Adding group to existing entities
Postby vimleshpatel » Thu May 07, 2015 12:30 pm
I tried to create a box and add it to the cabinet like:
Code: Select all
entities = []
entities<< create_left_panel
entities<< create_right_panel
entities<< create_front_panel
entities<< create_back_panel
entities<< create_bottom_panel
group = Sketchup.active_model.entities.add_group(entities) # here entities is array of entity(back, front side etc)
box = group.to_component
comp = cabinet.definition.entities.add_instance box.definition, transform
#cabinet is an ComponentInstance object.
box.erase! #If I'm not deleting this entity then 3 copies will be there.
But here I'm getting two copies for every entity in the group.
1. as a group of component inside a instance i.e box as ComponentInstance.[/list]
2. as all separate ComponentInstance object for every entity in group.[/list]
So, while moving any of the ungrouped entities the entity inside the box object is also moving. and if I tried to delete the ungrouped entity then Sketchup itself crashed.
I need some short of code that can add a group of entities into another entities [ComponentInstance.definition] group, without making another copy of it or the other copy should be deleted without crashing the Sketchup.
vimleshpatel
Re: Adding group to existing entities
Postby sdmitch » Thu May 07, 2015 2:40 pm
I think the problem is that you create the various panels in a method, probably as a group then you copy them into another group thus duplicating them.
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby TIG » Thu May 07, 2015 9:45 pm
You only give us half of the story ! :roll:
Presumably each of your methods 'create...' returns a valid 'entity'.
These must be in the model.active_entities context for the add_group(...) to work...
You somehow magic a 'transform' - in the add_instance(...) what is that ?
In principle the limited code you show us ought to work...
But of course you can easy screw it up in the parts you haven't shewn...
:shock:
Global Moderator
Postby vimleshpatel » Fri May 08, 2015 6:50 am
Here I'm copying the related method I used to create panel's
Code: Select all
#This method will return a panel as ComponentInstance
#RectangleBox is another class which will create a panel using 2 diagonal points, thickness
def create_box
   entities = []
   rotate_panel box, [0,0,0], X_AXIS, 270
   add_box_in_cabinet(box)
def add_box_in_cabinet box
   selection = Sketchup.active_model.selection
   if selection.count!=3
     UI.messagebox("Please select 3 panels and try again!")
     return
   h_panel=nil
   v_panels=[]
   selection.each{|panel|
     if panel.name == "HShelf"
       h_panel = panel
     else
       v_panels << panel
   definition = h_panel.parent
   parent_component = definition.instances[0]
   points = get_box_position_in_cabinet box
   if !points
     puts "Points are not valid"
     return
   trans_move = Geom::Transformation.translation points
   component = parent_component.definition.entities.add_instance box.definition, trans_move
   box.erase!
def get_box_position_in_cabinet h_panel, v_panels
   points = []
   dict1 = nil
   if v_panels.length == 2
     vdict1 = SketchupInfo.rootDictionary v_panels[0]
     vdict2 = SketchupInfo.rootDictionary v_panels[1]
     x1 = vdict1['x'].to_l.inch
     x2 = vdict2['x'].to_l.inch
     panel1= nil
     if x1 > x2
       points.push((x2+18).mm)
     else
       points.push((x1+18).mm)
   dict = SketchupInfo.rootDictionary h_panel
   points.push(dict['y'].to_l.inch)
   points.push(dict['z'].to_l.inch)
   if !points
     return false
   points
def create_panel pts, thickness
    ply_type ="PLY"
    info = Hash.new
    info[DESCRIPTION] = BACK
    b = RectangleBox.new(pts[0], pts[1], thickness)
    component = b.draw
def rotate_panel component, points, axis, angle
    trans_rotate = Geom::Transformation.rotation points, axis, angle.degrees
    component.transform! trans_rotate
def translate_panel component, points
    component.transform! trans_move
def create_left_panel
   panel = create_panel @left, @thickness
   rotate_panel panel, [0,0,0], Y_AXIS, 90
   points =[...] #Position for panel to fit
   translate_panel panel, points
   panel
def create_right_panel
   panel = create_panel @right, @thickness
   rotate_panel panel, [0,0,0], Y_AXIS, 270
   panel
def create_front_panel
   panel = create_panel @front, @thickness
   rotate_panel panel, [0,0,0], Y_AXIS, 180
   panel
def create_back_panel
   panel = create_panel @back, @thickness
   panel
def create_bottom_panel
   panel = create_panel @bottom, @thickness
   panel
Other than these methods I'm setting some value in the dictionary like x,y,z, lenx, leny etc.
