pdScript-interpreter for GUI Scripting in SketchUp-Ruby
Postby HPW » Sat Jan 21, 2012 6:29 pm
Hello,
Some times ago I ran across a pascal script scripting language from Precision.
Whats it makes special was the fact that it supports GUI scripting.
http://www.be-precision.com/products/pdScript/
After they build an optional engine as a DLL, its get interesting to call it from other enviroments.
Similar to my newLISP integration into Sketchup, I build a pdScript extension for Sketchup.
newLISP: viewtopic.php?f=180&t=18127&p=148708
A screenshot:
http://www.hpwsoft.de/SU_PDS.png
Windows only!
Interested who want to try it can download here:
http://www.hpwsoft.de/anmeldung/html1/s ... chup3.html
The ZIP contains 1 file at the toplevel:
pdScript_ext.rb
The rb is the extension which must be activated in the preferences.
The subfolder contains the DLL's and samples. Preserve the folder when you unpack the ZIP.
The extension adds a menu to the plugins menu with some demo.
The Win32API extension is needed from here:
viewtopic.php?f=323&t=42732#p380121
Regards
Hans-Peter
HPW
Re: pdScript-interpreter for GUI Scripting in SketchUp-Ruby
Postby Dan Rathbun » Sat Jan 21, 2012 9:06 pm
    Here's the one stop place for Win32API.so (here at SCF.)
    [Plugin Library] Win32API and Win32OLE so files
    You need not distro any certain version, with your plugin.
    Just list a dependancy, and put the above link in any posting of a plugin.
      I'm not here much anymore. But a PM will fire email notifications.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby Dan Rathbun » Sat Jan 21, 2012 9:18 pm
      You should not need to create global variables if you wrap your code in a module of your own.
      Creating instance variables (@vars) at the top level (which is within Object,) is a very big no no !
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby HPW » Sun Jan 22, 2012 9:04 am
        Hello Dan,
        Thanks for the suggestions.
        I will remove the Win32API from the zip.
        I had a look to module as you advised.
        Here my frist attempt:
        Code: Select all
        require 'sketchup.rb'
        module PdScript
          if not file_loaded?(File.basename(__FILE__))
            # UI.messagebox("pdScript loader startet")
            win32api_file = Sketchup.find_support_file "Plugins/Win32API.so", ""
            pdScriptapi_file = Sketchup.find_support_file "Plugins/pdScript/pdScriptE.dll", ""
            # UI.messagebox("pdScriptDll="+pdScriptapi_file)
            if (win32api_file)
              require 'Win32API'
              # UI.messagebox("Win32API loaded ")
              if File.exist? pdScriptapi_file
                @pdScript = Win32API.new(pdScriptapi_file, "pdScriptA", ['P','P','L'], 'I')
                @pdsFreeScript = Win32API.new(pdScriptapi_file, "pdsFreeScript", ['I'], 'I')
                @pdsExecuteFunction = Win32API.new(pdScriptapi_file, "pdsExecuteFunctionA", ['I','P','P','P'], 'I')
                @pdScriptScriptHandle = 0
                # puts "psScript_Result: "
                # puts @pdScript
                dll_file = Sketchup.find_support_file "Plugins/pdScript/RubyConnect.dll", ""
                if (dll_file)
                  @FindConnectedWindow = Win32API.new(dll_file, "FindConnectedWindow", ['P','P'], 'P')
          #        UI.messagebox("FindConnectedWindow loaded")
                   FindConnectedWindowSU = @FindConnectedWindow.Call("- SketchUp","")
          #        UI.messagebox("Return from FindConnectedWindow: "+FindConnectedWindowSU)
          #      else
          #        UI.messagebox("File RubyConnect.dll is missing in the pdScript-Plugins! pdScript loading fails!")
                end   # if
                # UI.messagebox("pdScript loaded")
                add_separator_to_menu("Plugins")
                $pdScriptMenuStrings = LanguageHandler.new("pdScript_menu.strings")
                pdScript_menu = UI.menu("Plugins").add_submenu($pdScriptMenuStrings.GetString("pdScript"))
                pdScript_menu.add_item($pdScriptMenuStrings.GetString("Start pdScript clock Dialog")) { PdScript.start_clock_dialog }
                pdScript_menu.add_item($pdScriptMenuStrings.GetString("Start pdScript MyDialog Dialog modal")) { PdScript.start_mydialog_dialog }
                pdScript_menu.add_item($pdScriptMenuStrings.GetString("Start pdScript MyDialog Dialog non-modal")) { PdScript.start_mydialog_nonmodal_dialog }
                pdScript_menu.add_item($pdScriptMenuStrings.GetString("Start pdScript FreeScript")) { PdScript.start_freescript }
              else
                UI.messagebox("Cannot find file pdScriptE.dll!")
