nested dynamic components
Postby newnoob » Sun May 01, 2016 8:00 pm
Hi Sketchucation, it's been a while since I've been here the last time.
Today I started using dynamic components because this seemed usefull to me for my purposes but soon I experienced some problems.
Basically I like to do something like pulling out a drawer out of a drawer out of a drawer with the interact tool.
Do I have to nest in this example the 3rd drawer component in the 2nd drawer component and the 2nd drawer component in the 1st?
But then I have to acess first each sub component to be able to apply the interact tool which is unpracticall.
Is there an other way? Is there some video which could helpe me - I have not found one.
Actually I don't want to pull drawers out of drawers. I would like to do what you see on the picture.
The numbers represent a sequence of states. Think of it as a sort of shower door which step by step builds up a shover room. I want to do each step by using dynamic componants and the interact tool.
newnoob
Premium Member
Premium Member
Re: nested dynamic components
Postby JQL » Mon May 02, 2016 9:59 am
You have to write something like this:
Onclick=Animateslow("Drawer",0,1,2,3)
This will animate a Custom Variable called drawer: It will start at 0, then animate to 1, then 2 and finally 3 where another click will animate from 3 to 1.
Then there will be many ways to make that Custom variable "Drawer" be inserted in your formulas to make your drawers animate one at a time.
JQL
Premium Member
Premium Member
Postby newnoob » Mon May 02, 2016 3:33 pm
Thank you for your answer.
As I understand it your suggestion is only working for a single component.
I am a big noob in math and programming. But I think Onclick=Animateslow("Drawer",0,1,2,3) only applies for a single component.
At least I understand how I can controle the behaviour of a single componant with Onclick=Animateslow("Drawer",0,1,2,3).
But my problem is that I have two components which should move ( do something)together (at certain steps) at the same time.
newnoob
Premium Member
Premium Member
Postby Garry K » Mon May 02, 2016 4:20 pm
JQL is correct.
For example I have bifold doors that open and close. There is 1 click event for each bifold pair. The click event is performed on 1 bifold panel. The other panel moves in conjunction with the control panel.
These doors are created from scratch using Ruby.
Garry K
Premium Member
Premium Member
Postby JQL » Mon May 02, 2016 4:36 pm
The idea is that you can inherit the "Drawer" attribute from nested component into the next.
When the onclick function is in the 3 stage, the something happens in a context that has inherited that attribute.
JQL
Premium Member
Premium Member
Postby newnoob » Mon May 02, 2016 8:15 pm
Well,ääääähhhhh??!
But isn't there a fancy mathematical formula (picture)for component 2 in need, to change position in conjunction with component 1?
Component 1 is just simply moving around axis z between 0° and 85° - which is relatively simple. I can understand that.
But to make component 2 to move in the specif intended conjunction with component 1 there is this mathematical formula needed(something trigonometric)
I wish I'd be less tupid. :fro: Thanks for handling me. :)
newnoob
Premium Member
Premium Member
Postby JQL » Mon May 02, 2016 9:20 pm
There is a formula for that wich envolves trigonometry but if you simply want to do that you can nest component 2 inside component one and it becomes much easier. Place the component's axis where you want your hinges to be... Then explore a bit and ask again if you need.
JQL
Premium Member
Premium Member
Postby Garry K » Mon May 02, 2016 9:39 pm
You might ask why so many nested levels. The right hand pair of bifolds are a copy (mirrored) of the left hand pair. The axis for the left most panel is the pivot point. So I made sure that it was in the center of the panel (thickness wise) and a couple of inches over from the end. That way the bifold pretty much acts like a real one. The other reason you need to nest at least 1 additional level is so the math survives moving and rotating the entire bifold.
Essentially the nest level that contains the formula isn't affected when I move and rotate the entire door assembly into position.
Garry K
Premium Member
Premium Member
Postby newnoob » Mon May 02, 2016 10:49 pm
JQL wrote:... component's axis where you want your hinges to be
Garry K wrote:the axis for the left most panel is the pivot point
Aahh! That's the thing. I did not set the axis.
