DC nested logical function
Postby dieter10 » Wed Nov 12, 2014 10:48 pm
Hello,
This doesn't works in sketchup:
IF( (length >=50)&&(with<=20),......)
The problem:
How do I need to solve this?
dieter10
Re: DC nested logical function
Postby pcmoor » Wed Nov 12, 2014 11:21 pm
there is no "&&" function but "AND"
use =IF(and(leng >=50,with<=20),true,false)
or can use nested
=IF(leng >=50,if(with<=20,true,false),false)
which returns 0 or 1
true or false can replaced for any other outcome
pcmoor
Postby dieter10 » Wed Nov 12, 2014 11:24 pm
Thanks for the quick reply!
And i have also some troubles with redrawing.
Can i make something that if i press the apply button that it automaticly redraws ?
dieter10
Postby pcmoor » Wed Nov 12, 2014 11:52 pm
by using the "current" in a dummy variable you may achieve what you are after
aX = current("x")
can post the DC, or private message ?
pcmoor
Postby dieter10 » Sun Nov 23, 2014 11:16 pm
My model is nearly finished.
Thanks for the reply's. Conclusion: you just need to think a moment how you're going to solve the problem and how you are going to create the formulas.
In the .gif file, you can see how i can modify the model.
But sometimes there is something that doesn't moves or ...
Is that a bug in sketchup? I never had this problem whem i'm starting from the original model.
dieter10
Postby pcmoor » Mon Nov 24, 2014 5:43 am
You would need to post the DC, so one can check for the error, otherwise look for the red # when it fails, or maybe a redraw is required.........one can only guess
pcmoor
Postby dieter10 » Mon Nov 24, 2014 9:35 pm
Thanks for your reply pcmoor, i found 2 red #. The function of the subcomponent referred to a variable of another head component. And i forgot to define the x position of 2 pieces. Now it seems to work fine. I just need to add the position for the keys, because they are scaled with the door panel and i want them always off the same distance off the side.
dieter10
Return to Dynamic Components
