add_group slow on mac
Re: add_group slow on mac
Postby Dan Rathbun » Sun Jan 29, 2012 2:15 pm
Bummer... definately the problem is in the C++ code.
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby jhauswirth » Mon Jan 30, 2012 7:18 pm
    Looking at the add_group Ruby code, its the same on both platforms.
    One reason (don't know if this is true) it could be slower on the Mac
    is the notifications that are sent around could be updating the Mac
    UI, like the component browser. This may be more efficiently done on
    the PC.
    Also, the same code (duplicate code/cut-n-pasted it looks like) that
    I fixed in the C++ API was also being used in the Ruby code.
    The bug report only mentioned the C++ API, so that's what got fixed.
    jhauswirth
    Postby thomthom » Mon Jan 30, 2012 7:29 pm
    jhauswirth wrote:Looking at the add_group Ruby code, its the same on both platforms.
    the PC.
    I have noticed that if you use Sketchup.status_text within a loop it will be very slow under OSX. It seems that the UI is forcefully freshened all the time, while on Windows you get "white-out" and the UI stops updating - but completes the loop much much faster.
    But if it is the UI that slows things down, then running the test with start_operation and disable_ui argument set to true, should show a good performance increase, right?
    PluginStore Author
    PluginStore Author
    Postby Dan Rathbun » Tue Jan 31, 2012 1:29 am
    @John: thanks for taking a look at this, and "weighing in."
    @GWD: Are all these groups to be added REALLY have all the same objects (like the example,) and just have a different location (transform) ?
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby GWD » Tue Jan 31, 2012 6:34 am
      Dan Rathbun wrote:@John: thanks for taking a look at this, and "weighing in."
      Dan,
      No this is just a quick test that reproduce the problem. We have at this moment 2 totaly different script which have this problem.
      GWD
      PluginStore Author
      PluginStore Author
      Postby GWD » Tue Jan 31, 2012 10:32 am
      the PC.
      I tested it with start_operation and it as no effect!
      GWD
      PluginStore Author
      PluginStore Author
      Postby GWD » Tue Jan 31, 2012 11:29 am
      I just did some testing with adding components instead of groups (see script below). And the result is shokking. Placing 600 component give about the same time as the 600 groups 0.7 sec on PC and 27 sec on MAC. BUT after the script ended the MAC keep on showing the busy icon for very long time. More than 5 minutes (then i killed sketchup). I did the same test on mac with different number of components and this are the results:
      50 components 0.29 sec running script 17 sec busy icon after script
      100 components 0.85 sec running script 35 sec busy icon after script
      200 components 3.8 sec running script 2 min 25 sec busy icon after script
      300 components 7.6 sec running script more than 5 min sec busy icon after script
      600 components 27 sec running script more than 5 min busy icon after script
      Code: Select all
      require 'sketchup'
      UI.menu("PlugIns").add_item("bugMAC Test2") {
      model = Sketchup.active_model
      entities = model.entities
      puts '- Start test1 add_group bug on MAC -'
      start = Time.now
      for n in 1..600 do
         newdef = model.definitions.add
         newdef.name = n.to_s
         point1 = Geom::Point3d.new(n*10,0,0)
         newdef.entities.add_cpoint point1
         pt = Geom::Point3d.new 0,0,0
         trans = Geom::Transformation.new pt
         i = model.entities.add_instance(newdef, trans)
         i.make_unique
      puts 'Total time: ' + (start - Time.now).to_s
      GWD
      PluginStore Author
      PluginStore Author
      Postby GWD » Mon Feb 06, 2012 4:38 pm
      No solutions?
      GWD
      PluginStore Author
      PluginStore Author
      Postby Dan Rathbun » Mon Feb 06, 2012 5:09 pm
      Not surprising that it takes the same time to add groups and components, because a group is a special type of component, that also has a ComponentDefinition (whose group? attribute is true.)
      The extra time, likely comes from adding all that new stuff to the Component browser. (guessing, here.)
      Close any unneeded toolwindows, especially the Object browser. And use an operation with the disable_ui flag set.
      That's all we can say. I guess John indicated that there were UI issues with the Mac edition. (I'm not sure if he said the SDK updates did, or did not make it into the last build... he was a bit ambiguous. But internal politics, ya know....)
      You can always file a bug report. The more people that scream...
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby GWD » Mon Feb 06, 2012 5:52 pm
        Dan, where can i post a bug report?
        GWD
        PluginStore Author
        PluginStore Author
        Postby Dan Rathbun » Mon Feb 06, 2012 10:37 pm
        GWD wrote:Dan, where can i post a bug report?
        Open Sketchup... pulldown the Help menu, choose "Contact Us" ...
        ... your browser will open, to the Google Sketchup Contact page.
        Use the "Bug Report" link, to bring up the form, and fill it out.
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby GWD » Tue Feb 07, 2012 8:23 am
          I submitted a bug report.
          GWD
          PluginStore Author
          PluginStore Author
          Postby Dan Rathbun » Thu May 24, 2012 4:03 am
            Good news for Mac users. This issue has been reported as fixed in the 8.0M3 release.
            see: SketchUp Release Notes
            and get the latest MR at the SketchUp Downloads page.
              Dan Rathbun
              PluginStore Author
              PluginStore Author
              Postby th3lurker » Thu May 24, 2012 9:05 am
              I would have loved it if they fixed add_face too. I've found workarounds, so i don't need it now, but still.
              th3lurker
              Postby GWD » Fri Jun 01, 2012 4:01 pm
              The problem isn't fixed at all on mac. I did the test i posted before with the new version. On mac the script runs 250% slower on the new version. On pc the script runs 300% faster on the new version!
              GWD
              PluginStore Author
              PluginStore Author
              Postby thomthom » Fri Jun 01, 2012 4:23 pm
              GWD wrote:The problem isn't fixed at all on mac. I did the test i posted before with the new version. On mac the script runs 250% slower on the new version. On pc the script runs 300% faster on the new version!
              Can you post your test code?
              PluginStore Author
              PluginStore Author
              Postby GWD » Fri Jun 01, 2012 4:50 pm
              You can find the code on page 3
              GWD
              PluginStore Author
              PluginStore Author
              Postby driven » Wed Dec 19, 2012 10:27 pm
              GWD wrote:You can find the code on page 3
              after a lot of digging, it appears that your test code will run in 0.8[1..3] seconds on both Snow Leopard and Mountain Lion with free or pro SU v6, v7 or v8, UNLESS you have either of these in your preference list
              <string>OutlinerController</string>
              <string>ComponentGBrowserController</string>
              these have no ill effect, but add either of the others and you beach-ball...
              <key>OpenInspectors</key>
              <array>
              <string>PagePanelController</string>
              <string>LayerPanelController</string>
              <string>StyleBrowserController</string>
              <string>SoftenPanelController</string>
              <string>EntityInfoController</string>
              </array>
              They actually fork the main Thread into a timer loop to make the thumbnails and will do that even if the ruby has run before you open the Inspector. i.e run test code without, then zoom, orbit, make new geometry, etc... turn on 'Components' or 'Outliner' and you'll get a beach-ball.
              If 'Components' is run first 'Outliner' opens straight away.
              john
              driven
              PluginStore Author
              PluginStore Author
              Previous
              Return to Developers' Forum
              Users browsing this forum: No registered users and 9 guests
