CutListAndMaterials
To access this forum when logged in, please, sign up to the Woodworking User Group in your User Control Panel.
CutListAndMaterials
Postby brandy20 » Thu Feb 12, 2009 1:05 pm
Hello everybody, I just downloaded CutListAndMaterials 3.3 and must say it's great. Just wondering if there a simple way to customize excel to make it accept the infos in a standardized way. I'm not a wizard in using excel but I think that with a little explanation I could get it. Thanks a lot! Luca
brandy20
Re: CutListAndMaterials
Postby Dave R » Thu Feb 12, 2009 1:46 pm
I suppose you could make up an Excel template into which you could import the CSV file generated by the plugin. I've thought about doing it but haven't actually done it. You'd want to figure out the maximum number of lines you're likely to need for the number of line items from the CSV. You could add columns for the math to make waste allowances and calculate costs.
You might want to delete CutListandMaterials3.3 since it is old stuff and switch to Cutlist 4 since it is the most current.
Global Moderator
Postby brandy20 » Thu Feb 12, 2009 3:30 pm
Tks a lot Dave, I'll start trying soon. I also wanna thank you for the very good job you're doing for the FWW blog. I'm learning a lot from it!
brandy20
Postby Dave R » Thu Feb 12, 2009 3:37 pm
Thank you and I'm glad to know it's helping.
Dave
Global Moderator
Postby brandy20 » Thu Feb 12, 2009 5:34 pm
I downloaded Cutlist 4 and put the ruby in the plugins folder but, when I run it I see the Internet Explorer page saying that "this program cannot display the webpage". Why? Maybe because I don't have the Pro version?
brandy20
Postby Dave R » Thu Feb 12, 2009 5:50 pm
The plugin runs on the free version. It sounds to me like itssomething to do with IE. Which version of Internet Explorer are you running?
Global Moderator
Postby brandy20 » Thu Feb 12, 2009 6:54 pm
IE 7. Sounds strange to me, too. I was use to use Firefox but the last version is so slow in my computer.
brandy20
Postby Dave R » Thu Feb 12, 2009 7:08 pm
That is odd.
I'm just trying to troubleshoot for you so I'm going to ask some questions.
Are you sure the computer is plugged in? :lol: Sorry, couldn't help it.
Look in the Plugins folder. You should have a folder called cutlistui and a file called CutListandMaterials.rb. Is that correct? And inside the cutlistui folder there should be two HTML files, cutlistresult.html and cutlistui.html? Are they there?
There are also a couple of Java script files. Do you have Java loaded on your computer?
Global Moderator
Postby brandy20 » Thu Feb 12, 2009 7:23 pm
Ok, let's start from the very beginning....so, YES, the computer is plugged in. ;)
I checked the files you told me and they are all there.
Another odd thing is that when I ran CutListAndMaterials there were two versions, one for SU5 and one for SU6. The SU5 worked correctly but the SU6 version gave me that strange IE message. My SU version is 6 dot something. I could try a new download. Maybe....
brandy20
Postby Dave R » Thu Feb 12, 2009 7:34 pm
Did you remove the old cutlistand materials plugin? If not, do that. Infact, just remove anything that says cutlist whatever. Then start with a fresh install. The current version of cutlist shouldn't give you separate menu entries referring to SU versions.
Global Moderator
Postby brandy20 » Thu Feb 12, 2009 7:39 pm
I did everything you said, nothing changes :mrgreen: I also checked for Java updates
Last chance, uninstall and install SU
brandy20
Postby Dave R » Thu Feb 12, 2009 7:52 pm
Reinstalling SU shouldn't be needed. Maybe throwing your computer into the river would help, though. ;)
Don't do anything else for the moment and let me do some research.
Global Moderator
Postby Dave R » Thu Feb 12, 2009 7:58 pm
Which operating system are you running?
And have you restarted SketchUp after reinstalling the plugin?
Global Moderator
Postby brandy20 » Thu Feb 12, 2009 8:48 pm
Win XP SP2 with the latest update and yes, SU was restarted.
brandy20
Postby Dave R » Thu Feb 12, 2009 8:52 pm
Alright. thanks. I'll contact my phsycho, er, I mean phsychic, and see what I find out. Think good thoughts and avoid sucking birds into your turbines.
Global Moderator
Postby brandy20 » Thu Feb 12, 2009 8:55 pm
Dave R wrote:Alright. thanks. I'll contact my phsycho, er, I mean phsychic, and see what I find out. Think good thoughts and avoid sucking birds into your turbines.
About good thoughts, I'm a positive guy :berserk:
About birds...well...I'll do my best!
brandy20
Postby brandy20 » Thu Feb 12, 2009 9:49 pm
Dave, I fixed the problem! I just made some movements in the plugin folder and now everything works fine. Thanks!
brandy20
Postby Dave R » Thu Feb 12, 2009 9:56 pm
Glad you got it fixed. What sort of "movements" did you make?
Global Moderator
Postby brandy20 » Thu Feb 12, 2009 10:07 pm
When I extracted the zip file there was a folder called cutlist_4.0.6 and inside that ther was the folder cutlistui and the file culistandmaterials.rb
The error I made is that I inserted the whole folder cutlist_4.0.6 in the plugins when I should have taken only the inside folder cutlistui and the file culistandmaterials.rb
The fact that the internet page appeared means that it can’t find the html file used as the interface for the plugin
This is due to my first time in using plugins. Next time it will be better.
Ciao!
brandy20
Postby Dave R » Thu Feb 12, 2009 10:23 pm
Ah yes. That would cause the problem.
Well, no worries. Enjoy.
Global Moderator
Postby david. » Fri Feb 13, 2009 12:18 am
One note about Java vs Javascript... they are two independent things. Javascript is a web based scripting language that is interpreted and runs within a browser, Java is not a scripting language. I doubt that the cutlist ruby depends on Java.
david.
Postby Dave R » Fri Feb 13, 2009 12:49 am
David, of course you are correct. I should have written javascript. I was in a rush when I was writing that.
Global Moderator
Return to Woodworking
