Move points to a '3D grid'
Postby rossthompson » Mon Mar 26, 2012 12:10 pm
I am trying to write a script for cleaning up geometery created from another program (IES VE). Essentially what I want to achieve is to move each vertex so it sits on a '3D grid'. I believe this could be achieved by applying a rounding function to the X,Y and Z coordinates of each point.
The attached image hopefully illustrates what I am trying to achieve. Ideally the degree of rounding would be a user input variable.
Any help on this would be greatly appreciated.
Ross
rossthompson
Re: Move points to a '3D grid'
Postby gilles » Mon Mar 26, 2012 12:51 pm
You can use the scale tool: begin to scale then type 400mm;400mm;400mm + enter.
Note that the separator may be "," for you .
gilles
Top SketchUcator
Postby thomthom » Mon Mar 26, 2012 12:57 pm
gilles wrote:You can use the scale tool:
rossthompson wrote:I am trying to write a script
PluginStore Author
PluginStore Author
Postby thomthom » Mon Mar 26, 2012 1:01 pm
This is a nice idea - I might implement such a feature in Vertex Tools.
Of the top of my head, something like this:
pt = Geom::Point3d.new( 3.976879, 3.970209, 1.002568 )
grid_pt = pt.to_a.map { |n| n.round() }
v = pt.vector_to( grid_pt )
You can do something like that - iterate the vertices of a mesh, for each vertex find the nearest grid position to the vertex, collect the vertex and adjustment vector to each their array and use Entities.transform_by_vectors https://developers.google.com/sketchup/ ... by_vectors
Note that this simple example rounded to nearest whole number. Modifications is needed to account for grids fitted to decimal precision.
PluginStore Author
PluginStore Author
Actually, that example will round to nearest inch - which is SketchUp's internal unit...
PluginStore Author
PluginStore Author
Postby thomthom » Mon Mar 26, 2012 1:15 pm
Code: Select all
pt = Geom::Point3d.new( 3.976879.m, 3.760209.m, 1.002568.)
tolerance = 0.25.m
grid_pt
= pt.to_a.map { |n|
  b = ( n / tolerance ).to_i * tolerance
  r
= n % tolerance
(> tolerance / 2) ? b + tolerance : b
grid_pt = Geom::Point3d.new( *grid_pt )
puts "Original: #{pt}"
puts "Tolerance: #{tolerance}"
puts "Grid Point: #{grid_pt}"
Output:
Original: (3976,879mm, 3760,209mm, 1002,568mm)
Tolerance: 250mm
Grid Point: (4000mm, 3750mm, 1000mm)
PluginStore Author
PluginStore Author
Postby thomthom » Mon Mar 26, 2012 1:35 pm
Test module - adjust the vertices in the active context to grid.
Code: Select all
module GridSnap
  def self
.round_pointpointtolerance )
grid_pt point.to_a.map { |n|
= ( tolerance ).to_i tolerance
      r
tolerance
(tolerance 2) ? tolerance b
  def self
.test_it
    pt
Geom::Point3d.new( 3.976879.m3.760209.m1.002568.)
tolerance 0.25.m
    grid_pt
self.round_pointpttolerance )
  def self
.adjust_verticestolerance 0.25.)
model Sketchup.active_model
    vertices
# Collect vertices.
for e in model.active_entities
      vertices
<< e.vertices if e.is_a?( Sketchup::Edge )
    vertices
.flatten!
vertices.uniq!
# Calculate grid adjustments.
vectors = []
entities = []
    for
vertex in vertices
      pt
vertex.position
      grid_pt
vector pt.vector_togrid_pt )
next unless vector.valid?
entities << vertex
      vectors
<< vector
# Apply transformations
model.active_entities.transform_by_vectorsentitiesvectors )
puts "#{entities.size} adjusted to grid."
PluginStore Author
PluginStore Author
Postby Dan Rathbun » Mon Mar 26, 2012 1:54 pm
How about that ??
... from concept to module in under a hour. :thumb:
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby TIG » Mon Mar 26, 2012 2:02 pm
    Could this then be a tiny step towards a poly-reducer?
    As the vertices are 'rationalized' onto a 'grid' some faces could become coplanar and therefore the superfluous shared edges could be removed.
    The fineness/coarseness of this 'grid' removes less/more 'detailing'... :?
    Global Moderator
    Postby thomthom » Mon Mar 26, 2012 2:09 pm
    Cubificator?
    I was thinking it might be usable to repair troublesome model imported from CAD drawings. Occasionally I run into models where splitting a face with an edge results in duplicate faces. I suspect its due to some precision errors. Maybe if the vertices where adjusted to fit to a finely grained 3D grid the troubles would go away... ?
