Geom::Transformation
Postby anteolic » Fri Aug 11, 2017 1:03 pm
I am totaly beginner in Sketchup scripting.
This code move object to some position,
trans = Geom::Transformation.new(bb.center.vector_to([100,0,0])) ; # move the temp bounding box
How is posible to move object just by zaxis and other axis dont affect.
anteolic
Re: Geom::Transformation
Postby TIG » Fri Aug 11, 2017 1:25 pm
Your example uses a point [100,0,0] to move the object 100 inches along the X_AXIS.
To move it in the Z_AXIS just try [0,0,100]
Also it'll be best to do a simple 'translate' rather than '[re]locate' it ?
trans = Geom::Transformation.translation([0, 0, 100])
A three element array can be substituted for a point or a vector.
If you want units other than inches do it like this 100.mm
Global Moderator
Postby anteolic » Fri Aug 11, 2017 1:33 pm
I have some object with his location, and select it and i want just to move this object to zaxis=0, and leave other axis unchanged.
anteolic
Postby TIG » Fri Aug 11, 2017 3:02 pm
Slightly different question.
If you want to move its center onto the ground-plane [z=0], consider this...
bb = some_object.bounds
ct = bb.center
pt = ct.clone
pt.z = 0
ve = ct.vector_to(pt)
tr = Geom::Transformation.translation(ve)
some_object.transform!(tr)
Global Moderator
Postby anteolic » Fri Aug 11, 2017 4:26 pm
Thanks!
anteolic
Return to Developers' Forum
Users browsing this forum: No registered users and 7 guests
