. now, I need to know how to interpret this formula and send the value to X axis, in numeric format.
any idea?
SketchUcationKid
Postby TIG » Mon Feb 06, 2017 4:32 pm
You are trying to set the built-in RotZ directly.
In Jim's example he set a variable, which was then used to set one of the built-in variables...
So try:
ANIMATE("myRotZ", 0, -90)
Then use that layer, with:
RotZ =myRotZ
etc...
Global Moderator
Postby SketchUcationKid » Mon Feb 06, 2017 4:59 pm
@TIG. the problem doesn't have to do with RotZ setting but with X axis setting. when I change its value (through ANIMATE function), it loses the formula previously saved.
thanks.
SketchUcationKid
Postby Jim » Mon Feb 06, 2017 10:26 pm
It sounds as if you could simplify the functions by using a better placed axis of rotation. Can you share the model?
Jim
Global Moderator
Postby SketchUcationKid » Mon Feb 06, 2017 11:36 pm
yes @Jim. for sure.
activate the INTERACT mode, open and close the cabinet door and see what happens to the door.
SketchUcationKid
Postby Jim » Tue Feb 07, 2017 12:02 am
Are you really using SketchUp 7 as it says on yout profile?
Jim
Global Moderator
Re: How To Interpret a Text as a DC Formula  Topic is solved
Postby Jim » Tue Feb 07, 2017 12:07 am
Anyhow, the point I and TIG are trying to make is that you can have a single animation attribute, but can use that attribute in any of the position and rotation attributes to obtain simultaneous animations.
Quick example: This would animate 90 degress around the Z axis, while at the same time moving along the X axis from 1 to 3. Does that help?
Jim
Global Moderator
Postby SketchUcationKid » Tue Feb 07, 2017 1:00 am
I'm using SketchUp 8.011752
SketchUcationKid
Postby SketchUcationKid » Tue Feb 07, 2017 1:54 am
@Jim and @TIG. I understood the changes you did but I'll come back to the same problem: X axis will lose the formula =Cabinet!X+Door!door_gap, useful for the dynamic resize. I want to kill 2 birds with one stone: I want to have a dynamic resize along with open/close door animation.
you might have noticed that when I rotate the door right after I have to move back the door in the X coordinate, otherwise, the door will be touching the other door of the beside cabinet, when both are open.
when opening/closing the door, X axis receives numeric values, losing the formula. when resizing the cabinet, X axis should have the formula back, in order to do the resize properly.
thanks.
SketchUcationKid
Postby SketchUcationKid » Tue Feb 07, 2017 2:30 am
but you both gave me a very good idea that might be the solution and I'll try it right after the coffee. I will write the formula Cabinet!X + anim in the X axis field. the custom variable anim will receive the numeric value coming from one of the two formulas written in the ANIMATE function.
ANIMATE function in turn will have the two formulas: Door!door_gap and Door!door_gap+MDF_thickness, for instance.
what do you think?
SketchUcationKid
Postby SketchUcationKid » Tue Feb 07, 2017 4:16 am
hi guys,
the problem with the resize and cabinet door opening/closing was solved thanks to you guys, specially to @Jim and @TIG who gave me a brilliant idea.
I'll let available the project for whoever wants to make use of it.
THANKS!!!
SketchUcationKid
Postby Jim » Tue Feb 07, 2017 9:30 am
Here is what I mean.
The "anim" attribute moves smoothly between 0 and 1. We use the basic math properties that
Code: Select all
0 × N == 0
1 × N == N
where N is any number.
So then for any translation or rotation or scale the formula is:
Code: Select all
start_position + anim * travel_distance
or for a rotation:
Code: Select all
start_angle + anim * travel_angle
Think in terms of start position and travel amount. When "anim" is 0 you get the start position. When "anim" reaches 1 you get the start_position + travel_amount.
The main advantage of all this is that you can use the "anim" attribute in any of the position, rotation, or size attributes to get multiple, simultaneous animations. Plus it actually simplifies the formulas once you get your head around it. You can also use the "anim" attribute to drive animations in other components in your DC.
Perhaps the 2nd image will help clarify.
Jim
Global Moderator
Postby SketchUcationKid » Thu Feb 09, 2017 12:06 am
that's right @Jim. you are an expert! now I'm uploading the final version of the cabinet project, with 2 doors working, as it really should be.
thanks.
SketchUcationKid
Return to Dynamic Components