              end      # if
            else
                UI.messagebox("File Win32API.so is missing in the SketchUp-Plugins-Directory! pdScript loading fails!")
            end   # if
          else
           puts "File "+File.basename(__FILE__)+" was yet loaded!"
          end   # if
          def PdScript.start_clock_dialog
            # UI.messagebox("Before clock Dialog")
            pdScriptclock_file = Sketchup.find_support_file "Plugins/pdScript/Clock.dpas", ""
            retval = @pdScript.Call(pdScriptclock_file,"",0)
            UI.messagebox("Return from Clock-Dialog: "+retval.to_s())
          def PdScript.start_mydialog_dialog
            pdScriptMyDialog_file = Sketchup.find_support_file "Plugins/pdScript/MyDialog.dpas", ""
            retval = @pdScript.Call(pdScriptMyDialog_file,"/pds{hide-from-taskbar=true}",0)
            UI.messagebox("Return from Modal-Dialog: "+retval.to_s())
          def PdScript.start_mydialog_nonmodal_dialog
            pdScriptMyDialog_file = Sketchup.find_support_file "Plugins/pdScript/MyDialogNon.dpas", ""
            @pdScriptScriptHandle = @pdScript.Call(pdScriptMyDialog_file,"/pds{hide-from-taskbar=true;keep-alive=true;host-app="+FindConnectedWindowSU+"}",0)
            # UI.messagebox("Return from NonModal-Dialog: "+@pdScriptScriptHandle.to_s())
          def PdScript.start_freescript
            if @pdScriptScriptHandle > 0
             retval = @pdsFreeScript.Call(@pdScriptScriptHandle)
          #  UI.messagebox("Return from Freescript: "+retval.to_s())
          def PdScript.ExecuteFunction(param1, param2, param3)
             # UI.messagebox("Before ExecuteFunction")
             retval = @pdsExecuteFunction.Call(@pdScriptScriptHandle, param1, param2, param3)
             UI.messagebox("Return from ExecuteFunction: "+retval.to_s())
          file_loaded(File.basename(__FILE__))
          # Sample calls from RubyConsole to comunicate to open pdScriptdialog
          # PdScript.ExecuteFunction("ChangeEdit2","Value 2 from RubyCall","|")
          # PdScript.ExecuteFunction("ChangeEdit4","Value 4 from RubyCall","|")
          # PdScript.ExecuteFunction("ChangeEdits","Value 1 from RubyCall|Value 2 from RubyCall|Value 3 from RubyCall|Value 4 from RubyCall","|")
        Seems to work.
        Is that the proper way to use a modul?
        Since my main-programming language is not ruby, it was my intention for posting here to hear from the experts, if I am doing something wrong.
        Regards
        Hans-Peter
        HPW
        Postby Dan Rathbun » Sun Jan 22, 2012 7:05 pm
          You are still using a global var $pdScriptMenuStrings, use a module var instead, like @@pdScriptMenuStrings, or since it will local to your module, an even simplier name, like: @@lang (see below.)
          Also:
          1. you did NOT supply the "pdScript.strings" file
          2. trying to use Google's LanguageHandler class is problematic, because it assumes that the string file is in the Resources subpath (which is difficult to install into.)
              Instead just have your own "lang" or "strings" subdir, with UTF8 encoded hash files. These files should have extensions that are equal to the user's local language code, thus:
              langcode = Sketchup.get_locale.split('-')[0]
              @@extpath = File.dirname(__FILE__)
              langdir = "lang"
              langfile = "pdScript_menu.#{langcode}"
              langpath = File.join(@@extpath,langdir,langfile)
          So you have a subdir:
          "pdScript/lang"
          that has various string files, like:
          pdScript_menu.en # English
          pdScript_menu.de # German
          pdScript_menu.fr # French
          etc. etc.
          A user can copy the english file and resave it with another langcode extension, then edit the values for their own language.
