More older stuff
To access this forum when logged in, please, sign up to the Woodworking User Group in your User Control Panel.
More older stuff
Postby CJRyan » Fri Jan 10, 2020 2:43 am
In that, I milled most everything but the ply-wood used, I guess this is "woodworking".
I modeled and built this from a concept sketch. I've revised the original model to reflect the "as-built" state.
The walls, ceiling, and floor were 1/4 inch steel welded in place, so every attachment point was drilled and tapped.
The two back panels on the right and left are mounted on cantilevered slides to access and hide my client's full-automatic guns.
Because the man had both double-barrel and single barrel rifles, I designed some upper receivers that are mounted using magnets, so the guns could be positioned as he wished.
7
CJRyan
Premium Member
Premium Member
Re: More older stuff
Postby L i am » Fri Jan 10, 2020 10:04 am
Really nice, well concieved and executed design CJ and thanks for sharing been a bit quite in that area. I find the render a bit half baked and not at all covincing ;)
Premium Member
Premium Member
Postby robertWan » Sat Jan 11, 2020 11:54 pm
L i am wrote:render
Render?
This is probably the actual appearance of the furniture.
Robert
robertWan
Postby CJRyan » Sun Jan 12, 2020 1:31 am
I'm fairly sure L i am was kidding. I only wish I could render that well.
CJRyan
Premium Member
Premium Member
Postby robertWan » Sun Jan 12, 2020 2:09 am
This confused me. :-)
Robert
robertWan
Postby L i am » Sun Jan 12, 2020 10:22 am
robertWan wrote:
L i am wrote:render
Render?
Robert
Hi Robert, sorry mate that was a (probably bad) joke. I was aware it was a Photo, indicated by the "wink" at the end ;)
Premium Member
Premium Member
Postby CJRyan » Mon Jan 13, 2020 4:40 am
L i am, in that I know you, I found it funny.
For hahas, I found another "render" of the hidden panel.
CJRyan
Premium Member
Premium Member
Postby L i am » Mon Jan 13, 2020 11:49 am
CJRyan wrote:L i am, in that I know you, I found it funny.
Hi CJ, not sure Stinkie would appreciate you taking credit for his work ;)
Premium Member
Premium Member
Return to Woodworking
