Dynamic Component attribute question  Topic is solved
Postby iclifton » Thu Mar 26, 2015 2:32 pm
My question is probably a simple one. If i create an attribute to return the cost of an item based on the model number, which i already have set up in a pull down list. When i use the =if formula, i can only go out 3 cost. i have eight model numbers. Is there a different formula that i can use or am i doing something wrong.
iclifton
Premium Member
Premium Member
Re: Dynamic Component attribute question  Topic is solved
Postby pcmoor » Thu Mar 26, 2015 11:21 pm
you can use nested if statements, however it is best to use the choose function, based on the dropdown index. CHOOSE(index,value1,value2,...valueN)
cost =choose(drop,$12,$15.....$n)
drop item 2 (where the value =2)
or if value of drop is some function or not a consecutive integer,
then use OPTIONINDEX("attributeName")
within the choose function
cost =choose(optionindex("drop"),$12,$15.....$n)
the number of choices = numder in dropdown
pcmoor
Postby iclifton » Fri Mar 27, 2015 2:39 pm
Thank you pcmoor. i was able to use =CHOOSE(OPTIONINDEX. It gave me the result i was looking for. Thanks for the help!
iclifton
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Dynamic Components
Who is online
Users browsing this forum: No registered users and 2 guests
Visit our sponsors:
