One or more buildings
Postby ThorOl » Sun Feb 03, 2013 1:12 pm
Hi fellow sketchupians.
I am about to model this building in Norway:
http://tinyurl.com/cncqch5
My question is, would you do this as one, or more buildings for google earth?
ThorOl
Re: One or more buildings
Postby Gaieus » Sun Feb 03, 2013 2:09 pm
That's a whole block. According to the SketchUp to Google Earth modelling guide lines, each building in the block should be a separate model to submit.
You can model them together however (best practice to keep the buildings perfectly aligned) but make each building a separate component. Once done, go to the Component browser and right click on each component (the whole buildings only, if you use nested subcomponents) and "Share component" from there. They will now be shared and uploaded separately.
Postby ThorOl » Sun Feb 03, 2013 2:42 pm
Thanks!
One thing tho, that is not very visible from the photo. The "Center" of this blosck is raised. The whole inner of the block is raised to a second floor. Does this change your previous answer?
ThorOl
Postby Gaieus » Sun Feb 03, 2013 3:22 pm
Well, here is the guide line for the individual buildings:
http://support.google.com/sketchup/bin/ ... er=1267399
Then you can also add a (small) "terrain skirt" (which I would use for that central area if it is only raised and not a building like a garage):
http://support.google.com/sketchup/bin/ ... wer=167465
But make sure that small is small. Like it should not extend out of the yard in your case, I guess. Here is the guide line:
http://support.google.com/sketchup/bin/ ... er=1267403
And all the guide lines:
http://support.google.com/sketchup/bin/ ... er=1267260
Return to Google Earth