    PluginStore Author
    PluginStore Author
    Postby rossthompson » Mon Mar 26, 2012 3:13 pm
    ThomThom thanks so much for your support! I have had a go at running your test module. My understanding is that it should shift the points in the active selection to a 0.25m grid as specified in the code.
    However I am having problems running the module. I have attempted to add it to the tools menu as below, but I am not 100% sure how to 'call' the routine. Appologies if I'm being an idiot - I am new to ruby scripting!
    Code: Select all
        module GridSnap
          def self.round_point( point, tolerance )
            grid_pt = point.to_a.map { |n|
              r = n % tolerance
              (r > tolerance / 2) ? b + tolerance : b
          def self.test_it
            pt = Geom::Point3d.new( 3.976879.m, 3.760209.m, 1.002568.m )
            tolerance = 0.25.m
            grid_pt = self.round_point( pt, tolerance )
          def self.adjust_vertices( tolerance = 0.25.m )
            model = Sketchup.active_model
            vertices = []
            # Collect vertices.
              vertices << e.vertices if e.is_a?( Sketchup::Edge )
            vertices.flatten!
            vertices.uniq!
            vectors = []
            entities = []
            for vertex in vertices
              pt = vertex.position
              vector = pt.vector_to( grid_pt )
              entities << vertex
              vectors << vector
            model.active_entities.transform_by_vectors( entities, vectors )
    # Menu Entry:
    UI.menu("Tools").add_item("GridSnap") { GridSnap } if not file_loaded?("GridSnap.rb")
    file_loaded("GridSnap.rb")
    I think this could be a very useful tool for cleaning many types of imported geometry.
    Ross
    rossthompson
    Postby Dan Rathbun » Mon Mar 26, 2012 3:21 pm
    thomthom wrote:Cubificator?
    Polyhedronizer ?
    Orthogonizer ?
    Orthographizer ?
    OrthograFixer ?
    :lol:
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby TIG » Mon Mar 26, 2012 3:24 pm
      In case TT is away...
      Inside the code making the menu use
      {GridSnap.adjust_vertices(1.cm)}
      It affects the whole model.
      This example uses 1cm grid
      Use another 'tolerance' if desired...
      If you use () it defaults to 0.25m anyway...
      It's only some example code and could be better assembled into something working on a selection with warnings and an 'undo' ???
      Global Moderator
      Postby TIG » Mon Mar 26, 2012 3:43 pm
      Not sure this reduced poly rock is so good ?
      'Cuboidalizer' is another name idea too... that or 'Discombobulizer' :shock:
      Global Moderator
      Postby Dan Rathbun » Mon Mar 26, 2012 3:49 pm
      Here's a beta version with an inputbox and undo operation...
      It seemed to only change a cubes vertices in the Z axis ??
      Code: Select all
      module GridSnap
        @@last_tolerance = 0.25.m
        class << self # PROXY CLASS
          def round_point( point, tolerance )
              r = n % tolerance
          def test_it
            tolerance = @@last_tolerance
            grid_pt = round_point( pt, tolerance )
          def adjust_vertices( tolerance = @@last_tolerance )
            vertices = []
            # Collect vertices.
            vertices.flatten!
            vertices.uniq!
            vectors = []
            entities = []
              entities << vertex
              vectors << vector
          def menu_command()
            title   = 'Adjust Vertices'
            prompt  = 'Tolerance'
            default = @@last_tolerance
            result = UI.inputbox([prompt],[@@last_tolerance],title) rescue @@last_tolerance
            if result
              begin
                Sketchup.active_model.start_operation("#{title} (#{Sketchup.format_length(result[0])})")
                adjust_vertices( result[0] )
                Sketchup.active_model.commit_operation()
              rescue
                Sketchup.active_model.abort_operation()
              else
                @@last_tolerance = result[0]
        end # PROXY CLASS
        #{# RUN ONCE
        unless file_loaded?("GridSnap.rb")
          # Menu Entry:
          UI.menu("Tools").add_item("GridSnap") { menu_command() }
        end #}
      end # module
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby thomthom » Mon Mar 26, 2012 7:53 pm
        Dan Rathbun wrote:It seemed to only change a cubes vertices in the Z axis ??
        Should apply to X,Y and Z... Seemed to work correctly in my quick test...
        PluginStore Author
        PluginStore Author
        Postby daiku » Tue Mar 27, 2012 2:47 pm
        Polyhedronizer ?
        Orthogonizer ?
        Orthographizer ?
        OrthograFixer ?
        :lol:
        It's like Autotune for cad! They can make you sound good, even if you can't sing.
        If you are editing digital music, and you need to make the drum beats perfect, you can move the beats to the nearest sixteenth note, or whatever. It's call "quantizing".
        daiku
        PluginStore Author
        PluginStore Author
        Postby Dan Rathbun » Tue Mar 27, 2012 4:00 pm
        daiku wrote:It's called "quantizing".
