Undoing all transformations  Topic is solved
Postby Frankn » Tue Aug 28, 2018 6:28 pm
I'm pretty sure I've seen this before but I can't find the answer... so sorry in advanced if this is a repeat question.
I'd like to remove all transformation for a given instance... so basically reverse what ever moves and rotations were done.
I can get the transformation array,
Code: Select all
e.transformation.to_a
and i tried setting everything back to 0 bu that didn't work...
Frankn
Re: Undoing all transformations  Topic is solved
Postby sdmitch » Wed Aug 29, 2018 2:51 pm
Maybe this?
Code: Select all
mod = Sketchup.active_model
ent = mod.entities
sel = mod.selection
cmp=sel.first
t=cmp.transformation.to_a
t[0]=1;t[1]=0;t[2]=0;#t[3]=nil
t[4]=0;t[5]=1;t[6]=0;#t[7]=nil
t[8]=0;t[9]=0;t[10]=1;#t[11]=nil
t[12]=0;t[13]=0;t[14]=0;#t[15]=nil
cmp.transformation=cmp.transformation.set! t
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby Frankn » Thu Aug 30, 2018 7:08 pm
sdmitch, just had a chance to try it out and it does work...
Thanks!
Frankn
Postby fredo6 » Fri Aug 31, 2018 6:40 pm
Also, to reset all transformations and puts the instance g at the origin, just use
g.transformation = Geom::Transformation.new
If you have a state before some transformations are made to the instance, you can save the state with (clone is important)
tr0 = g.transformation.clone
Then, later, you can resume this state with
g.transformation = tr0
Note that the transformation of an instance corresponding to g.transformation is always in the context of its parent.
fredo6
PluginStore Author
PluginStore Author
Postby Frankn » Sat Sep 08, 2018 6:05 pm
Thanks for all that info fredo... It'll certainly come in handy
Frankn
Return to Developers' Forum
cron
Users browsing this forum: No registered users and 6 guests
