Entity ID and Materials!
Postby Marc477 » Wed Sep 10, 2014 4:16 am
I discovered that the entityID (for materials) is not the same when getting it from the Ruby API or the cpp SDK:
Example (using the same material in both example)
Ruby API
Code: Select all
//aMat is a material
aMat.entityID
//Returns 183
Cpp SDK
Code: Select all
//aMat is a SUMaterialRef
int id;
SUEntityRef entity = SUMaterialToEntity(aMat );
SUEntityGetID(entity , &id);
uint matID = (uint) id;
//Returns 201
I tested this using a custom attribute dict to make sure it is the same material in both cases, it seems that the material in the SDK has always an ID of +18, and if I don't cast it to a uint, its value is always negative.
Why ? :? :roll:
Marc477
Re: Entity ID and Materials!
Postby tt_su » Thu Sep 11, 2014 11:00 am
entityID are not persistent. They are not serialize in the SKP file format. Whenever you read a file they are regenerated.
tt_su
SketchUp Team
SketchUp Team
Postby Marc477 » Fri Sep 12, 2014 9:13 pm
Then how can I find: starting from a ruby API material: the corresponding SDK material ?
Marc477
Postby Marc477 » Fri Sep 12, 2014 9:17 pm
I don't really understand how it is possible to have no persistent ID. In the skp file: how each face knows to which material it is bound? I supposed there is an ID saved with the face that tells which material is linked to the face.
Marc477
Postby TIG » Fri Sep 12, 2014 11:23 pm
Any Material will have a unique '.name'.
So that is effectively its 'ID' spanning sessions...
Global Moderator
Postby tt_su » Mon Sep 15, 2014 10:46 am
The serialization and serialization use its own way to store the material references for each face. But entityID is not something restored between sessions. As TIG mentions, the material name is the persistent ID for materials.
tt_su
SketchUp Team
SketchUp Team
Postby Marc477 » Tue Sep 16, 2014 1:20 am
Ok thank you! I though 2 materials could have the same name.
Marc477
Postby jiminy-billy-bob » Tue Sep 16, 2014 6:58 am
tt_su wrote:As TIG mentions, the material name is the persistent ID for materials.
But the name can change, right? How is that a persistent ID?
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby tt_su » Tue Sep 16, 2014 8:04 am
It's persistent in the sense that it will have the same name when you reopen the file and for as long as until you change it - as oppose to entityID which will change. And it's an ID because you cannot have two identical material names in a model.
tt_su
SketchUp Team
SketchUp Team
Postby jiminy-billy-bob » Tue Sep 16, 2014 9:05 am
Yeah but the plugin has to be installed and active to keep track of name changes.
As opposed to groups/instances GUIDs which will remain the same no matter what. The plugin will always be able to retreive it.
For me that's a huge difference.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby tt_su » Tue Sep 16, 2014 10:31 am
jiminy-billy-bob wrote:Yeah but the plugin has to be installed and active to keep track of name changes.
Yes a GUID is a different animal. I see where you are coming from.
tt_su
SketchUp Team
SketchUp Team
Postby TIG » Tue Sep 16, 2014 1:52 pm
In that case you need to give the material you want to keep track of an attribute that will endure across sessions and is thereby independent of its 'name' etc.
tid = Time.now.to_f
some_material.set_attribute("matID", "tid", tid)
Now save 'tid' in some meaningful data collection 'external' to the SKP, or say in an array in an attribute dictionary attached to the model itself...
Later on you reopen the model and you want to find a specific material that has some recovered 'tid' float value...
material = nil
model.materials.each{|mat|
if tid == mat.get_attribute("matID", "tid", nil)
material = mat
break
If the material has been deleted you get no match - material == nil - and you adjust your stored data collection accordingly.
Otherwise it exists...
You can also batch process a model.materials, and if there is not one already you add a 'matID' with a 'tid' attribute to each material, and also update the stored data collection...
Global Moderator
Postby jiminy-billy-bob » Tue Sep 16, 2014 1:56 pm
Yeah TIG, I already do just that with layers :)
But calling the name a "persistent ID" was not right to me.
jiminy-billy-bob
PluginStore Author
PluginStore Author
Postby Marc477 » Wed Sep 17, 2014 3:14 am
Also, I found that 2 materials CAN have the same name in a specific case: If you name one material Color_000 for example, it will be named like the Sketchup internal material of the same name: [Color_000]. (It seems that the SDK removes the brakets '[' and ']' when you get the name of an internal material with SUMaterialGetName()).
Marc477
Postby tt_su » Wed Sep 17, 2014 9:14 am
Ah, yea - there is name and display_name - at least in the Ruby API. name is the unique one that should be used to refer to materials. display_name should be used only to display the material name to the UI.
However, it appear that the C API doesn't quite do that. Let me have a chat with the rest of the team.
tt_su
SketchUp Team
SketchUp Team
Return to Developers' Forum
Users browsing this forum: No registered users and 12 guests
