The component information inside the group extract  Topic is solved
Postby themonty » Wed May 29, 2019 9:29 am
Hello, I'm a beginner in Ruby's development.
We are currently developing a Ruby to extract component information within the group.
The component information inside the group is extracted, but the component information within the group and within the group cannot be extracted.
Is there a way to continue searching for a child group by applying a repeat statement to get some component information?
code :
Code: Select all
sel.each do |ss|
  if not ss.class == Sketchup::Group
    UI.messagebox ('그룹을 선택해 주세요')
    return
  #@group_names.push(ss.name)
  #@num_entities.push(ss.entities.length)
  #각 인스턴스 별 Definition 이름을 @name 배열에 넣는다.
  ss.entities.each do |e|
    if e.class == Sketchup::ComponentInstance
      if e.definition.name.include? '-' or e.definition.name.include? '_'
        if e.definition.name.include? '~'
          ename = e.definition.name.gsub!('~','')
        else
        if ename.include? '#'
          @names.push(ename.split('#')[0].strip)
        else
          @names.push(ename)
    elsif e.class == Sketchup::Group
      e.entities.each do |ee|
        if ee.definition.name.include? '-' or ee.definition.name.include? '_'
          if ee.definition.name.include? '~'
            ename = ee.definition.name.gsub!('~','')
          else
          else
            @names.push(ename)
  end #ss.each에 대한 END
  #@name의 배열 순서를 정렬한다.
  @names = @names.sort!
  #@name의 배열을 같은 내용을 묶어 해시로 통합한다.
  hash_overlap = @names.each_with_object(Hash.new(0)) { |word,counts| counts[word] += 1 }
  @comp_names = (hash_overlap.to_a)
    #comp_names의 내용을 h, b, t1, t2, length별로 분류한다.
    @comp_names.each do |str|
      num = str[0].split('-')[1].strip
      i = 0
      while i < num.count('X') + 1
          str.push(num.split('X')[i].strip)
          i = i + 1
      #str.push(num.split('X')[1].strip)
      #str.push(num.split('X')[2].strip)
      #str.push(num.split('X')[3].strip)
      #str.push(num.split('X')[4].strip)
  @hash_names.store(ss.name, @comp_names)
  @names = []
  hash_overlap = {}
end #sel.each에 대한 end
themonty
Re: The component information inside the group extract
Postby TIG » Wed May 29, 2019 10:29 pm
I reformatted your code using [ code ] rather than [ruby ] tags.
Your Korean strings are also confusing ;)
Here's the outline of a way... missing out the 'naming tests' you seemed to use...
Code: Select all
def start_process()
  @model=Sketchup.active_model
  @ss=@model.selection
  @hash={}
  @ss.grep(Sketchup::Group).each{|group|
    do_group(group)
  p @hash ### output or more processing ?
def do_group(group)
  name=group.name
  name=group.definition.name if name.empty?
  @hash[name]=[]
  group.entities.each{|e|
    if e.is_a?(Sketchup::Group)
      e.entities.each[|ee| do_group(group) }
    elsif e.is_a?(Sketchup::ComponentInstance)
      e.definition.entities.each{|ee|
        if ee.is_a?(Sketchup::Group)
          ee.entities.each{|eee| do_group(eee) }
        elsif ee.is_a?(Sketchup::ComponentInstance)
          @hash[name] << ee.definition.name
Run it using start_process()
You should get @hash returned as a hash divided up by group name, with each value an array of nested component names...
Global Moderator
Postby themonty » Thu May 30, 2019 2:50 am
Thank you for your answer.
As you execute the code you sent, Error: #SystemStackError: stack level too deep]
There's a message.
I will upload the sketchup file.
I want to extract the name of the Component Instance Definition in each group.
themonty
Postby TIG » Thu May 30, 2019 12:05 pm
I haven't tested the code - I gave it as a simple example of iterative methods.
There's probably a typo in it - the full error-message would point you to the faulty line...
Tested: typo in line#16
should be:
e.entities.each{|ee| do_group(group) }
There's still an error - I'm looking into it now...
Global Moderator
Re: The component information inside the group extract  Topic is solved
Postby TIG » Thu May 30, 2019 2:21 pm
I think this does what you want:
Code: Select all
def start_process()
  @coll={}
    name=group.name
    @coll[name]={}
    do_group(group, name)
  puts @coll ### output or more processing ?
def do_group(group, name)
  @coll[name]={} unless @coll[name]
      nname=e.name
      nname=e.definition.name if nname.empty?
      @coll[name][nname]={} unless @coll[name][nname]
      e.entities.grep(Sketchup::Group).each{|g|
        dname=g.name
        dname=g.definition.name if dname.empty?
        @coll[name][nname][dname]={}  unless @coll[name][nname][dname]
        do_group(g, dname)
      e.entities.grep(Sketchup::ComponentInstance).each{|c|
        dname=c.definition.name
        @coll[name][nname]['compos']=[] unless @coll[name][nname]['compos']
        @coll[name][nname]['compos'] << dname
      dname=e.definition.name
      @coll[name]['compos']=[] unless @coll[name]['compos']
      @coll[name]['compos'] << dname
#start_process()
It returns a hash of the (nested) groups, and a hash entry 'compos' which is an array of the nested component-instances...
Global Moderator
Postby themonty » Fri May 31, 2019 1:12 am
Thank you for your help.
It works perfectly.
Thank you again.
themonty
Return to Developers' Forum
