Layer change inside DC while, using copy
Postby Dulo » Sat Mar 01, 2014 11:17 pm
Hello
I've created a DC in which I use the copy function.
It's a sort of a frame, with the partitions made in the copy function.
So if the frame is 1000mm long there are 4 (3 copies) partitions, if you scale it to 2000mm there are 8 partitions (7 copies)
However when I load the DC in my new drawing, everyting keeps the layer in which it was created. The DC is in the current layer from the moment I have loaded the DC.
But when I scale from 1000 to 2000mm, the first 4 partitions keep their original layer, but the new copies are in the current layer. Is there a way to keep the original layer while copying?
And is it possible to place the layer info in a attribute, to give it trough an attribute to a component? Or to get it from a component and place it in a attribute?
Thanks a lot in advance, I've should have paid more attention during the English lessons though.
Regards
Ludo
Dulo
Re: Layer change inside DC while, using copy
Postby Dulo » Wed Apr 02, 2014 8:48 pm
verry vivid reactions.
explained my question to difficult?
Dulo
Postby yorik1984 » Thu Apr 03, 2014 10:18 am
in this case i apply needed layer to geometry(not components or groups). Is not good, but it working.
User avatar
yorik1984
Postby Jim » Thu Apr 03, 2014 10:16 pm
The behavior of the COPIES attribute failing to also copy the Layer would be considered a bug in Dynamic Components.
Jim
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Dynamic Components
Who is online
Visit our sponsors:
