SketchUp Update Broke the Foundation Plugin
Postby medeek » Mon Jul 17, 2017 2:06 am
I'm not entirely sure what has changed but I just noticed that the "face" tool of the slab-on-grade foundation is throwing an error after I updated SketchUp (SketchUp 2017), everything is working fine in previous versions of SketchUp:
Error: #<NoMethodError: undefined method `volume' for #<Geom::BoundingBox:0x0000000f7b2488>>
c:/users/administrator/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/medeek_foundation_ext/medeek_sog_trim_rebar.rbs:104:in `trim_rebar'
I've indicated the exact line where the error is happening below.
The code is:
Code: Select all
# Slab on Grade (TRIM REBAR) Methods
def sog_trim_rebar (slabgroup, rebargroup, profileface, edgedistance)
 # Initialization
 @mod = Sketchup.active_model
 @ent = @mod.active_entities
 # Profile Face
 @face = profileface
 @slab_ents = slabgroup.is_a?(Sketchup::Group) ? slabgroup.entities : slabgroup.definition.entities
 @slab_trns = slabgroup.transformation
 @rebar_ents = rebargroup.is_a?(Sketchup::Group) ? rebargroup.entities : rebargroup.definition.entities
 @rebar_trns = rebargroup.transformation
 MedeekMethods.face_inset(@face,edgedistance)
 v3 = @face.normal
 v3.length = 24
 @bf = @ent.add_group
 @bfe = @bf.entities
 @bft = @bf.transformation
 last = @o_pts.length - 1
 0.upto(last) do |i|
  @bfe.add_face(MedeekMethods.make_a_face(@o_pts[i],@o_pts[i-last],v3))
 face = @ent.add_face(@o_pts)
 MedeekMethods.trim_rebar(rebargroup,face)
 @bf.erase!; @ent.erase_entities(face.edges);
def trim_rebar(ci,f)
 plane = f.plane;
 bb=Geom::BoundingBox.new;
 0.upto(7){|i|bb.add ci.bounds.corner(i)}
 [b]unless bb.intersect(@bf.bounds).volume == 0.0[/b]
  ci.make_unique; cit = ci.transformation;
  cde = ci.is_a?(Sketchup::Group) ? ci.entities : ci.definition.entities;
  new = cde.intersect_with(false,cit,cde,cit,false,@bf)
  if new
   # puts "Finding clipped edges"
   rmv = cde.grep(Sketchup::Edge).select{|e|
            !new.include?(e) && f.classify_point(e.midpnt.transform(cit).project_to_plane(plane))==16
   # puts "Erasing clipped edges"
   cde.erase_entities(rmv)
   unless ci.manifold?
    # puts "Making manifold"
    new.grep(Sketchup::Edge).each{|e|e.find_faces if e.valid?}
def make_a_face(p1,p2,v)
 pts=[];
 pts<<p1.offset(v)
 pts<<p2.offset(v)
 pts<<p2.offset(v.reverse)
 pts<<p1.offset(v.reverse)
 return pts
def face_inset(face,dist)
 @c_pts=face.outer_loop.vertices.collect{|v|v.position};
 last = @c_pts.length-1;@o_pts = []
 0.upto(last) do |a|
  vec1 = (@c_pts[a]-@c_pts[a-last]).normalize
  vec2 = (@c_pts[a]-@c_pts[a-1]).normalize
  unless vec1.parallel? vec2
   vec3=(vec1+vec2).normalize
   ang = vec1.angle_between(vec2)/2;
   if vec3.valid?
    vec3.length = -dist/Math::sin(ang);
    vec3.reverse! if face.classify_point(@c_pts[a].offset(vec3))==16
    t = Geom::Transformation.new(vec3)
    @o_pts << @c_pts[a].transform(@slab_trns*t)
Nathaniel P. Wilkerson PE
Medeek Engineering Inc
design.medeek.com
medeek
PluginStore Author
PluginStore Author
Re: SketchUp Update Broke the Foundation Plugin
Postby Dan Rathbun » Tue Jul 18, 2017 9:40 pm
medeek wrote:I've indicated the exact line where the error is happening below.