          Just be sure to test using File.exists?(langpath) and if it returns false, then use the english as a default.
          It is not really necessary to use a convoluted class like LanguageHandler, when a plain Ruby Hash works just as fine. See the "langhandler.rb" file in the "Tools" dir for the snippet that loads a strings file into a Hash. You can have the hash stored in a simple name like: @@lang and just access the values, like: @@lang["Start pdScript MyDialog Dialog modal"]
          BUT.. you must also wrap the extension registration script "pdScript_ext.rb" inside your module so that the @@lang var is local to YOUR module, and not Object (which would propagate into everyone else's classes and modules.)
          File: 'pdScript_ext.rb'
          Code: Select all
          # File: 'pdScript_ext.rb'
          # This extensions allows the intergration of pdScript into SketchUp
          # Additional info about pdScript at www.be-precision.com/products/pdScript/
          require('sketchup.rb')
          require('extensions.rb')
          require('pdScript/langLoad.rb')
          module PdScript
            plugdir = Sketchup.find_support_file('Plugins')
            @@extdir = "pdScript"
            langdir  = "lang"
            langpath = File.join(plugdir,@@extdir,langdir,"pdScript_menu.#{langcode}")
            if not File.exists?(langpath)
              langcode = 'en'
            @@lang = parse_langfile(langpath) # create the language hash
            @@extension = SketchupExtension.new( @@lang["pdScript interpreter"], "pdScript/pdScript.rb")
            @@extension.description = @@lang["Adds pdScript interpreter to the ruby environment"]
            @@extension.name= "pdScript interpreter"
            @@extension.creator = "HPW/Precision"
            @@extension.copyright = "2012-01-22"
            @@extension.version = "1.0"
            Sketchup.register_extension( @@extension, false )
          (PS: use Ruby standard date string format: YYYY-MM-DD)
          File: 'pdScript/langLoad.rb'
          Code: Select all
          # Copyright 2005-2008, Google, Inc.
          #   code from "Tools/LangHandler.rb"
          #   Modified for use with PdScript module. 2012-JAN
          #   renamed to: 'pdScript/langLoad.rb'
          # Permission to use, copy, modify, and distribute this software for
          # any purpose and without fee is hereby granted, provided that the above
          # copyright notice appear in all copies.
          # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
          # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
          # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
          module PdScript
            class << self  # Proxy class bound to THIS module:
              @hash = ""
              #  parse_langfile( langpath )
              #  Args:
              #    langpath  :  a fullpath to a UTF8 encoded strings format file.
              #  Returns a hash object loaded with the new strings, and english keys.
              def parse_langfile(langpath)
                @hash = Hash.new {|hash,key| key }
                # for [] method, returns the arg if key does not exist in hash
                langFile = File.open(langpath, "r") { |file|
                  entryString = ""
                  inComment = false
                  file.each do |line|
                    #ignore simple comment lines - BIG assumption the whole line is a comment
                    if !line.include?("//")
                      #also ignore comment blocks
                      if line.include?("/*")
                        inComment = true
                      if inComment==true
                        if line.include?("*/")
                          inComment=false
                      else
                        entryString += line
                    if entryString.include?(";")
                      #parse the string into key and value
                      #remove the white space
                      entryString.strip!
                      #pull out the key
                      keyvalue = entryString.split("\"=\"")
                      #strip the leading quotation out
                      key = keyvalue[0][(keyvalue[0].index("\"")+1)..(keyvalue[0].length+1)]
                      #pull out the value
                      keyvalue[1].gsub!(";", "")
                      value = keyvalue[1].gsub("\"", "")
                      #add to @strings
                      @hash[key]=value.chomp
                      entryString = ""
                  end # do each line
                } # end of File.open (File is closed automatically.)
                return @hash
              end # def
            end # proxy class
          end # module
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Postby Dan Rathbun » Sun Jan 22, 2012 7:43 pm
              Changed File: 'pdScript/langLoad.rb', line 32 (and added comment.)
              Will set the hash so that 'key' will be returned, if it is not present as a key.
                Dan Rathbun
                PluginStore Author
                PluginStore Author
                Postby Dan Rathbun » Sun Jan 22, 2012 7:47 pm
                Woops.. do not forget to change the version in the _ext file:
                @@extension.version = "1.0.1" or whatever....
