DC StairCaseBuilder
DC StairCaseBuilder
Postby Howard leslie » Thu Apr 23, 2009 1:16 pm
StairCaseBuilder – General Notes
1. StairCaseBuilder – A Dynamic Component that can be used to help model Staircases very quickly.
2. Similar in style and operation to another related Dynamic Component – SpiralStairCaseBuilder.
http://forums.sketchucation.com/viewtopic.php?f=289&t=29484
NOTE:
Dynamic Components can be USED by ALL SketchUp Users - Free & Pro
Release Log
V3-2 - 2009-04-23 first public release.
V4 - 2009-04-25 Ability to have either open stairs or solid risers.
V4-1 - 2009-04-28 International and UK Versions released.
V5-1 (Current Version) - 2010-03-17 International and UK Versions Merged. Handrailing Construction Guides Added.
StairCaseBuilder Current Version - V5-1 - Main Changes
1. StairCaseBuilder now has just 1 Version - International & UK Versions have been merged (any units can be used - mm / feet and inches etc) - any future updates will be added to this current version.
2. A bug existed in previous versions whereby staircase riser calculations were occasionally incorrect under certain circumstances (reported once) - this is now FIXED.
3. Handrail Construction Guides have been added. The StairCaseBuilder now adds lines that can be used as guides to help further modelling of handrailing for your staircase if required.
After some deliberating I decided not to incorporate detailed handrailing into this DC - instead I added handrailing guides (simple lines).
The inclusion of detailed handrailing would have been quite daunting.
Do you add round / square or half - round handrailing / stanchion sections ?
How many Stanchions ? 1 per Step or every other Step ?
In other words - infinite combinations exist and I wanted this DC to be as generic and therefore as useful as possible so it can be used WHENEVER a staircase needs to be modelled.
Handrailing guides are far more useful as they give great flexibility - but it does mean you have some finishing off to do by hand if you want a detailed staircase.
The handrailing construction guides along with various plug-ins will help speed up this manual part.
V 5-1 - SU DC Bug or StairCaseBuilder Bug ?
Sometimes the Handrail Construction Guidelines or Staircase may appear to be modelled incorrectly (eg Construction Lines don't join at the top handrail). To correct this simply enter a low figure in the Total Rise (Floor to Floor Height) eg 200mm / 8" etc. Click Apply. The Staircase is flattened right down - this resets the Staircase. Then add your correct Total Rise again and Click Apply. I'm not sure if this is a general SketchUp DC bug when it has to do lots of calculations or a bug associated with StairCaseBuilder.
TOP TIPS - HANDRAILING
The Handrail Construction Guides (lines) should first be set up to approximate your actual handrails and stanchions you require. (If you don't need them, turn the layer off).
Up to 4 Handrails (horizontal lines) can be added.
Stanchions (vertical lines) can be moved in X,Y and Z using the DC dialog box (ie moved front / back, left / right and up / down).
It may be sufficient to leave the Handrails as simple lines only eg if the staircase is only ever viewed from a distance. If you want to model you're handrailing further, don't overdetail the handrailing / stanchions if they are never viewed really close up eg use a 12 or 16 sided circle for round sections etc or use rectangular sections. For a more detailed finish to the handrailing I can thoroughly recommend use of the following plug-ins:
Pipe Along Path (TIG)
2d Tools (TIG) - 2d Toolset, but some tools eg Fillet work in 3d also.
Profile Builder (Dale Martens)
Any probs / suggestions / improvements / feedback etc - giz a shout
Enjoy
Howard L'
Keywords: Dynamic Component DC Staircase Stairs Steps
Last edited by Howard leslie on Sun Jul 11, 2010 3:26 pm, edited 28 times in total.
Howard leslie
Re: DC Staircase Builder - to UK BS & Bldg Regs
Postby tinanne » Mon Apr 27, 2009 3:41 pm
Howard, Thank you this is great. I wish it was in inches. :( I could use it all the time. Of course, I could break down and learn how to use it in metric. :)
Thanks again for your generosity.
Executive Director : American Society of Architectural Illustrators
AIP 30 Competition opens soon. ASAI.org
Architectural Rendering
tinanne
Premium Member
Premium Member
Postby putnik » Tue Apr 28, 2009 4:30 am
Thank you.
putnik
Postby Chris Fullmer » Tue Apr 28, 2009 4:57 am
Yes, its really a great component. Thanks for sharing!
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Re: DC Staircase Builder - International & UK Versions
Postby Howard leslie » Tue Apr 28, 2009 11:08 pm
Tina,
Your wish is granted.
See first post in this thread.
International version is now available where you can enter info in feet and inches if reqd.
Hope this helps
Regards
Howard L'
Howard leslie
Postby tinanne » Wed Apr 29, 2009 1:09 pm
Wahoo! Howard that is wonderful! Thank you so much!