You cannot use bbCode bold tags inside a bbCode code block.
Try marking errors inside code using comments like:
erroneous code # <<<<<<<<<<--------------<<<<<<<< ERROR !
Or, bracketing:
# THIS DOES NOT WORK
result = some_code()
a = b + result
Regarding your NoMethodError error. The BoundingBox class does not have (nor ever did,) an instance method named volume(). So I doubt that it could work as intended on older versions.
EDIT: However, it is possible you were relying upon a modification to the BoundingBox class made by some extension that you've not loaded in the latest version ? (Generally, you should not rely upon API modifications made by other extensions.)
You also seem to have ignored the advice in the API docs concerning the BoundingBox#intersect method.
You'd have to either define a singleton volume() method and attach to that single object:
Code: Select all
module BB_Volume
  def volume()
    height * width * depth
bb_obj.extend(BB_Volume)
unless bb_obj.volume == 0.0
  # do code here
OR .. just use the Geom::BoundingBox#empty? method:
Code: Select all
unless bb_obj.empty?
  # do code here
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby TIG » Tue Jul 18, 2017 9:53 pm
    As Dan says, bounds does not have a method .volume !
    Also, don't leave a space between a method and its arguments:
    should be
    def sog_trim_rebar(slabgroup, rebargroup, profileface, edgedistance)
    etc...
    Global Moderator
    Postby Dan Rathbun » Tue Jul 18, 2017 10:16 pm
    I would also suggest avoiding naming objects "new" as this is the standard name for the class constructor method. This could confuse the Ruby interpreter under some situations, as it must decide whether you are trying to make a method call or creating a local reference of the same name.
    The idea is to train yourself to avoid hard to find errors.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby medeek » Wed Jul 19, 2017 2:13 am
      Dan you are a SketchUp Wizard.
      Sure enough after I did a bit of digging about I found two class modifications that I was relying on that somehow got deleted from my plugins folder:
      class Sketchup::Edge
      def midpnt
      Geom::Point3d.linear_combination(0.5, self.start.position, 0.5, self.end.position)
      class Geom::BoundingBox
      def volume
      vol = self.width*self.height*self.depth
      vol = vol<1.0e+30 ? vol : 0.0
      Which basically tells me that the rebar for the slab-on-grade foundation was never working for anyone except me (polygon and face tool)
      design.medeek.com
      medeek
      PluginStore Author
      PluginStore Author
      Postby medeek » Wed Jul 19, 2017 2:15 am
      I never said I was good at programming in Ruby or dealing with the API, actually I'm very weak in that regard. I know just enough to get me into trouble. I'm surprised that I have gotten as far as I have with these plugins.
      design.medeek.com
      medeek
      PluginStore Author
      PluginStore Author
      Postby TIG » Wed Jul 19, 2017 1:25 pm
      You should not modify or add to shipped modules/classes - like Sketchup and Geom.
      It won't get past the EWH audit.
      It's easy enough to define similar methods inside your own module[s]...
      Code: Select all
      def midpt(edge)
        Geom::Point3d.linear_combination(0.5, edge.start.position, 0.5, edge.end.position)
      Used thus, passing it an edge:
      mpt = midpt(edge)
      returns a point...
      and
      Code: Select all
      def bbvol(bb)
        vol = bb.width*bb.height*bb.depth
        vol = vol < 1.0e+30 ? vol : 0.0
      Used thus, passing it a bounding-box:
      vol = bbvol(bb)
      returns a float volume...
      Global Moderator
      Postby Dan Rathbun » Wed Jul 19, 2017 5:49 pm
      Or single object extension via mixin module (as shown above.)
      Code: Select all
      unless bb.extend(BB_Volume).volume == 0.0
        # do code here
      Or if only supporting Ruby 2.x+ SketchUp versions, you can use class refinements that are only active within your files.
      See: http://ruby-doc.org/core-2.0.0/doc/syntax/refinements_rdoc.html
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Return to Developers' Forum
        Users browsing this forum: No registered users and 5 guests