(After some playing with the axis I also figured -angle values regarding axis rotations are clockwise and + angle values are counterclockwise.)
However to have to open each component, in order to "manually" control the whole motion sequence step by step is not as "sexy" as to use some sophisticated equation to do the whole job at once.
Thanks guys!
newnoob
Premium Member
Premium Member
Postby newnoob » Tue May 03, 2016 12:22 pm
I still have problems after setting the axes which I can not explain myself.
I've created a mother component in which I've nested two sub components of the same shape.
The mother component can rotate between -90° and 0. One of the nested components can also rotate (around it's own set axis) between -90° and 0
As long as I do not rotate the mother component the nested component just does what is should do which is rotating between 0° and -90°.
But the problem starts as soon as I have rotated the mother component to -90°. When the mother component is rotated at -90° the nested component is behaving strangly. Instead of rotating to -90° and 0° it is sort of jumping to -90° and then bouncing fast back.
I don't have a clue.
newnoob
Premium Member
Premium Member
Postby JQL » Tue May 03, 2016 12:47 pm
Here it is:
JQL grey and white Folding door DC.skp
JQL
Premium Member
Premium Member
Postby Garry K » Tue May 03, 2016 12:57 pm
JQL
If you copy, paste and rotate this DC and then use interact then it bounces back to the same plane as the original.
You need to nest it one level deeper.
Garry K
Premium Member
Premium Member
Postby JQL » Tue May 03, 2016 1:08 pm
Thanks Garry!
I know that but I thought I was giving away too much in one time and this doesn't help learning. I was hoping that issue could be something asked later by anyone interested or even better, the issue could be solved alone.
A step at a time, each step requiring the next...
There are even more issues there waiting to be found.
JQL
Premium Member
Premium Member
Postby newnoob » Tue May 03, 2016 5:50 pm
Thanks for the help JQL! I really appreciat it. (unfortunately I can't open your file with my SU Pro 2014) However I understand nuts.
I have already a problem to understand what it means when you use symbols like ! and * in
=Mother!Rotation*-90
or
RotZ = Rotation*90
A principial logical problem which I have is that in my understanding the white component is only moving around axis z but the grey component is moving around axis z AND is sliding at the same time on axis x.
But there is nowhere something refering to - change position on axis x - for the grey component. There is only RotZ = other!Rotation*-90 - It does not seem reasonable to me that this is enough when the grey component is ALSO MOVING on axis x.
newnoob
Premium Member
Premium Member
Postby Garry K » Tue May 03, 2016 7:14 pm
Have you gone through this
https://help.sketchup.com/en/article/115544
Notice the axis:
And here is the formula. Think of it this way
The top most component (Mother) gets rotated 90 which rotates both the grey and the white panels.
Then rotate the gray one -180
Garry K
Premium Member
Premium Member
Postby Garry K » Tue May 03, 2016 7:19 pm
Mother!Rotation refers to Rotation variable in Mother (should be named state)
On Click sets Mother!Rotation to either 0 or 1
RotZ formula Rotation*90 will be 0 when the state is 0 or 90 when the state is 1
RotZ in grey panel also references the variable Mother!Rotation and therefore it's value is either 0 or -180
Pretty simple actually
Garry K
Premium Member
Premium Member
Postby JQL » Tue May 03, 2016 7:22 pm
As Garry says, you have to learn the basics first.
Mother!Rotation is the "Rotation" attribute defined in "Mother" component. The idea is that you can reference attributes that exist in parent components or components nested in the same level.
When you want to do that, you simply click on the attribute you want to use, from the ones being shown:
1 - Edit the formula for RotZ inside the grey component;
2 - Start by typing "=";
3 - Then click on Mother's "Rotation" attribute;
4 - And sketchup will autocomplete "Mother!Rotation" inside the formula.
JQL
Premium Member
Premium Member
Postby JQL » Tue May 03, 2016 7:26 pm
Garry, I'm know about your plugins but I'm not familiar with them as I never tested them...