I love this place :enlight:
tinanne
Premium Member
Premium Member
Postby Aidan_Weisz » Mon Jun 22, 2009 7:23 am
Thank you for all these, Howard.
Aidan_Weisz
Postby utiler » Tue Aug 11, 2009 11:33 pm
This is a great example Howard, very clever and very generous.... :berserk:
utiler
Top SketchUcator
Postby Ben Ritter » Mon Sep 28, 2009 10:08 pm
Howard, thank you for the component. I'll have to start using SU7 now.
Ben Ritter
Re: DC StairCaseBuilder
Postby Howard leslie » Wed Mar 17, 2010 10:10 pm
DC StairCaseBuilder V5-1 released
Enjoy
Howard L'
Howard leslie
Postby brookefox » Thu Apr 29, 2010 1:59 am
From a distance, certainly looks nice, but codes in my vicinity, and throughout most of the US, require more horizontals: 4" inch max clear is common. Tough luck for the yanks.
~ Brooke
brookefox
Postby CNC Paul » Mon May 03, 2010 11:13 am
Howard,
That is a great tool, how can I get a copy ?
Regards
Paul
CNC Paul
Postby TIG » Mon May 03, 2010 12:00 pm
brookefox wrote:From a distance, certainly looks nice, but codes in my vicinity, and throughout most of the US, Part K requires more horizontals: 4" inch max clear is common. Tough luck for the yanks.
In the UK under "Part K" it's even slightly smaller - a 100mm diameter ball shouldn't pass through any gap in a stairs risers or associated railings/balustrades [there is an exception for the potentially non-compliant triangular gap between the riser/tread and a raking balustrade bottom]. This rule applies to any 'domestic' stair or building where you might reasonably expect children aged 5 or under - i.e. schools and the like. These days this is effectively most public buildings and even offices too - indeed, there was a tragic accident at a national TV station's offices a few years ago when a toddler fell several floors through a more open balustrade around an atrium, and was killed - he was there with his mother on a 'take-your children-to-work' day. A building operator is responsible for the Health and Safety of staff and visitors, so even if the Regs allow it many want 'safe' designs. Now only stairs in plant-rooms and the like can be the more 'gappy' type.
This '100mm ball rule' is actually determined from a toddler/baby's head size - whilst having these reduced gaps stops older kids falling through, the concern is that 'crawling' youngsters might squeeze through a small gap 'backwards', then fall BUT still get their head stuck in the gap if it's bigger than 100mm and then they could break their neck or strangle themselves - BUT they can't get their body through the 100mm gap in the first place, and so are 'safe'.
On aside note: I have also done work on maximum security prisons - in those the maximum gap is 125mm [was 5"] between rigid bars etc, this is determined as a gap a normal adult can't squeeze through - although in one jail there was a small skinny guy who would amuse himself by winding up the guards, he'd squeeze his whole body through the bars, but then get stuck because his head wouldn't pass through - then he was completely uncooperative about getting back through to the side where his head was [sawing off his head seemed the attractive option, but it's not allowed under some daft human-rights rule or other ;) ]. Also no 'Shawshank Redemption' escapes because prison drains passing out of the secure compound can't be more than 300mm/12" internal diameter in the UK !
Back to the stairs... open-riser stairs of any type are also disallowed in public buildings under the Disability-Discrimination-Act[DDA]/BS8300 and Part M - 'Accessibility Regs' - if people with calipers on there legs might get then caught !
Where open-risers are allowed their gaps can be limited to <100mm by adding a single thin rod across them, or more commonly making the tread thicker at the riser location, or making the back of the tread with an upstand of ~25/50mm so that the gap is reduced AND you also have something to stop the tread finish against neatly.
Also often forgotten is in domestic/<5yrs buildings the parts of a balustrade etc are not allowed to be horizontal [rails etc], or even have 'holes', that could an be climbable by small children.
You talk about restrictions - "natural selection" has stopped here... :roll:
Global Moderator
Postby Howard leslie » Mon May 10, 2010 11:43 am
Brooke,
Some Top Tips for you ...
Use StairCaseBuilder to design the bulk of the Staircase, then ...
Finish off handrailing as shown - ProfileBuilder or PipeAlongPath Ruby Scripts help in this task.
See attached file to give you some ideas.
StairCaseBuilder incorporates Horizontal (Handrail) and Vertical (Stanchion) Guidelines.
These are GUIDELINES that can be further enhanced or detailed to complete your staircase as required.
Handrailing GUIDELINES (simple lines) are used in this DC (as opposed to more detailed handrailing) as the possibilities / combinations for more detailed handrailing are infinite eg
- Position and Spacing of Stanchions.
