half-round rope molding  Topic is solved
To access this forum when logged in, please, sign up to the Woodworking User Group in your User Control Panel.
Postby pipingguy » Tue Dec 05, 2017 1:36 pm
before i physically mutilate the pre-finished poplar subject item that's supposed to adorn a cabinet-top crowne molding with an outside corner, i tried doing it with skp....but with no luck. maybe if the two workpieces had opposite hands, but they don't.
pipingguy
Re: half-round rope molding  Topic is solved
Postby Dave R » Tue Dec 05, 2017 1:53 pm
The trick is to join both pieces of molding so either the high points or the low points on the edges meet.
Then miter them.
Flip one of the lengths of molding end for end and adjust the position so it looks more like a continuous run of rope. around the corner.
4
Global Moderator
Postby pbacot » Tue Dec 05, 2017 4:59 pm
zounds!
MacOSX Mojave ShetchUp Pro v16...v19? Layout Twilight Pro v2 M2 Kerkythea PowerCADD
Top SketchUcator
Postby pipingguy » Wed Dec 06, 2017 12:53 am
how do you know so darned much sir?
pipingguy
Postby Dave R » Wed Dec 06, 2017 1:00 am
pipingguy wrote:how do you know so darned much sir?
People like you ask questions and I'd like to help.
Global Moderator
Postby pipingguy » Wed Dec 06, 2017 1:26 am
i tried it without benefit of a left hand plus a right hand rope. close enough. a little sanding and touch-up paint and no one will notice unless they are a basketball player. :D
some funny stuff in this link........
http://forums.finehomebuilding.com/brea ... miter-tips
pipingguy
Postby CJRyan » Sat Dec 09, 2017 2:25 am
Dave R wrote:The trick is to join both pieces of molding so either the high points or the low points on the edges meet.
Then miter them.
The "real" trick is to do it in situ. When a number of inside and outside corners have to match.
Get the Douzukinoko saw out! For numerous 1/32 inch cuts to adjust the length.
CJRyan
Premium Member
Premium Member
Return to Woodworking