When you say that you're creating your DC's from ruby, are you creating them from scratch from there or are you picking up some existing component template and filling it with stuff using ruby?
JQL
Premium Member
Premium Member
Postby Garry K » Tue May 03, 2016 8:11 pm
It is all Ruby (except for door handles).
I have web dialogs for parameters. Cab Maker for instance has 8 tabs and around 240 graphics which change for each parameter. Lots of enabling / disabling of parameters depending upon what you select. Choose a library template (just a small text file) and I go read in the data and update the web dialog.
I think it is a much better work flow and the resulting skp is kept down in size. This way you can have 100's of choices for textures but I only load in the ones you want to use. This also means that most of the parameters are virtually infinitely sizeable and can be combined many many ways.
The only place that I use dynamic attributes is for doors opening / closing and drawers opening / closing.
Garry K
Premium Member
Premium Member
Postby JQL » Tue May 03, 2016 8:27 pm
That's really cool Garry! I'm amazed at what you achieved there. And it seems you have the same thing for doors and windows?
JQL
Premium Member
Premium Member
Postby Garry K » Tue May 03, 2016 8:59 pm
Yes for doors, I'm working on windows and on a wall maker.
As you probably guessed - that bifold came out of my door maker.
Garry K
Premium Member
Premium Member
Postby JQL » Tue May 03, 2016 10:14 pm
That sort of thing interests me a lot more than cabinets.
You're talking about walls doors and windows all in the same plugin?
JQL
Premium Member
Premium Member
Postby newnoob » Tue May 03, 2016 11:42 pm
Garry and JQL thank you for your extensive answers. I'll process them tomorrow.
Thanks to the explanation:
it makes now perfectly sense to me.
newnoob
Premium Member
Premium Member
Postby Garry K » Wed May 04, 2016 12:16 am
JQL
3 separate plugins.
Garry K
Premium Member
Premium Member
Postby juju » Wed May 04, 2016 8:28 am
Garry K wrote:JQL
3 separate plugins.
How's the window plugin coming along Garry?
juju
Premium Member
Premium Member
Postby newnoob » Wed May 04, 2016 6:40 pm
@ JQL
I've just checked out your fb-gallery and I like your attic renewal, the material choice and integration of old stuff which was already at the attic before the renewal gives it a warm and cosy feeling. I also like pure minimalistic designs where warm wood tones are mixed with grey concrete tones, like your office, this is like wood and stone. This in combination with some plant green always works for me. Furthermore I like the tiny garden. I am interested in the utilisation of small spaces, like micro houses, micro homes, capsule hotels.
newnoob
Premium Member
Premium Member
Postby Garry K » Wed May 04, 2016 7:26 pm
juju
I haven't got very far with the window plugin. I have been concentrating on a wall plugin - then I'll go back to the window plugin.
Garry K
Premium Member
Premium Member
Postby newnoob » Fri May 06, 2016 11:58 am
Ok, I think I got it. I had a problem to understand what relates to what.
Which purpose has:
Custom
Rotation 0
The sole purpose of it is to display if the the state of onclick is set to 0 or 1 - is it?
newnoob
Premium Member
Premium Member
Postby JQL » Fri May 06, 2016 12:36 pm
newnoob wrote:@ JQL
Thanks newnoob...
We are working on a new site and we have some new projects on that line, so keep in touch!
JQL
Premium Member
Premium Member
Postby Garry K » Sat May 07, 2016 10:40 pm
Yes
The Mother component has an new variable that you add called Rotation.
Rotation starts out = 0
Click once and Rotation goes to 1
Click again and Rotation goes to 0
In a situation where you want more than 2 states - separate them by commas.
So for a 4 state variable where you might open and close the door in increments.
ANIMATESLOW("some variable", 0, 1, 2, 3)
Garry K
Premium Member
Premium Member
Next
Return to Dynamic Components
Users browsing this forum: No registered users and 4 guests
