edit_transform not available in the C-API?
Postby pixelcruncher » Tue Sep 05, 2023 11:52 am
Hey folks,
SketchUp offers the edit_transform instance model for the model: https://ruby.sketchup.com/Sketchup/Model.html#edit_transform-instance_method - However, it seems that there's no equivalent in the C-API. I checked the documentation of the SUModelRef: https://extensions.sketchup.com/developers/sketchup_c_api/sketchup/struct_s_u_model_ref.html.
Am I not looking in the right place, or is there an alternative way to get the edit_transform?
Cheers,
Thomas
I am the creator of Rayscaper, an interactive, photorealistic render engine for SketchUp that is fun to use.
pixelcruncher
Premium Member
Premium Member
Re: edit_transform not available in the C-API?
Postby Dan Rathbun » Sun Feb 25, 2024 1:40 am
The C API is mainly written to act upon files.
There is only some limited things you can do with "live" models.
Currently, the C API cannot be used to modify the active model.
You can get the active edit path via: SUModelGetActivePath()
... and from it the transform via: SUInstancePathGetTransform()
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby pixelcruncher » Sun Feb 25, 2024 6:49 am
    Dan Rathbun wrote:The C API is mainly written to act upon files.
    Thanks, Dan, for the information! I solved it in my code by having a ModelObserver, implementing onActivePathChanged, and passing it to my C-extension code.
    Even though you cannot modify the active model, you still need to know the edit transformation for some cases. If a user opens a model to edit, if you query the instance transformation, it will be a world-coordinate transformation instead of a transformation relative to the parent. My C code assumes transformations relative to the parent, so I must calculate that using the edit transformation. You probably already knew this, but I'm putting it here for posterity.
    Cheers,
    Thomas
    pixelcruncher
    Premium Member
    Premium Member
    Return to Developers' Forum
    Users browsing this forum: No registered users and 9 guests
