Trouble finding faces
I am using an If else statement, I got it to work earlier in the code, but now I am having an issue grouping a new entity and finding it's face, it has to do with adding an arc and not adding an arc.
How would one name a group and find the faces in this situation?
ents=Sketchup.active_model.active_entities prompts = ["Stair Width", "Travel","Tread Thickness","Total Height","Riser Thickness","Stringer Width","Stringer Thickness","Top Hanger Thickness","Customer","Customer Address","Top Hanger Nose","Round Nose","Flight","No Nose"] defaults = [36.0,51.5,1.5,46.5,0.5,11.25,1.25,0.5,"My Builder", "234 Jimmys street","Yes","Yes","Main","Yes"] list=["","","","","","","","","","", "Yes|No","Yes|No","Main","Yes|No"] input = UI.inputbox prompts, defaults,list, "Stair Info" a,b,c,d,e,f,g,h,i,j,k,l,m,n=input cst=i.to_s adr=j.to_s ent = Sketchup.active_model.entities tr=(d/8.0).ceil rise=d/tr run=((b-(1+h))/(tr-1)) wdth=a-2.5 prompts = ["Stair Width", "Number if Rises","Height","Travel","Hanger"] defaults = [36.0,tr,d,b,h] list=[""] input = UI.inputbox prompts, defaults,list, "Rise and Run" wth,rs,b,d,h=input cst=i.to_s adr=j.to_s ent = Sketchup.active_model.entities l rise=b/rs run=((d-(1+h))/(rs-1)) #---------Clear All Sketchup.active_model.entities.clear! #----------------Make 1st tread ent.add_line [0,(run+1)+0*run-1.5,rise-c], [0,(1.5+0*run)-1.5,rise-c] ent.add_line [0,1.5+0*run-1.5,rise-c+0.1875], [0,1.5+0*run-1.5,rise-c] ent.add_line [0,1.5+0*run-1.5,rise-c+0.1875], [0,1+0*run-1.5,rise-c+0.1875] ent.add_line [0,1+0*run-1.5,rise-c+0.1875], [0,1+0*run-1.5,rise-c] #Nose Yes/No<<<<< if n=="Yes" ns=1 else ns=0 end puts ns puts d #End add nose<<< #ROUND Nose Yes/No<<<<<< if l=="Yes" puts "Round Nose" #add arc<<<<<< edg = ent.add_line [0,1+0*run-1.5,rise-c],[0,e+0*run-1.5,rise-c];vrt1=edg.end ent.add_arc [0,0.5+0*run-1.5,-c/2.0+(rise)],[0,0,-1],[-1,0,0],c/2.0,0,180.degrees,12 edg = ent.add_line [0,1+run-1.5,rise],[0,0.5-1.5,rise];vrt2=edg.start #end Add Arc<<<<< else edg = ent.add_line [0,1+0*run-(1+0.5),rise-c],[0,e+0*run-(ns+1),rise-c] edg = ent.add_line [0,e+0*run-(ns+1),rise-c],[0,e+0*run-(ns+1),rise] edg = ent.add_line [0,e+0*run-(ns+1),rise],[0,(run+1)+0*run-1.5,rise] puts "SQUARE NOSE" end edg=ent.add_line [0,1+run-1.5,rise],[0,1+run-1.5,rise-c] edg.find_faces; face=edg.faces[0] face.pushpull wdth if l=="Yes" edgs=vrt1.edges.reject!{|e| e.length<wdth};edgs[0].soft=true edgs=vrt2.edges.reject!{|e| e.length<wdth};edgs[0].soft=true else end group1 = ent.add_group face.all_connected ;group1.name="Tread" group1.description="Tread" for i in 1..tr-2 group2 = group1.copy tran = Geom::Transformation.translation [0, run*i, rise*i] group2.transform! tran end ents=Sketchup.active_model.active_entities #---Good group = ent.add_group(); group.name="Bottom riser" ent2 = group.entities pts = [] pts[0] = [0, 0, 0] pts[1] = [0,-e,0] pts[2] = [0, -e,rise-c+0.1875] pts[3] = [0, 0, rise-c+0.1875] # Add the face to the entities in the model face = ent2.add_face pts face.pushpull wdth group.description = "Bottom riser" #---good group = ent.add_group(); group.name="Riser" ent3 = group.entities pts = [] pts[0] = [0, run, rise-c] pts[1] = [0,run-e,rise-c] pts[2] = [0, run-e,2*rise-c+0.1875] pts[3] = [0, run, 2*rise-c+0.1875] # Add the face to the entities in the model face = ent3.add_face pts face.pushpull wdth group.description = "Riser" for i in 1..rs-3 group2 = group.copy tran = Geom::Transformation.translation [0, run*i, rise*i] group2.transform! tran end #----good #<<<<<<Top Hanger group = ent.add_group(); group.name="Top riser" ent5 = group.entities ent5.add_line [0,b+3,b-c], [0,b+3,b-15] ent5.add_line [0,b+3,b-15], [0,b+3+h,b-15] ent5.add_line [0,b+3+h,b-15], [0,b+3+h,b] #ROUND Nose Yes/No<<<<<< if l=="Yes" puts "top hanger round nose" #add arc<<<<<< edg = ent5.add_line [0,b+3,b-c], [0,b+3-0.5,b-c] ;vrt1=edg.end ent5.add_arc [0,b+3-0.5,b-(c/2)],[0,0,b+3-1],[-1,0,0],-c/2.0,0,180.degrees,12 edg = ent5.add_line [0,b+3+h,b], [0,b+2.5,b];vrt2=edg.start #end Add Arc<<<<< else puts "top hanger square nose" ent5.add_line [0,b+3,b-c], [0,b+3-1,b-c] ent5.add_line [0,b+3-1,b-c], [0,b+3-1,b] ent5.add_line [0,b+3-1,b] , [0,b+3+h,b] end #add the face to the entities in the model edg.find_faces; face=edg.faces[0] face.pushpull -wdth
It seems to me that you define 'edg' twice if l=="Yes" but don't define it at all if l=='No'.
#ROUND Nose Yes/No<<<<<< if l=="Yes" puts "top hanger round nose" #add arc<<<<<< edg = ent5.add_line [0,b+3,b-c], [0,b+3-0.5,b-c] ;vrt1=edg.end ent5.add_arc [0,b+3-0.5,b-(c/2)],[0,0,b+3-1],[-1,0,0],-c/2.0,0,180.degrees,12 edg = ent5.add_line [0,b+3+h,b], [0,b+2.5,b];vrt2=edg.start #end Add Arc<<<<< else puts "top hanger square nose" edg=ent5.add_line [0,b+3,b-c], [0,b+3-1,b-c]#<<<< edg ent5.add_line [0,b+3-1,b-c], [0,b+3-1,b] ent5.add_line [0,b+3-1,b] , [0,b+3+h,b] end #add the face to the entities in the model edg.find_faces; face=edg.faces[0] face.pushpull wdth