        TRUE !!
        Restriction to discrete values (or multiples thereof,) rather than any values in the set of possibles (real numbers, in this case.)
        So.. the long term:
        Vertex Positional Quantization
        The short form:
        Vertex to Grid
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby rossthompson » Wed Mar 28, 2012 2:30 pm
          Hi guys, I have had a play with Dan's Beta version and for me it works really well. The verticies are adjusted in X,Y and Z directions and the undo function works fine!
          The only slight problem: it adjusts all the geometry in the model, rather than just the active selection. The original module just adjusted the active selection.
          Any ideas?
          Again thanks for the support - this script should be a realy time saver!
          Ross
          rossthompson
          Postby Dan Rathbun » Wed Mar 28, 2012 3:27 pm
          Well .. I did not think I changed the context of what Thomas' code did... just tried to wrap the code properly and added the menu_command() method to handle an inputbox.
          I'll have a look at it.. again.
          (And it's not really MY edition just because I added the inputbox.. it's still Thomas' thing.)
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Postby Dan Rathbun » Wed Mar 28, 2012 3:56 pm
            OK... added support for a selection. (Pssst! ... there was no selection support from the beginning Ross.)
            This utility should probably be wrapped in Thomas' toplevel author module, and reside below his author directory in some manner.
            I'll leave those choices up to him, and when he releases version 1.0.0, we'll delete these beta versions in this thread and put in a link to the release thread.
            Code: Select all
            #  GridSnap.rb
            #  by Thomas Thomassen
            #  THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
            #  IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
            #  WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
            #  This utility quantizes the vertex locations, of the current selection,
            #    of the model, or just the current context, to a 3D grid, whose interval
            #    can be set via a popup inputbox.
            #  Revisions:
            #   0.1.0 : 2012-03-26 : by Thomas Thomassen
            #   initial beta release
            #   0.2.0 : 2012-03-26 : by Dan Rathbun
            #   + Added menu_command() method for inputbox and undo operation.
            #   0.3.0 : 2012-03-28 : by Dan Rathbun
            #   + Revised the menu_command() method to pass a selection set to the
            #       adjust_vertices() method as a 2nd argument.
            module GridSnap
                    r = n % tolerance
                def test_it
                def adjust_vertices( tolerance = @@last_tolerance, ents = nil )
                  vertices = []
                  # determine the context:
                  ents = model.active_entities() if ents.nil?
                  # Collect vertices.
                  for e in ents #model.active_entities
                  vertices.flatten!
                  vertices.uniq!
                  vectors = []
                  entities = []
                    entities << vertex
                    vectors << vector
                def menu_command()
                  if result
                    begin
                        if model.selection.empty?
                        else
                          adjust_vertices( result[0], model.selection.to_a() )
                    rescue
                    else
              end # PROXY CLASS
              #{# RUN ONCE
                # Menu Entry:
              end #}
            end # module
              Dan Rathbun
              PluginStore Author
              PluginStore Author
              Postby VertexMover » Fri Oct 10, 2014 12:45 am
              Is there an easy way to have it go through the Outliner list and open each model group and snap those corners to the grid?
              What would need changed in the script so that it would snap all visible geometry to the grid, Without having to manually select and open each group?
              VertexMover
              Postby Dan Rathbun » Fri Nov 07, 2014 5:10 pm
              Dan Rathbun wrote:This utility should probably be wrapped in Thomas' toplevel author module, and reside below his author directory in some manner.
              It would need to iterate the model's definition list, changing those that have instances.
              But I'm not sure if it is really safe to change entities collections outside the current context?
              PM'ing TT
                Dan Rathbun
                PluginStore Author
                PluginStore Author
                Postby tt_su » Sat Nov 08, 2014 2:42 pm
                Dan Rathbun wrote:But I'm not sure if it is really safe to change entities collections outside the current context?
                That should be ok. One just need to keep in mind that the current open context apply a transformation that affect 3d points.
                tt_su
                SketchUp Team
                SketchUp Team
                Postby Dan Rathbun » Sat Nov 08, 2014 4:56 pm
                Ok.. but are ya gonna repost under TT_GripSnap or whatever? (I had said we'd remove the code blocks above and replace with Store links when done.)
                  Dan Rathbun
                  PluginStore Author
                  PluginStore Author
                  Postby thomthom » Sun Nov 09, 2014 10:20 am
                  This wasn't something I ever planned to publish. It was just a code snipped posted for anyone to grab.
                  PluginStore Author
                  PluginStore Author
                  Return to Developers' Forum
                  Users browsing this forum: No registered users and 5 guests
