Component controls in upper component
Postby AijAij » Thu Nov 24, 2016 3:21 pm
Hallo,
In attached drawing I have created a ship's crane.
Basically the crane consist of 3 main components , each inside eachother.
Component 1 - Crane Complete. This entire component consists comp. 2 and 3 and is able to rotate all over the Zaxis.
Component 2 - Boom. This component is inside comp.1 and is able to rotate over the Yaxis together with component 3.
Component 3 - Hook. This component is inside comp.2 and is able to move up/down by Zaxis.
Comp 2 and 3 are linked to each other is such a way that the Block(comp 3) always stays under the end of the Boom(comp 2).
So far so good after quiet some brainwaves.
If I click in component 1, I can only use its own dynamic options. (The options of comp 2 and 3 are not visible).
The reach component 2 dynamic options, I have to go deeper inside comp. 1 to reach comp. 2 and same for comp 3 to go even 1 step deeper.
I would like to see all dynamic options in 1 window at first click on component 1.
Can't figure out how without messing up movements.
Very important is that when rotating comp1 , comp.2 and 3 move along.
AijAij
Re: Component controls in upper component
Postby AijAij » Thu Nov 24, 2016 8:37 pm
I gave up too quick. Found the solution
Close topic
AijAij
Return to Dynamic Components
cron
Users browsing this forum: No registered users and 5 guests
