by Mike Lucey » Fri Sep 20, 2019 2:44 pm
Hi Mac SketchUp Users,
It looks like Mac OS Catalina Beta, at least, does not fully support SketchUp.
Mike
Mike Lucey
- Mayor
- Name: Mike Lucey
- Operating system: Mac
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by pbacot » Fri Sep 20, 2019 4:24 pm
Thanks Mike!
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
- Top SketchUcator
- Name: pbacot
- SketchUp version: 2016
- License type: Pro
- Level of SketchUp: Intermediate
by sketch3d.de » Thu Sep 26, 2019 11:40 am
Mike Lucey wrote:It looks like Mac OS Catalina Beta, at least, does not fully support SketchUp.
what does this exactly mean, pls elaborate, thx.
sketch3d.de
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Beginner
by laterstarter » Thu Oct 17, 2019 11:45 am
3dConnexion devices are not supported at all yet, though they inform a driver is being developed
Natively SKP 2019 seems to work under Catalina so long as one has not been spoilt by a 3DConnexion navigation device.
Kind Regards, Scott
laterstarter
- Premium Member
- Name: Scott R Smith
- SketchUp version: 2020
- License type: Pro
- SketchUp use: hobby
by markchandler » Thu Oct 17, 2019 8:37 pm
If you're on macOS Catalina, you should be running SU2019.3
markchandler
- Name: Mark Chandler
- SketchUp version: 2019
- License type: Pro
by juju » Thu Oct 17, 2019 9:28 pm
markchandler wrote:If you're on macOS Catalina, you should be running SU2019.3
Wow, another maintenance release?! When did this drop? I totally missed that.
juju
- Premium Member
- Name: Juju
- License type: Pro
by sketch3d.de » Fri Oct 18, 2019 12:18 pm
sketch3d.de
- License type: Pro
by TIG » Sat Oct 19, 2019 1:17 pm
Version 2019.3 is published. https://www.sketchup.com/download/allBUT it not been advertised, or notified in update checking ! Its main change is MAC's Catalina compatibility. So if you must have Catalina get it. BUT remember that Catalina is flaky with ALL earlier versions of SketchUp and they won't be getting updated. So if you use v2017/2018 you can't step up to Catalina. Catalina has also broken lots of other common applications, so you might want to check what they are, as fixing SketchUp might only be one step down along road !!
- Global Moderator
- Name: TIG
- License type: Pro
by juju » Sat Oct 19, 2019 6:25 pm
TIG wrote:Version 2019.3 is published.
stepping up to Catalina when you're on SU2019 / SU2019.1 / SU2019.2 is also a no-no.
juju
- Premium Member
- Name: Juju
- License type: Pro
by TIG » Sun Oct 20, 2019 4:15 pm
Unless you like to live dangerously
- Global Moderator
- Name: TIG
- License type: Pro
by Ecuadorian » Sun Oct 27, 2019 10:54 pm
I also lost Audacity after the upgrade
Ecuadorian
- Name: Miguel
- SketchUp version: 2017
- License type: Pro
by TIG » Mon Oct 28, 2019 2:05 pm
Catalina has broken many apps ! The latest SketchUp v2019.3 [available but not widely advertised yet!] addresses most known issues, but I understand that it still suffers from an 'undo/redo' bug, and that needs fixing directly by Apple !
- Global Moderator
- Name: TIG
- License type: Pro
by slbaumgartner » Wed Oct 30, 2019 2:33 pm
@Euadorian what kind of problem with Audacity are you seeing? If it is being rejected as 32-bit, you need to update to the latest release (2.3.2) which is 64-bit. However, there is known issue with access to certain input devices such as the microphone. They are looking into it. See this link for a temporary workaround: https://forum.audacityteam.org/viewtopi ... 2&p=378694
slbaumgartner
- PluginStore Author
- Name: slbaumgartner
- License type: Pro
- SketchUp use: woodworking
by Ecuadorian » Thu Oct 31, 2019 11:39 pm
@slbaumgartner Thank you! It just won't open. I was in a rush, so I just used MacOS's voice recorder and then edited it in my PC. I'll look into it. Thanks!
Ecuadorian
- Name: Miguel
- License type: Pro
by ramyasri123 » Fri Feb 07, 2020 11:54 am
ramyasri123
- Name: ramyasri
- SketchUp version: 6
- License type: Free/Make
by galactus » Tue Feb 11, 2020 12:06 pm
Plugins don't work with CATALINA 10.15.2 / SU 19.3
is there any news yet?
galactus
- Name: Paul
- License type: Pro
by galactus » Tue Feb 11, 2020 2:25 pm
UPDATE: I just updated to Catalina 10.15.3 and installed LibFredo6_v9.5g. FredoCorner and Curviloft are working again!!!
galactus
- Name: Paul
- License type: Pro
by Mike Lucey » Sun Mar 08, 2020 4:24 pm
Good to hear. It looks like the wrinkles have been ironed out
Mike Lucey
- Mayor
- Name: Mike Lucey
- License type: Pro
by Leggy » Fri Apr 03, 2020 5:01 pm
So are we good to upgrade now?
Leggy
- Name: Dean Legg
- License type: Pro
- SketchUp use: engineering and mechanical design
by Mike Lucey » Sat Apr 18, 2020 12:36 pm
Leggy wrote:So are we good to upgrade now?
Yes, all good now. I must 'unstick' this thread.
Mike Lucey
- Mayor
- Name: Mike Lucey
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Corner Bar