                  Dan Rathbun
                  PluginStore Author
                  PluginStore Author
                  Postby HPW » Sun Jan 22, 2012 11:51 pm
                  Hello Dan,
                  Thanks again for the advises and samples.
                  I did what you say, but since you did not post the file format for the language file I tried to understand the source of the parse-function.
                  My pdScript_menu.en is this:
                  Code: Select all
                  pdScript interpreter="pdScript interpreter"
                  Adds pdScript interpreter to the ruby environment="Adds pdScript interpreter to the ruby environment!"
                  pdScript="pdScript English"
                  Start pdScript clock Dialog="Start pdScript clock Dialog English"
                  Start pdScript MyDialog Dialog modal="Start pdScript MyDialog Dialog modal English"
                  Start pdScript MyDialog Dialog non-modal="Start pdScript MyDialog Dialog non-modal English"
                  Start pdScript FreeScript="Start pdScript FreeScript English"
                  The function runs but I get always the key instead of the value.
                  What did I miss?
                  Regards
                  Hans-Peter
                  HPW
                  Postby HPW » Mon Jan 23, 2012 12:33 am
                  I think I have now the correct format but it still does not work.
                  Code: Select all
                  "pdScript interpreter"="pdScript interpreter";
                  "Adds pdScript interpreter to the ruby environment"="Adds pdScript interpreter to the ruby environment!";
                  "pdScript"="pdScript English";
                  "Start pdScript clock Dialog"="Start pdScript clock Dialog English";
                  "Start pdScript MyDialog Dialog modal"="Start pdScript MyDialog Dialog modal English";
                  "Start pdScript MyDialog Dialog non-modal"="Start pdScript MyDialog Dialog non-modal English";
                  "Start pdScript FreeScript"="Start pdScript FreeScript English";
                  UI.messagebox(@@lang["pdScript interpreter"])
                  does show an empty dialog.
                  Hans-Peter
                  HPW
                  Postby Dan Rathbun » Mon Jan 23, 2012 2:32 am
                  in File: 'pdScript/langLoad.rb'
                  the hash var may be out of scope for the nested blocks. There is some difference between { ... } and do ... end
                  I'll try to test later.
                  And you can look at any of the strings files in your "Resources/de/" folder. You'll see they have English keys and German values.
                    Dan Rathbun
                    PluginStore Author
                    PluginStore Author
                    Postby Dan Rathbun » Mon Jan 23, 2012 5:21 am
                    HPW wrote:The function runs but I get always the key instead of the value.
                    What did I miss?
                    because:
                    PdScript.module_eval "puts(@@lang.inspect)"
                    returns:
                    {"pdScript"=>nil, "Adds pdScript interpreter to the ruby environment"=>nil, "pdScript interpreter"=>nil, "Start pdScript clock Dialog"=>nil, "Start pdScript FreeScript"=>nil, "Start pdScript MyDialog Dialog modal"=>nil, "Start pdScript MyDialog Dialog non-modal"=>nil}
                    and I created the Hash so that if the value was invalid, it would return the English key as a backup.
                    Two problems
                    line 74 was chomp! should be chomp
                    also, easiest solution for scoping, was to use a instance @ var: @hash instead of hash
                    In addition, the keys must be EXACT when you ask for the value, or else you just get the arg returned.
                    I corrected the files above
                      Dan Rathbun
                      PluginStore Author
                      PluginStore Author
                      Postby HPW » Mon Jan 23, 2012 7:12 am
                      Hello Dan,
                      Thanks again.
                      I will add this at the evening.
                      One question again: Is there a save way to gets sketchup's main window handle.
                      I see some posts with winApi calls to search the window by title string.
                      I have done the same in my Dll.
                      Would be nice when Sketchup would publish this in a global var.
                      Hans-Peter
                      HPW
                      Postby HPW » Mon Jan 23, 2012 7:50 pm
                      Hello,
                      Added all suggested changes and upload a 1.01 zip to the link above.
                      Thanks again to Dan for the advises and code samples. Learned a lot.
                      Hans-Peter
                      HPW
                      Postby HPW » Tue Jan 24, 2012 10:08 pm
                      Hello,
                      I made a small page for the sketchup plugin on my website.
                      I updated the above link for the download.
                      Hans-Peter
                      HPW
                      Return to Developers' Forum
                      Users browsing this forum: Zawayaid and 4 guests