One more thing that I observed is: If I'm not creating box in cabinet, then only one copy is created. but If I'm selecting panels in the cabinet and tried to create box then it will create 2 copies of of box.
vimleshpatel
Postby TIG » Fri May 08, 2015 10:25 am
Is you code inside a module ??
Code: Select all
    ply_type ="PLY"
    info = Hash.new
    component = b.draw
Leaves unanswered questions...
Where do the Constants DESCRIPTION and BACK come from ?
what is 'b' that RectangleBox makes ?
Is it a 'box' in geometry ?
What is the '.draw' method for it ?
This method returns a 'component' ??
I'm sure your code could be less convoluted and thereby more easily understood...
:cry:
Global Moderator
Postby vimleshpatel » Fri May 08, 2015 1:02 pm
All those method are defined inside class like:
Code: Select all
class DBox
   DESCRIPTION = 'Description'
   BACK = "Back" # It means nothing yet.
   def get_all_points
     @left = [[0, 0, 0], [500.mm, 150.mm, 0]]
     @right = [[0, 0, 0], [500.mm, 150.mm, 0]]
     @front = [[0, 0, 0], [200.mm, 150.mm, 0]]
     @back = [[0, 0, 0], [200.mm, 150.mm, 0]]
     @bottom = [[0, 0, 0], [480.mm, 180.mm, 0]]
     @thickness = 18
   def create_box
     entities = []
       return
     h_panel=nil
     v_panels=[]
         h_panel = panel
       else
         v_panels << panel
     if !points
       return
     box.erase!
     points = []
     dict1 = nil
       panel1= nil
       if x1 > x2
       else
     if !points
       return false
     points
     ply_type ="PLY"
     info = Hash.new
     component = b.draw
     points =[0,0,0] #Position for panel to fit
     panel
     points =[200.mm,0,0] #Position for panel to fit
     panel
     points =[18.mm,0,0] #Position for panel to fit
     panel
     points =[18.mm,0,482.mm] #Position for panel to fit
     panel
     points =[10.mm, 140.mm, 490.mm] #Position for panel to fit
     panel
class RectangleBox
  attr_reader :near, :far, :thickness
  def initialize( near, far, thickness, ply_type, info = {})
    @near = near; @far = far
    @thickness= thickness
    @ply_type = ply_type
    @description = info[DESCRIPTION]
  def draw(*args)
    model=Sketchup.active_model()
    if args.length == 0
      ents = model.entities()
      group = ents.add_group()
    else
      group = args[0]
    corners = get_corners()
    face = group.entities().add_face(corners[0], corners[1], corners[2], corners[3])
    face.pushpull(@thickness.mm)
    panel= group.to_component
    panel.definition.name = "#{@ply_type}"
    panel.name = @description
    return panel
  def get_corners()
    ret = []
    ret[0] = @near
    ret[2] = @far
    ret[1] = [ @near[r], @far[g], @far[b] ]
    ret[3] = [ @far[r], @near[g], @near[b] ]
    return ret
class SketchupInfo
   def self.getDictionary(entity, dictionary)
      dicts = entity.attribute_dictionaries
      if !dicts.nil?
         dicts[dictionary]
   def self.rootDictionary(entity)
     SketchupInfo.getDictionary(entity,'dynamic_attributes')
I called create_box method form menu by creating object for DBox
Code: Select all
box = DBox.new
box.create_box
I removed some of the method which are not used till now.
If I'm creating box independently (not inside Cabinet) then it creates only one box as ComponentInstance, but when I tried to create it withing Cabinet then one extra box is creating which is not even a group(all panels are individual) & if I'm moving one of the panel the the panel inside grouped box is also moving. or if I tried to delete any panel then Sketchup got crashed.
vimleshpatel
Postby TIG » Fri May 08, 2015 2:03 pm
The class is somewhat like a module in this context...
But still best to include the whole lot inside your own module...
Can I suggest you revisit your various entities definitions.
Sometimes you use model.active_entities, another model.entities, they might not always be the same thing...
Also if you make your group and immediately add thing to group.entities it might be easier...
Global Moderator
Return to Dynamic Components
