Facearea() problem  Topic is solved
Facearea() problem
Postby totesz » Tue Jan 12, 2016 7:14 pm
I am new in DC, but for my work need Facearea()function to count area.
When I scale any DC object, after redraw the area not changed.
Area changed only if I do it in object edit mode with Push/Pull tool.
totesz
Re: Facearea() problem  Topic is solved
Postby pcmoor » Tue Jan 19, 2016 2:28 am
you will notice whenever you scale a object its material stretches, so the area calculation remains the same, just what you see is a stretch representation of the same area
so make the component unique, so it does not effect others using the same definition, after scale or changes, right click choose scale definition, and right click dynamic component redraw may also be required.
I hope to later create a set of ruby script tools to overcome some of these issues
pcmoor
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Dynamic Components
Who is online
Visit our sponsors:
