Uninitialized class variable
Postby Pixero » Sat Jun 03, 2017 8:21 pm
I'm trying to make a script remember the values the user puts in during a SketchUp session so that he wont have to re enter them every time the script is run.
When for example using:
Code: Select all
module Mymodule
  class Myclass
  def initialize
    #Setting default values
    @myvariable = 25.mm unless @myvariable
    #And so on......
the script works but wont remember the settings when run again.
When using @@myvariable = 25.mm unless @@myvariable
I get a "Uninitialized class variable" error message.
What am I doing wrong?
Pixero
Premium Member
Premium Member
Re: Uninitialized class variable
Postby sdmitch » Sat Jun 03, 2017 8:33 pm
Pixero wrote:I'm trying to make a script remember the values the user puts in during a SketchUp session so that he wont have to re enter them every time the script is run.
Code: Select all
module Mymodule
  class Myclass
  def initialize
    #And so on......
You just need to make a dummy assignment to it just after class declaration.
Code: Select all
module Mymodule
  class Myclass
  @@myvariable=nil
  def initialize
    @@myvariable = 25.mm unless @myvariable
    #And so on......
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby Pixero » Sat Jun 03, 2017 9:05 pm
Should it be @@myvariable = nil and then @myvariable with just one @ or was that a typo?
Pixero
Premium Member
Premium Member
Postby sdmitch » Sat Jun 03, 2017 9:24 pm
Pixero wrote:Should it be @@myvariable = nil and then @myvariable with just one @ or was that a typo?
I just copied your code and added the @@myvariable=nil to it. The typo, @myvariable, was in your original code.
It should be @@myvariable everwhere.
sdmitch
PluginStore Author
PluginStore Author
Postby Pixero » Sun Jun 04, 2017 1:23 pm
Thanks, that worked.
Pixero
Premium Member
Premium Member
Return to Developers' Forum
Users browsing this forum: archano, Cleo123, Vishnu Ram K and 4 guests
