Referencing DWG in Sketchup and export to GE
Postby jex83 » Thu Feb 08, 2018 9:37 pm
Dear Forum,
I have a georeferenced dxf-file (GK-Zone 2, EPSG 31466) and I want to get it into Sketchup to export it to GE. The location is also correct, tested it in QGIS.
If I directly import it, Sketchup will screw the geolocation. And if I get a "reference point" in my dxf and transfer this point to WGS84 and use it as origin point in SKP, the location and the dimensions seems to match, but the model is rotated for roughly 2-3 degrees. And when I transfer the dxf in QGIS to WGS84 and to later on the same, I have the same problem.
Does anybody know what has to be adjusted in the procedure?
Or is there a more simple way to get a referenced acad-file referenced into sketchup?
jex83
Re: Referencing DWG in Sketchup and export to GE
Postby jex83 » Sun Feb 11, 2018 10:28 am
Or just asked generally: how can I "transfer" a geographic reference while importing a 3D-model from another source ?
jex83
Postby jex83 » Thu Feb 15, 2018 9:16 pm
anyone? never ever had anybody else this problem?
jex83
Postby alpro » Sat Feb 17, 2018 5:13 am
I find getting any georefenced data into SU a PIA requiring some kind of work arounds. Why don't you use 2 reference points so then you can rotate your data?
alpro
Premium Member
Premium Member
Postby jex83 » Tue Feb 20, 2018 9:20 am
hi alpro,
thanks for the response. what do you mean by work arounds...do you have any example?
the problem with two reference points is, that this doesn't work for instance if you have an underlying raster-satelitte image.
and sorry for the question, but what is PIA?
jex83
Postby pbacot » Tue Feb 20, 2018 4:06 pm
PITA
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby jex83 » Tue Feb 20, 2018 9:49 pm
@pbacot ah ok, got it ;-)
jex83
Postby SJS66 » Mon Jul 29, 2019 2:37 am
pbacot wrote:PITA
Ha, hate to say it but I had to google it....lol.
Just to save other dummies like me doing the same PITA = Pain In The Arse
:-P
User avatar
SJS66
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Google Earth
Who is online
Visit our sponsors:
