Hide/Show only every Nth Copied Instance?
Postby bthomas3 » Thu Oct 23, 2014 10:37 pm
I hope this hasn't been covered somewhere else, but I can't find it anywhere
To keep it simple, I have a variable that is set by the user (say 3), and I want to hide every COPY multiple of that number, including the original.
So, I'm hiding COPY 0.0, COPY 3.0, COPY 6.0, etc.
Suggestions? Thanks in advance.
BT
bthomas3
Re: Hide/Show only every Nth Copied Instance?
Postby quantj » Fri Oct 24, 2014 4:33 am
I suppose there's a math formula for this, I just don't know it. Otherwise, if you don't plan on having many copies, you can do a really long IF statement to hide copy 3, 6, 9, etc). Maybe add another variable to test copy# so that you can easily change what Nth number you want hidden.
Thinking out loud, I'm thinking having a variable to calculate the total copies/# (like 3)='A', and with that number you'll get the total amount of copies you need hidden. And then somehow get every 3x# up to 'A' hidden...
quantj
Postby Anton_S » Fri Oct 24, 2014 7:01 am
Usage: Select any group/component, right click, and select Hide Every nth Instance option.
Anton_S
PluginStore Author
PluginStore Author
Postby bthomas3 » Fri Oct 24, 2014 6:06 pm
Anton_S wrote:Usage: Select any group/component, right click, and select Hide Every nth Instance option.
Excellent script, thank you, but not ideal for this application. I need something in Dynamic Components so that the object (say a white picket fence) can be scaled to length AND the user can specify the interval of hidden components.
The flip side to this is a second, overlapping set of pickets (say, blue), that show up where the others were removed. This formula is easy using COPY*Multiplier*distance, but hiding the white ones that the blue ones replace is where I'm stuck.
Thanks again
BT
bthomas3
Postby bthomas3 » Fri Oct 24, 2014 6:21 pm
quantj wrote:I suppose there's a math formula for this, I just don't know it. Otherwise, if you don't plan on having many copies, you can do a really long IF statement to hide copy 3, 6, 9, etc). Maybe add another variable to test copy# so that you can easily change what Nth number you want hidden.
Ok, I was trying to avoid If/Then statements, but I got it to work with your suggestion, so time to move on. Here's what I have:
Variable (var) = 2 or 3
For the "white pickets" hidden every 2 or 3 instances:
=IF(COPY=0,0,IF(COPY=var*1,0,IF(COPY=var*2,0,IF(COPY=var*3,1,0))))
For the "blue pickets" shown every 2 or 3 instances:
=IF(COPY=0,0,IF(COPY=var*1,0,IF(COPY=var*2,0,IF(COPY=var*3,0,1))))
Thanks for your help, everyone. If there's a more elegant solution, I'm all ears. Otherwise, this will do. Thanks again!
BT
bthomas3
Postby pcmoor » Sat Oct 25, 2014 12:53 am
only variable that acts as a counter is copy
so need to make an expression using this when comparing to other variables
know each object is copy+1
also its a multiple of the "missing rate" (num)
however sometimes its a perfect division other times not
so need to make a formula which gives the decimal part of the division
=(copy+1)/num-int((copy+1)/num)
then use this as if statement
pcmoor
Postby quantj » Sat Oct 25, 2014 1:55 am
I think I kinda got something going:
Nth=3(or any other number)
Formula A: =copy/3
example: 8/3 = 2.6667
Formula B: =INT(copy/3)
example: 8/3 = 2
Formula C: =Formula A - Formula B
Hidden: =IF(Formula C = 0, 0, 1)
I worked once for my example, but when i changed the number of copies, it didn't auto redraw to redo the formula.
Hopefully someone here can finish this with native tools, it's a puzzle I'd like to see solved without plug-ins
quantj
Postby quantj » Sat Oct 25, 2014 1:56 am
pcmoor wrote:only variable that acts as a counter is copy
Sorry pcmoor, my math stills arent tha advanced, that went over my head. :(
Tried out your model (after writing my post), yours works and can update (which i couldn't figure out)
EDIT:
I get it! after i stared at the INT i realized we were on the same track, i think just seeing all the variables put into one formula confused me
quantj
Postby danielbowring » Mon Oct 27, 2014 12:44 am
You should be using a modulo operation for this. A modulo operation will give the "remainder" of integer division. SketchUp doesn't provide a mod function for DCs, so you'll have to create it as such:
Code: Select all
a - (n * FLOOR(a/n))
where a is the index and you want to hide every N.
For example, if you have
Code: Select all
HIDDEN=COPY - (3 * FLOOR(COPY/3))==0
, you'll get:
Code: Select all
HIDDEN, VISIBLE, VISIBLE, HIDDEN
You can change the compared value (in the above example, 0) to be the "offset", but it must be less than n.
Code: Select all
HIDDEN=COPY - (3 * FLOOR(COPY/3))==2
, you'll get:
Code: Select all
VISIBLE, VISIBLE, HIDDEN, VISIBLE, ...
danielbowring
Postby Anton_S » Mon Oct 27, 2014 1:59 am
Actually Ruby does have a modulo function. It's this symbol: %.
5%3 = 2
6%3 = 0
etc...
The script at third post uses the modulo technique to hide every nth instance.
Anton_S
PluginStore Author
PluginStore Author
Postby danielbowring » Mon Oct 27, 2014 7:21 am
Yes, ruby does have a modulo operator - I said Dynamic Components doesn't provide a modulus function.
danielbowring
Return to Dynamic Components