- No and position of Horizontals / Verticals
- Handrailing / Stanchion Cross Sections, Which to choose ? eg Circular, Oval, Semi-Circular, Square, Rectangular or a more detailed / fancy section ?
See other notes / images / ideas in the first post of this thread
Hope this helps
Regards
Howard L'
Last edited by Howard leslie on Mon May 10, 2010 10:51 pm, edited 1 time in total.
Howard leslie
Postby brookefox » Mon May 10, 2010 6:27 pm
Thank you, Howard. At heart, of course, I'm just another spoiled child, wanting it all on my plate, served up, with savory sauce.
Thank you for delivering.
~ Brooke
brookefox
Postby domus » Tue May 11, 2010 7:13 am
Thank you! You've made me appreciate dynamic components and glad I chose to get SU Pro. This is a real time saver!
domus
Postby domus » Tue May 11, 2010 7:32 am
I hope my last post doesn't give the impression that you can't use this Dynamic Component with SU free. You can, of course. I mean it's inspired me to learn more about how to create them, which you can only do in SU Pro.
domus
Postby Howard leslie » Wed May 12, 2010 9:12 am
Domus,
In case you haven't seen it yet - you may also like to try this DC for creating doors (another time saver). I created it because I found that I was forever having to model doors from scratch - this DC is also animated (use magic finger icon on DC toolbar):
http://forums.sketchucation.com/viewtopic.php?f=289&t=21350
Hope this helps
Regards
Howard L'
Howard leslie
Postby domus » Wed May 12, 2010 11:25 am
Thanks again Howard, I didn't know about that one. Another gem!
domus
Postby penumbra » Mon Aug 16, 2010 2:46 am
I just wandered in to this post. This is absolutely fab!, thanks!
penumbra
Postby mac1 » Sun Dec 05, 2010 8:49 pm
Howard
Hoping you are still watching this post. Have a problem in river city.
have xp sp3 and su 7.1+ free. Was trying to evaluate your builder but cannot get the input box to appear. Have tried various thing but no joy. Is this a limit of free or do I need 8
mac1
Top SketchUcator
Postby Howard leslie » Sun Dec 05, 2010 11:31 pm
mac1,
StairCaseBuilder is a Dynamic Component (SU version 7 file format)
All users of SketchUp can take advantage of DCs - both Free & Pro.
SU 7 & SU 8 can both use Dynamic Components
TO USE THIS DC:
Open Component File - Don't Import it into an existing SU Model
(but see note below).
Bring up DC Toolbar: View - Toolbars - Dynamic Components
Dynamic Components Toolbar - Yellow Middle Icon - Component Options
Click on DC
Dialog Box Options should appear
Set options
Apply
Copy & Paste DC Staircase into your own model
You can actually import this DC into an existing model like a regular Component but the DC will be nested 1 Level down
(Look at Outliner).
You can still bring up the Dialog Box but you'll have to go inside the Components Context to do this.
(or Explode the outer most Component once)
Hope this Helps / Make Sense
Regards
Howard L'
Howard leslie
Postby mac1 » Mon Dec 06, 2010 2:25 am
Howard Leslie wrote:mac1,
TO USE THIS DC:
Click on DC
Set options
Apply
(Look at Outliner).
Regards
Howard L'
Thanks for the quick reply. In ISO 1 context of Dc selected a step then component option .Ruby consul states
Error: #<TypeError: cannot convert nil into String>
(eval):1321:in `set_file'
(eval):1321:in `show_dialog_orig'
(eval):7558:in `show_dialog'
(eval):7598:in `show_configure_dialog'
(eval):155:in `initialize'
(eval):147:in `call'
If I follow your instructions, tool bar, yellow icon, then click on the DC I get just one error. Bummer
mac1
Top SketchUcator
Postby mac1 » Wed Dec 08, 2010 7:36 pm
Howard
Update for you.
Regressed back to SU 7.0 free, after a copy of may installed SU 7.1 plugins and tools to desk top, and your DC worked OK :enlight:
Re-downloaded SU7.1 free with the as supplied Google plugins and tools, and your DC works OK :enlight:
Search is now on for "bad" plugin or :?:
Thanks again for your help
mac1
Top SketchUcator
Postby 7348su » Sat Jan 01, 2011 4:04 am
Love it very much, thanks.
7348su
Postby Dropout » Sat Jan 01, 2011 11:30 pm
And we get it where?
Dropout
Postby pbacot » Sat Jan 01, 2011 11:34 pm
Dropout wrote:And we get it where?
See the first post in the thread.
Sort of the standard here for plugins and components: The download is usually in the first post--even for updates.
I am downloading this one. Fantastic work! Thanks so much. Peter
Top SketchUcator
Return to Dynamic Components
